Disc brake caliper won't line up using post-to-flat mount adapter
Quoted: 446 Post(s)
Liked 1,044 Times
I'm currently working on a new bike build. Everything was completed yesterday and the only thing left was to attach the front disc brake caliper. The fork is flat mount and the disc brakes are post mount using a post-to-flat adapter. I attached the adapter to TRP HY/RD brakes I'm using, but the disc rotor ended up rubbing towards the outer pad and there is no adjustment space on the bolts to center it. I tried using washers underneath the post/flat adapter, but that didn't help and I tried multiple adjustments including trying to realign the wheel with no luck.
So I'm wondering what options I should try next? The post-to-flat mount adapter I was using is Shimano. Should I try another adapter? I was thinking maybe the Shimano adapter isn't playing well with the TRP brakes, so I was wondering if a matching TRP adapter would make a difference? Maybe it's the fork that's causing the issue? Since it's a flat mount fork, perhaps the tolerances aren't tight enough to compensate for the addition of the adapter? Last option would be to swap out the post disc brake for a flat mount version? Though I'd prefer not to do that, before exhausting all other options.
Any advice would be appreciated. Thanks!
Quoted: 1438 Post(s)
Liked 1,092 Times
Is the adapter symmetrical, and if not, is it in the correct orientation?
Quoted: 446 Post(s)
Liked 1,044 Times
I notice when I have the adapter not fully screwed in I have some play to center the brake calipers to the rotor, but the moment I tighten the adapter to the fork, the alignment goes off by a few millimeters causing the pads to lean on the rotor with no room for adjustment. I tried 2 small washers under each bolt of the adapter, but that didn't seem to help. Also I don't think spacers would make a difference with the brake bolts. I'm ordering another adapter and see if that'll help on alignment, but I'm worried it could just be sloppy tolerances on the fork bolt mounts, since it was probably intended to be used with regular flat mount brakes.
Liked 1,092 Times
Is it possible that some file work on the adapter would help the alignment. If it was my bike I would make the changes to the (relatively inexpensive) adapter rather than the mount on the fork.
Resetting your pistons may help to resolve this issue or you may have a sticky piston on one side that is causing this issue. Remove pads and use a piston press or a plastic coated cone spanner to push your pistons all of the way into the calliper, pull brake lever very lightly to see if both pistons are moving freely and equally (be very careful not to push pistons all of the way out). If not clean pistons with isopropyl using cotton buds, then with a cotton bud dipped in brake fluid smear around sides of piston. Hope this helps.
Likes For MUDCOWS:
Expired Member
Quoted: 3671 Post(s)
Liked 5,423 Times
Quoted: 446 Post(s)
Liked 1,044 Times
I'm wondering if this might be the solution? I notice as long as I don't tighten the bolts to the recommended spec, the calipers don't rub. If I file off a bit of the adapter bottom surface to be slightly angled it might actually align the brake calipers better without having to face the surface of the fork or do any mods to the brakes themselves.
Quoted: 446 Post(s)
Liked 1,044 Times
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Likes For tyrion:
Likes For tyrion:
Randomhead
Liked 3,696 Times
it's very common for flat mounts to be out of spec. I can't imagine it would be your adapter. You need to find a bike shop with the facing tool shown in the previous post. My lbs faces every flat mount bike that they sell.
Likes For unterhausen:
Quoted: 446 Post(s)
Liked 1,044 Times
I was just thinking, if I face the post mount adapter, I could file it at a slight angle to compensate misalignment without affecting the fork.
Quoted: 446 Post(s)
Liked 1,044 Times
I just called my LBS that does all my work, unfortunately they don't have that particular Park Tool facing tool. Any suggestions for doing the facing work myself?
Quoted: 1528 Post(s)
Liked 718 Times
Don't try to face the fork without the proper tool, it's too optimistic to eyeball the necessary tolerance for road disc.
Find a shop with the tool.
Quoted: 446 Post(s)
Liked 1,044 Times
Quick update. I found an LBS that will face the fork with the proper Park Tools facing tool and the procedure shouldn't cost more than $85 (or less). Though when I was talking to the mechanic he advised against the procedure recommending I just go with a flat mount disc caliper. So looking at my options, I could just buy a single mechanical TRP Spyre for $65, but for the cost I could spend a little more and get a pair of Shimano BR-RS305 flat disc brakes for $112 (no experience with those brakes). If I want to properly match my rear post TRP HY/RD caliper, I could get a pair of TRP HY/RD flat mount brakes with/rotors for $145. Unfortunately I cannot find those particular calipers sold individually.
I'm leaning towards just getting the TRP HY/RD pair, but I'd be open to other brake suggestions or just go with the flat mount facing. Thanks!
Liked 2,011 Times
Quoted: 446 Post(s)
Liked 1,044 Times
Second follow-up update! When I posted this issue a few days ago, I had ordered a third party post-flat adapter from Amazon, but I didn't think it would have resolved my alignment issue. Anyways, after posting my first update the part arrived 30 minutes later and I decided to install it. Amazingly, the new adapter appears to put the caliper closer into alignment (just barely though). I'm not sure if the Shimano adapter was perfectly in-spec or this no-name adapter just had more leeway for sloppiness. It appears to have resolved my rotor rubbing for now. Thanks for all the help!
My experience as a working mechanic is that out of spec flat mounts are pretty common. You'll only make things better getting the mounts faced accurately. Had to do this to an entire run of bikes for the floor.
