different sized tires?
Old 08-26-10, 10:05 PM
zigmin
Butt-Nekid Wonder
zigmin's Avatar
Bikes: 93' bridgestone rb-1
Currently running a 700x25 front and 700x28 rear on my fixed gear, purely out of having no other tires/money to buy new ones . Anything wrong with this?
zigmin is offline
Old 08-26-10, 10:09 PM
Squirrelli
GONE~
Nope, it's all good.
This is interesting though:
Originally Posted by Sheldon Brown
Mixing/Matching Tires
Most bikes come with identical tires front and rear. This is all right for general use, but if you want to optimize your bike, you should consider using different tires front and rear. The front and rear tires have different loadings and different requirements.
  • Narrower Front, Wider Rear
    If lightness is the primary goal, tire width/weight is limited by the risk of pinch cut flats, a.k.a. "snake bites." Since there is more weight carried on the rear tire, you can get away with a slightly narrower tire in front than you can in back.
  • Wider Front, Narrower Rear
    A wider front tire makes sense in many applications, however, when handling and ride comfort are considered. A wider tire will generally provide better cornering traction than a narrower one, assuming appropriate inflation pressure. A wider tire also provides superior shock absorbency. I personally prefer a slightly wider tire in front, since I suffer from some wrist discomfort on occasion.
Squirrelli is offline
Old 08-26-10, 10:23 PM
CharneK
SpecialK
CharneK's Avatar
Bikes: 2007 SE Lager
Interesting indeed
CharneK is offline
Old 08-27-10, 12:40 AM
nathant53
I run a 26x1.35 in the front and 700cx28 in the back. But im gonna run both 700c x 28 soon.
nathant53 is offline
Old 08-27-10, 12:52 AM
Squirrelli
GONE~
You're getting a new wheel?
Old 08-27-10, 09:20 AM
devin3294
nubcake
devin3294's Avatar
Bikes: Surly Steamroller '10 53cm, Kink Gap bmx '09
thats just like on my bmx, i run 1.95 in the back and 2.125 in the front. although 20" of course
devin3294 is offline
Old 08-27-10, 09:31 AM
illdthedj
illdthedj's Avatar
Bikes: klein quantum, litespeed tuscany, bianchi pista concept, centurion comp ta, centurion super le mans, traitor ringleader
i run 700x32 up front (schwalbe durano) and 700x28 fyxation in back (although they run more like 32s)
yah nothing that wrong with having different sized tires up front or back, although 700x23s with 700x40 something would be awkward lol
illdthedj is offline
Old 08-27-10, 12:30 PM
xafofo
i've got a 27 inch wheel up front and 700x28 in the back.... its all good
xafofo is offline
Old 08-27-10, 01:14 PM
fuzz2050
Real Men Ride Ordinaries
fuzz2050's Avatar
Quoted: 16 Post(s)
Liked 3 Times in 3 Posts
I have a 26X2.25 in front, and a 26X1.25 in back. Nothing wrong with it, except that now my top tube slopes.
fuzz2050 is offline
Sahn
Bicycle Mechanics
17
03-23-19 01:25 PM
Wilk
Mountain Biking
16
09-18-12 08:54 PM
pdxtex
Road Cycling
22
04-07-12 05:47 PM
EdIsMe
Road Cycling
3
07-07-11 09:11 AM
gueuzeman
Touring
15
08-18-10 07:46 AM
