Solar panel on handlebar bag
Bikes: Custom built LHT & Troll
Quoted: 832 Post(s)
Liked 141 Times
I need very little energy to get my electronics going when touring (less than 1Wh/day). So I'll look into solar.
The plan would be to stick a small panel (2W? 4W?), perhaps as small as those found on garden lights, on top of my handlebar bag (Ortlieb Ultimate 6). I haven't figured this thing yet. As there could be expertise here : (1) I assume removable (velcro?), but perhaps a permanent panel is a better solution. (2) What's the best way to run the cable; (3) The usual recommendation is to charge a battery rather than a device such as a phone, to deal with current fluctuation. Does it apply even if the device is turned off? The plan would be to trickle charge my phone, set to off, and to recharge my watch from the phone when needed (4) Are all panels just the same (i.e. just a few manufacturers yet tons of retail brands). If not, which is best and why?
Quoted: 381 Post(s)
Liked 145 Times
Androids might work off. iPhones turn on when charging. All panels are not the same. In the wattage you want there is one some hikers like. You have to do your own research though.
https://www.amazon.com/Lixada-Portab...dp/B06Y655DJD/
mosquito rancher
Adam Rice
Adam Rice
Quoted: 1820 Post(s)
Liked 3,330 Times
maybe look into what solar panels are sold for backpacking.
This is an idea that has been around for decades, and the uninitiated eventually discover that they didn't account for the fact that solar panels need to be oriented at the proper angle towards the sun to get their rated output, the panel temperature needs to be cool, there can't be shade on the panel, the voltage of the device being charged needs to be matched to the panel's characteristics, and need to account for cloudy days and such.
There's got to be plenty of places on the web where this has been hashed out over and over (and possibly here).
Not saying it can't be done, but not as simply and economically as you might hope.
Steve in Peoria
Steve in Peoria
Quoted: 832 Post(s)
Liked 141 Times
Perhaps... but technology is rapidly progressing. My energy needs have been greatly reduced and solar panel technology now delivers more efficiently and cheaply. I'll try a couple of things and eventually report.
Likes For gauvins:
Quoted: 832 Post(s)
Liked 141 Times
Likes For gauvins:
Liked 3,330 Times
There must be some backpacking, or maybe bike packing, forums that have found the best options for this sort of thing. In any case, your search should be an interesting adventure!
I'll be looking forward to a report when you find something that works.
Steve in Peoria
Quoted: 3426 Post(s)
Liked 1,441 Times
I do some non-biking trips (kayak or canoe) of up to two weeks long without any form of resupply. Thus, my dynohub option does not work on those trips. And my backpacking trips always have re-supply after no more than six days.
I reassessed solar a few months ago after looking at what Happy Feet was doing. But in my reassessment, I concluded that carrying batteries (in my case mostly AA, not very much Li Ion) was less weight than the weight of solar. And if I am not searching out sunlight, the batteries were more convenient.
I just finished a week and a half long backpacking trip last week, that involved re-supply for food after no more than four day long segments, each resupply of food also included four more AA batteries for my GPS and headlamp, and camera batteries (Li Ion). My phone was either off or airplane mode except a few minutes per day, I carried three phone batteries (an LG phone that has user replaceable batteries), and never needed to change one.
A quick note on Li Ion batteries, if at all possible you should minimize using cold batteries. I learned on my Canadian Maritimes trip two years ago that using my phone for just a few minutes to get weather forecasts and check e-mail with a cold battery in the morning could consume 10 percent of my battery. After that I always warmed up my phone, either in sleeping bag or in a pocket under my down vest before I used it which greatly extended battery life.
I recently learned that my favorite AA and AAA batteries that were Ikea Ladda white NiMH rechargeables have been replaced with different models. I have plenty off the white ones, but I am no longer suggesting any particular brands for purchase, as I have no experience with their replacements.
At this thread if you start at post 53, you find a "conversation" between me and Happy Feet. There may be some useful info for you there.
https://www.bikeforums.net/touring/1...choices-3.html
For touring, I use a powerbank with 44 watt hour rating, that powerbank will work in pass through mode, meaning it can be charged simultaneously with being discharged to charge up a USB device. My powerbank is no longer made, the company makes bigger and smaller ones. They cost more than many others, but I am sold on them, brand is Voltaic. If you had their smaller one, you could go for a long time with cloudy sky if you were relying on solar.
https://voltaicsystems.com/battery-packs
Likes For Tourist in MSN:
If you decide on solar, get a small battery pack that does pass through charging. It'll "collect" whatever charge it can, while putting out a constant charge to your device. Some of them will do pass through wireless charging too (wirelessly charge a device while being charged).
I have one that I use with my Brompton w/Dyno hub.
