Cranksets that squash the bearings unless bolt is torqued perfectly & spacers…
Quoted: 1023 Post(s)
Liked 350 Times
are exactly perfect to permit both no play but also no binding of the bearings….
I’m referring to Cannondale Hollowgram cranks with BB30 bottom brackets. But I have seen but never tried other brands that do this. To my mind it is a frustrating system for someone like me who is trying to improvise my own road triple 30 mm axle Cannondale crank using an MTB 30 longer axle…
I thought I could mix and match spacers with my longer length axle and get the play out and still have free spinning but this does not appear to be in the cards for the build I am proposing…
Are there any definitive guides out there for outfitting 30mm cranks of different configurations? Do any of the makers of 30 mm bb axle cranks use opposing side bolts more like Shimano external bearing cranks use?
S*v* J*sus
SRAM cranks use a wavy washer for bearing preload, if that's what you're asking.
The Shimano "opposing side bolts" don't set the bearing preload - don't know what you're getting at here.
Likes For beanbag:
Liked 350 Times
I'm doing trial and error taking a MTB Cannondale Hollowgram axle and trying to make a road triple with some KCNC triple web-rings I got from E-bay. It looks like it should work but when I tighten the securing crank bolts it acts like they are just going to make the bearings bind. I think I will take this project to the Cannondale dealer and ask for their assist because the combo of this axle to this frame (standard English threaded with a "BSA 30 threaded" bottom bracket) is just not a proven combo.
:D
Liked 2,178 Times
this reminds me of the Force22 & associated BB30. It is a delicate design, & I wouldn't classify it as a reliable unit even if it was kept away from water, dirt, & lateral hits.
I'd try to find something that doesnt use a preload design. You need to measure twice for length to meet your needs, but once dialed in, it should yield fruitful end results.
-Oh Hey!
-Oh Hey!
I use wheels manufacturing thread together BBs with angular contact bearings with shimano grx cranks on my sram axs drivetrains. Those bearings take more preload force and still spin freely. They're not touchy to set up like most BBs.
S*v* J*sus
