Tires that will allow a road bike to ride ok on Rails To Trails gravel?
Likes For ofajen:
Old enough, hmmm?
I'd try something like the 700x45c they use on gravel bikes; if they fit your rims and clear the brakes.
BTw there is no standard for Rail Trail surfaces, they come in a wide range. Ours has what I call crusher fines in the tracks that everyone rides, left and right of those the grit is coarser and when they patch up a section it is coarser still.
As far as dust goes, bike cleaning will be a regular chore.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2579 Post(s)
Liked 5,636 Times
Have 32s on this non-gravel but endurance frame and have ridden a couple of hundred miles on gravel rail/trial conversions as well as some easy single track.
INFINITO CV
INFINITO CV
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
With the gravel trails we have around here, I found 25mm and 28mm to be a bit too thin for comfort. 32mm was a nice compromise between gravel and pavement. On my old bike I had some 32mm Schwalbe Marathon tires that were pretty heavy, but indestructible.
Quoted: 18410 Post(s)
Liked 15,530 Times
Expired Member
Quoted: 3665 Post(s)
Liked 5,416 Times
Likes For shelbyfv:
Quoted: 77 Post(s)
Liked 88 Times
I think tire width is largely dependent on your ability to pick and stick with a line, the amount of deep sand/mud and your frame. I rode the Saluda Robaux on 30s as its the largest tire my Domane will accept and I'm an old geezer. A lot of the pros rode 28s at the Roubaix and at the Gravel Locos 150. Rails to trails are normally compacted and thus allows us to use 25 to 28s. Have fun
Maybe try touring tires. Last year I took trip to PA to ride rail trails. During the pandemic it was hard to find tires locally. I ended up getting Continental Ride Tours (700x35). Smooth on the bottom and knobby on the sides. I was pleased with how they rode. Also I wanted something with decent puncture resistance since I didn't know what conditions I would encounter.
My goal for this year (now it'll be next year) is to ride the Katy trail in Missouri. Depending on who you believe, it is either smooth and fast hard packed crushed limestone, coarse gravel, or soft loose sand and rocks. Could be all of those, considering the trail itself is a couple-three hundred miles long I think. And some areas have been prone to flood in recent years.
I might decide to take two bikes and use them as conditions warrant.
Quoted: 4227 Post(s)
Liked 2,488 Times
Any tire of about 32mm - 45mm size with some tread is perfect for riding on Rails to Trails gravel. I would avoid slicks and choose a touring tire or cx tire for riding on any type of gravel
Likes For wolfchild:
Back 40+ years ago when I had a bike with 27" tires, I found that 27x1 1/4 was OK (barely) for most gravel, but 27x1 1/8 was dicey. My hybrid ran 700x35 knobbies for a while, and that was pretty good on most gravel.
Cheerfully low end
Quoted: 645 Post(s)
Liked 1,044 Times
I switch to small knob tires in the cold half of the year when the trails tend to be saturated and have soft or muddy places.
Otto
I know I have a friend who got a nice road bike and he noticed that while he CAN use it on gravel its uncomfortable. It has no shock absorption and riding it on the gravel beat the heck out of him. So he keeps the road bike to the roads where he can fly. And his other bikes for doing off roading. His major complaint was he missed the shock absorber on the set post most. LOL
I agree with most of the cyclists, Rails to Trails road beds are great for any tire…that said, since I ride for enjoyment not speed, I’d suggest a touring type tire. I’ve been using Continental 700C x 32, max psi a bit above 90. I’d stay away from the narrow rimmed high psi tire…
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
I've put thousands of miles on the crushed limestone gravel paths in the Chicago area (I live near the Illinois Prairie Path), and I primarily ride a road bike with 32 mm tubeless tires. I keep the pressure at 45-60 psi, depending on if I'm mixing in many paved sections. I ride higher pressures on road rides.
It's really only an issue if I hit some loose terrain or sandy areas, which do exist on these trails. But I enjoy the thrill of being a little "under-biked".
Can I ride a road bike on the small gravel you see on the old train track bike trails with the right tires? I wouldn't think the smooth 27x1 1/4 road tires would do great... but then again, it's usually a pretty straight line ride. I have close to zero road bike experience. I have one road bike with tires that look like skinny mountain bike tires. I haven't ridden it enough to know much about how those would do. Any thoughts on this setup?
Quoted: 5224 Post(s)
Liked 3,581 Times
one can also play with tire pressure. meaning, let a pound or two out. it can soften the ride & the front tire will be less twitchy around any loose objects
Likes For rumrunn6:
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Quoted: 219 Post(s)
Liked 217 Times
Others have covered it well. I'll just add my own experience on crushed stone trails near me is it's fine if the tires are on the skinny side IF
1. you're comfortable and confident on that particular bike, 2. there is SOME tread (my kid has a small road bike with 24" (ISO520) x 1" tires and just switching to a Panaracer made for multi surfaces helped lots, even though it's the same 1" width.
I've ridden rail trails on 26mm (Panaracer Gravelking) and had no issues EXCEPT with SAND - not gravel, but deeper loose sandy patches. Since I moved to 35mm tires (on a newer bike that could fit 'em) I've had no issues with that "squirreliness." I bet even 32s would be more than enough. It's just having enough width and enough small tread pattern.
I was on a rail trail (gravel) the other day with my hearty 45mm tires. No, problems, enjoying the ride when I met up with a couple of road bikes riding 23mm. After a hello and the weather, they asked me where the nearest asphalt was.
Bikes: Raleigh Hybrid, Raleigh Mixte, Catrike 559
Cheerfully low end
Quoted: 645 Post(s)
Liked 1,044 Times
I have many miles touring and day rides on the Katy Trail's crushed limestone with 700 x 32's on a Fuji Touring, the Panaracers that came on it new, they worked out fine. The only time I recall a problem was through a short section where the trail had flooded and a new base of larger gravel/rock had been put down.
The trail surface prior to that 1993 flood was smooth enough that I had no real issues riding it, which would have been on 300g training tubulars that would likely have been 21s or maybe 23s.
Since about that time I have really not done dedicated road rides and primarily stay on our trails and connect via low traffic roads.
On the Katy, 700x32 is plenty of tire in dry conditions and really, even in the winter, the Katy itself can be managed with 32s, though a lot of the regulars are running 38s.
Getting to it in winter on a connecting trail or heavily graveled road, however, I enjoy the luxury of 26x2.2 tires on my old MTB.
Otto
meh
Quoted: 1110 Post(s)
Liked 1,013 Times
I didn't read all the posts in the thread (I'm kinda lazy) ... so this might be repeating earlier posts:
Not all rail-trail 'gravel' is the same, so tires that work on 'your' rail-trail might not work on 'their' rail-trail.
That said, Frau Toad spent many years riding & miles our local rail-trail (Lake Minnetonka Trail) with a crushed limestone surface on 23 to 28 mm road tires without a single complaint. I've find 28 mm T-Serv tires great on any rail-trail surface I've seen around the Twin Cities. Frankly, rail-trails are straight and flat so there's very little need to worry about handling/grip.
I should point out that I'm also the Toad that'll ride 4" fat tires on these same trails ... So there's that
Quoted: 241 Post(s)
Liked 232 Times
Earlier this season I encountered 3 riders on one of the trails out for their first "gravel" ride. Chatted with them a bit and they kept raving about how nice the trails were, how light the traffic was, how nice the scenery was. Digging in a little more I found out that they had never been on the trail before since they all didn't have gravel bikes until this year. I sort of laughed when they said that, and that's when they noticed I was on a road bike with rim brakes and slicks. All 3 looked shocked that I was on such ill-suited equipment.
All I could think of was how did these guys miss these routes for who knows how long simply because they didn't think they had the "right" bike? I've been riding some of these trails for over 20 years with the same type of equipment. Give it a try on your present bike. If it doesn't work turn around and go home with the knowledge of what you need to do to ride the trail. If it works, enjoy. But analyzing the heck out of it is a sure way to miss out.
Likes For RGMN:
