Brake Adjustment Question
Quoted: 81 Post(s)
Liked 7 Times
Hi folks,
I went to my LBS to have new brakes installed (Shimano Altus C91 Rear Cantilever) just before the COVID 19 lockdowns. I didn't look closely when I took the bike home and the bike seemed to stop fine. I looked again recently and saw that the gap between the pads and the wheel rims on my rear tire are irregular. Does this need to be fixed? If yes, what needs to be adjusted? Is this doable for an amateur mechanic?
view of brakes from top
side view
Left side: large gap between pad & wheel rim
Right side: almost no gap between pad & wheel rim
side view
You should be able to put an Allen/hex key in the Spot I circled (to hold it steady), then I believe it’s a 10mm wrench that will go on the bolt head on the opposite side (where the arrow is pointing). Loosen with the wrench as you hold the Allen key steady. This should loosen the pad and allow you to back one side out (or the other side in) to even out the gap.
Do this for major adjustments. For small adjustments, you can just turn the tiny screw sticking out of the side of the left side pad:
Totally doable with no experience. I’d start with the small screw to see if you can get it straightened out.
Disclaimer: I’ve never even seen these brakes, just did a quick google search.
Did you check the installation of the wheel? My wife had a similar issue. Turns out she did not seat the QR skewers properly in the fork.
Likes For powermatt99:
Quoted: 581 Post(s)
Liked 921 Times
@powermatt99 says, the problem is almost definitely that the wheel is not straight in the dropouts. This is a very common mistake when adjusting brakes, and will make an experienced mechanic pull their hair out until they realize the simple mistake.
You can tell it is wheel alignment because the way the pads have become misaligned - one pad too close and riding up on the tire, and the other pad a mile away from the rim. THis is exactly what happens when the wheel is not straight.
Likes For ClydeClydeson:
Quoted: 581 Post(s)
Liked 921 Times
except that advice skips the troubleshooting steps that will identify the root of the problem (almost definitely the wheel is not straight in the dropouts), and adjusting the brakes to work with the wheel crooked in its dropouts will just become even worse adjusted brakes as soon as the wheel is removed and replaced again.
Quoted: 81 Post(s)
Liked 7 Times
Hi again,
Thanks for the comments about wheel alignment and skewers. Now the origins of the brake problem make sense. I have a Burley trailer and just added the trailer "hitch" to the quick release skewer. So that may have knocked things out of line? If yes, how do I adjust the brakes or wheel?
Quoted: 581 Post(s)
Liked 921 Times
To fix wheel alignment in the dropouts, you just have to loosen the quick release, then ensure the axle is fully seated in the dropouts before you retighten the quick release. I bet if you do this right your brakes will no longer be out of adjustment.
Quoted: 581 Post(s)
Liked 921 Times
ALSO
There are usually two little conical springs on the QR skewer. These should be positioned one on each side so that the smaller end of both springs are pointing in towards the hub. Having a backwards QR spring will make it impossible to get the wheel straight.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,217 Times
Hi folks,
side view
side view
Stuart Black
Stuart Black
Above should look symmetrical .. the main cable passes through the grey tube , it needs to be a little bit tighter/ looser..
use the fixing bolt to adjust its length..
then pad to rim spacing is done with the length of the shaft on the brake pad post.
Don't mean to derail this thread but
Every time I remove my rear tire I have to adjust the rear derailleur to get shifting back to perfect. Is that a common problem with QR's? or am I not fully seating it.
You don't have a straddle cable , That cable continues thru the grey tube and is held by the clamping bolt on the right side arm.
It's a fail safe system, so a broken main cable wont drop the straddle cable onto front tire,
with knobby tires the bike stops throwing the rider to the ground..
maybe you need to consider buying a separate transverse cable and the hanger you put on that main cable like this,
which you think you now have, but don't.
like this : ^the top pieces^ you can find them for a few bucks @ bike shops..
Quoted: 581 Post(s)
Liked 921 Times
One possibility is that the removable derailleur hanger (if your bike has one) is not properly fastened to the frame. Make sure the bolt(s) that connect(s) the hanger to the frame are tight. If they are loose, the hanger will move when the wheel is installed.
Quoted: 1572 Post(s)
Liked 643 Times
The return springs in those particular brakes are confined within a plastic retainer. Examine those little plastic cups for cracks. If you find a crack, that's your problem. Shimano used to provide replacements at no charge. I've also successfully fixed them by wrapping the cracked cup with wire..
Liked 4,217 Times
And from above.
Here’s what it should look like from the front and
Above
The difference is subtle but if the through cable is in the wrong place, it can pull the brakes off to one side.
By the way, an old style straddle cable and hanger like this one
_IMG4950 by Stuart Black, on Flickr
doesn’t pull the cable one way or the other because of the tension on the one side of the hanger like the link cables can. If they do, you just slide the hanger over.
Stuart Black
Stuart Black
Quoted: 2952 Post(s)
Liked 3,106 Times
Yep. With straddle hangers, a lot of times you can get it to self align with a good hard squeeze of the brake lever.
Quoted: 1062 Post(s)
Liked 665 Times
I'm voting for wheel alignment, because the tire is also quite close to the fender on the side that it's close to the pad. If the frame has vertical dropouts, then you can usually fix this by just holding the bike straight upright, flick the QR open, then flick it closed again. You'll hear it clunk into place. This will also be a good time to review the correct technique for using QR.
Liked 4,217 Times
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 4,217 Times
The hundreds of them that we have in the parts bin at my co-op have lost them long ago
Stuart Black
Stuart Black
