Should I Restore This Paramount?
#76
Bikes: 2019 Trek Emonda SLR7 Disc, 2017 Advocate Cycles Sand County, 2016 Surly Disc Trucker, 2011 Specialized Tarmac SL3 Expert Double, 1996 Sancineto, 1989 Cinelli Corsa "Mens Sana," 1985 Peugeot PGN-10 Galibier, 1974 Schwinn Paramount
Quoted: 26 Post(s)
Liked 45 Times
Whoops. I hadn't realized reach issues yet, because I haven't straddled or sat upon it. I can adjust them up pretty easily once the time comes. Thanks for noting that so I can give it some attention later.
Likes For Hailstorm_7:
#78
Quoted: 3464 Post(s)
Liked 2,827 Times
To move the shifters up to the typical position - the rear shift cable will end up being the front, the rear will need to be replaced.
check to position of the cable guide near the bottom bracket while you are at it.
this frame was designed for 27” wheels
can take 700c - you might consider Weinmann centerpull or DiaCompe center pull brakes.
#79
Quoted: 4510 Post(s)
Liked 6,374 Times
#80
Quoted: 5888 Post(s)
Liked 3,471 Times
I've enjoyed this thread and you're doing a great job. You picked up your Paramount around the same time as I picked up my '68 Paramount. Mine came with Weinmann centerpulls, a stronglight 55 crank, and a bunch of Campy record parts. Those parts are all original to the bike. I plan on rebuilding mine this year once my garage is no longer a deep freeze.
Likes For bikemig:
#81
Quoted: 26 Post(s)
Liked 45 Times
Completed project pics are up here: https://www.bikeforums.net/classic-v...l#post22034603
Thanks again for all your help and encouragement!
