Go Back  Bike Forums > Bike Forums > Framebuilders
Steel track frame - fork dents/dimpling/crimples?
Framebuilders Thinking about a custom frame? Lugged vs Fillet Brazed. Different Frame materials? Newvex or Pacenti Lugs? why get a custom Road, Mountain, or Track Frame? Got a question about framebuilding? Lets discuss framebuilding at it's finest.
Old 03-12-21, 10:20 AM
jliet
Quoted: 7 Post(s)
Liked 4 Times in 3 Posts
Hello, posting as I was directed here!
Just found these when I removed the front track (non-drill) brake that was attached to the fork - believe it is columbus aelle tubing. Presuming these are from the stress of the brake and not something that was done intentionally by frame builders (i.e. crimping to increase spacing? doesn't seem like it with the size of these).
Presuming this fork is not safe to ride after all...
Cheers.
jliet is offline
Old 03-12-21, 11:59 AM
unterhausen
Randomhead
Liked 3,684 Times in 2,508 Posts
It's hard to understand what is going on with that. I don't think I have ever seen a fork with that sort of dent as a result of buckling.
My rule about forks is that if I don't feel fully confident, even if I don't know why, I don't ride it. I think most people feel the same way.
unterhausen is offline
Likes For unterhausen:
Old 03-12-21, 12:55 PM
jliet
Quoted: 7 Post(s)
Agreed! I think I will take it to a local framebuilder/etc and see what they say and whether it's worth repairing.
And I definitely wouldn't have ridden it, I just didn't see this until now aha, so unfortunately (or fortunately) I did some inadvertent stress testing already...
jliet is offline
Old 03-12-21, 01:04 PM
guy153
Quoted: 321 Post(s)
Liked 261 Times in 212 Posts
My interpretation of what the OP was saying was that it previously had some kind of band-on brake mounts that were fitted by a 300lb gorilla.
guy153 is offline
Old 03-12-21, 01:42 PM
jliet
Quoted: 7 Post(s)
And the brakes even had a rubber padding... guess someone really went for it.
jliet is offline
Old 03-12-21, 02:08 PM
unterhausen
Randomhead
Okay, sorry, I didn't read closely enough. I wouldn't ride it.
Old 03-12-21, 03:39 PM
Trakhak
Trakhak's Avatar
Quoted: 2468 Post(s)
Liked 2,942 Times in 1,671 Posts
For those unfamiliar with clamp-on brakes for track bikes, this or something like it was apparently installed on the fork.
Trakhak is offline
Likes For Trakhak:
Old 03-13-21, 07:11 AM
smontanaro
Bikes: many
Quoted: 1439 Post(s)
Liked 1,377 Times in 755 Posts
Hmmm... Might be a "solution" for those pesky 650b conversions where you can't find long enough brakes.
Monti Special
smontanaro is offline
Old 03-13-21, 07:39 AM
jliet
Quoted: 7 Post(s)
They are actually generally great - in this instance the person actually installed the ovalised 'aero' version on round forks, hence the dents... But otherwise they are decent!
jliet is offline
Old 03-13-21, 04:53 PM
bulgie
blahblahblah chrome moly
bulgie's Avatar
Quoted: 1172 Post(s)
Liked 2,566 Times in 1,072 Posts
Maybe the blades were damaged in the same crash that buckled the downtube? I didn't hear any mention of the DT being kinked, but it is, right? Lug point starting to do the "can opener" on the tube? Unless this is some kinda lens distortion.
Mark B
bulgie is offline
Old 03-13-21, 06:56 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4191 Post(s)
Liked 3,834 Times in 2,293 Posts
Mark makes an interesting point. Less the question about possible DT frontal impact evidence (which I can sort of see too) but more the possibility of more then one issue at play at the same time. We seem to like simple explanations and short routes to an answer but real life often has a few involvements going on at the same time. It is very easy to envision that this frame has had both a frontal impact as well as a heavy handed but wrong install of a uncommon brake mount. That two problems might be seen should not be dismissed. Once again this possibility shows we here are so limited in our ability to give advice with limited info and few images. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 03-14-21, 01:15 AM
bulgie
bulgie's Avatar
Originally Posted by Andrew R Stewart
<...> the possibility of more than one issue at play at the same time.
Or put another way, Occam was an optimist.
It's always tempting to look for one simple explanation, but sometimes there's more than one thing wrong.
Who here has found "the" piece of glass in their tire only to immediately get another flat because there were two pieces of glass in the tire? (Obviously a question only for those old enough to remember innertubes.)
bulgie is offline
Likes For bulgie:
Old 03-14-21, 02:05 AM
guy153
Quoted: 321 Post(s)
I call this the British Car Problem. You hear a funny noise and think CV joint. You take it all apart and the CV is indeed shot. Three days later, and with most of the grease now out of your eye sockets, off you go. The same noise. The CV was shot but so were the ball joints. Occam clearly never owned a Mini.
guy153 is offline
Likes For guy153:
