Go Back  Bike Forums >
Bike Forums
Bicycle Mechanics
Gritty feeling while pedaling
Old 09-24-22, 05:01 PM
bg24
I recently got a wheel true on my back wheel and ever since there’s been a gritty feeling while pedaling in certain gears (the few hardest ones). I recently got a new bottom bracket so it’s not that, I took my pedals off and inspected them and they’re fine. I cleaned the chain and cassette to remove debris. The only thing I can think is that the wheel true messed up the chain alignment/gear alignment. I’m wondering if this is possible and if so what can I do to correct it?
bg24 is offline
Old 09-24-22, 05:13 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 1572 Post(s)
Liked 910 Times in 648 Posts
A wheel truing doesn't move the hub/cogs anywhere.
It moves the rim in relation to the hub.
Hold both crank arms and rotate back & forth an 1/8 turn (more if you can) and see if you can feel "anything".
Just because it's new doesn't mean it can't be bad, although unlikely.
You may be noticing a chordal action between certain cogs/rings.
Are to cogs you feel it on a multiple of the # teeth of the chain ring it's on? IOW, several matching Lowest Common Denominators.
48> 12, 16, 24..... etc.
Bill Kapaun is offline
Old 09-24-22, 06:00 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 3790 Post(s)
Liked 2,938 Times in 1,799 Posts
The moment awareness starts is not always when problems have begun.
Having said that I would confirm that the rear der adjustments are good because that is easy to do. The next aspect is that those harder cogs are getting worn enough for you to feel it but not enough to be a deal killer yet. Andy
AndrewRStewart
Andrew R Stewart is offline
Likes For Andrew R Stewart:
Old 09-24-22, 06:07 PM
streetsurfer
streetsurfer's Avatar
Bikes: ‘95 Le Tour, 80’s Nishiki Competition, Coda F900, Diamondback Response Trail, several schwinns-contis, suburban, letour lux, supersport? (repaint)
Quoted: 62 Post(s)
Liked 174 Times in 98 Posts
Gritty like wheels spun in hand when the cones are adjusted a bit tight?
streetsurfer is offline
Old 09-24-22, 06:11 PM
bg24
Interesting, I did also have my hub tightened as there was play in the wheel when locked in the dropouts. Could that be the cause?
bg24 is offline
Likes For bg24:
Old 09-24-22, 06:14 PM
Bill Kapaun
Overtightening the QR can lead to gritty feeling bearings.
The axle bends/compresses (take your pick and argue with yourself) when the QR is snugged down. The tighter it's snugged, the tighter the bearings get.
Back it off an 1/8th or so turn and see what happens.
I think the average user tends to tighten more than needed.
Likes For Bill Kapaun:
Old 09-24-22, 06:21 PM
bg24
Ok thanks, I’ll try that tomorrow.
bg24 is offline
Likes For bg24:
Old 09-24-22, 07:13 PM
sweeks
sweeks's Avatar
Quoted: 884 Post(s)
Liked 418 Times in 309 Posts
The gritty feeling caused by excessively tight bearings would be easily felt with the wheel off the bike and the axle turned by hand, but the bearings would have to be *super* tight for this to be felt while riding. I wonder if the QR alone is capable of this much compression.
And, not to pick the old scab, the axle compresses when the QR is tightened. This is not unreasonable, because steel is an elastic material. If the axle actually did bend, the metal on the outside of the bend would be stretched, and the metal on the inside would be compressed. This could actually be measured.
sweeks is offline
