Help with replacing chainset for an old Viking
Old 07-13-11, 09:00 AM
bumcivilian
I've just bought an old Viking touring/racer, but one of the pedals has knackered the crank arm on the gear side (the pedal is hanging on but won't screw either in or out). I've been told as it's gear side I'll probably need to replace the chainset. However the bike place I took it to had no suitable cranks.
It needs a square tapered chainset, suitable for a 10 speed.
Looking around I found this https://www.wiggle.co.uk/miche-young-...=products#more
However I'm not sure how to be certain it'll be compatible. So, if anyone can tell me what specs I need to check and how to check them, or any other advice about finding suitable parts, or any advice in general it'd be greatly appreciated.
bumcivilian is offline
Old 07-13-11, 09:20 AM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1887 Post(s)
Liked 476 Times in 295 Posts
Can you show us a photo of the damaged crank? The odds are pretty fair that someone on the forum will have one. Also ebay is a good place to look for older (used) bike parts.
rhm is offline
Old 07-13-11, 09:48 AM
bumcivilian
Yeah I'll try to get a picture up soon as. Till then it's a SR-Sakae Ringyo Apex crank, if that helps anyone.
Old 07-13-11, 10:03 AM
rhm
multimodal commuter
rhm's Avatar
Which reminds me! If you're not familiar with the website www.velobase.com, you might want to take a look at it. I found this photo there:
Is that what you have?
I'm pretty sure I have one of those in my parts bin, or something like it. But I sense you're in a different part of the world than I, so shipping it would not make much sense.
rhm is offline
Old 07-13-11, 10:51 AM
bumcivilian
Yeah I was looking at that after finding it through google. I think mine is this one:
I'm in Manchester, UK, so postage would probably be a pain. If it is the right one, and you're up for it I'd be willing to pay for the convenience of not having to trawl the internet for something closer.
edit: don't think the image is working, here's the link https://velobase.com/ViewComponent.as...m=115&AbsPos=4
Old 07-13-11, 10:59 AM
rhm
multimodal commuter
rhm's Avatar
Aw, come on. The internet is your friend!
Look on ebay uk, see what turns up... such as:
https://cgi.ebay.co.uk/SR-Chainset-52...item35b39333ff
https://cgi.ebay.co.uk/Sugino-Maxy-fo...item35b38cdcd6
I'm away for the summer; can't check what I have until late August. You'll probably want to find something before then, no?
rhm is offline
Old 07-13-11, 11:15 AM
bumcivilian
Yeah I'll hopefully have something by then. I'm just not too sure about all the specs I need to look out for. How specific does the chainset need to be?
After spending today trawling forums I ended up quite confused and not too confident about just buying a new set - a lot of the stuff I've read seems to suggest I'll need something quite specific, but I'm not sure if that's just because those posts are relating to people who are looking to upgrade and improve. I'm just looking to make the bike rideable again.
Old 07-13-11, 11:45 AM
rhm
multimodal commuter
rhm's Avatar
Yes, those are good questions. For compatibility, there are not too many variables you have to worry about. I presume your old set has 40 or 42 tooth and 52 tooth chain rings, am I right? If so, if you get another chainset with a 52 tooth larger ring, then you won't have to move the front derailleur up or down, and you won't have to change the length of the chain. If you got one with a smaller front ring --48 teeth, for example-- you would have to move the front derailleur down, and you might want to shorten the chain a bit.
The square taper comes in two variants, and it is possible to get the wrong one. This mystifies me a bit, so I won't go into it.
Both chainsets and pedals come in either French or English threads. You probably have English (9/16").
If your chainset was exactly like the one in the photo above, then I'm pretty confident that Sugino Maxy chainset on ebay would be a perfect fit.
If yours has removable chain rings, like the one in the link you provided, then you also have to worry about the bolt circle diameter, BCD, unless your new chainset includes chain rings (as is common).
rhm is offline
Old 07-13-11, 12:10 PM
bumcivilian
You're right, mine is 40/52. The chain rings I think are fixed, but I'm not too sure. I may well just gamble on the Sugino Maxy you linked me to. I'm sure I'll be able to sell it on or use it otherwise if it doesn't work.
Thanks for all this, you've been a great help. I'll post back if I need more help, though hopefully I won't need to.
Old 07-13-11, 12:14 PM
rhm
multimodal commuter
rhm's Avatar
Yeah, let us know. Good luck!
rhm is offline
Old 07-13-11, 12:39 PM
bibliobob
bibliobob's Avatar
Bikes: '53/'54 Bianchi CDM, '62'62ish Altenburger Cinelli Mod B, '69 Rene Herse, '72 Motobecane Grand Record, '73-74 Colnago Super,, '74 Cinelli SC, '78 counterfeit Confente, '82 Medici Gran Turismo, '82 3Rensho SRA, '85 Eddy Merckx Pro
Quoted: 43 Post(s)
Liked 109 Times in 28 Posts
Photos please! We need to see some fine handiwork from Wolverhampton! A Viking is definitely on my list of bikes to acquire.
bibliobob is offline
Old 07-13-11, 01:24 PM
bumcivilian
Here's the photos of the crank, hopefully helpful. One of them shows the problem: the pedal has destroyed the thread inside the crank, and can no longer be properly screwed in or even removed.
There's also one of the full bike just for fun. Not great photos though I'm afraid. I lack a camera so it's clumsily done with my laptop...
Old 07-24-11, 05:06 PM
bumcivilian
Just to let anyone who's interested know, the guy I bought the bike from found a spare and sent it on, so it's all sorted. The bike's a lovely ride.
Thanks for all your help anyhow, nice to know the support and know how is there if I need it.
Old 07-24-11, 07:13 PM
LeicaLad
Quoted: 54 Post(s)
Liked 34 Times in 22 Posts
Hugh Thornton lives in Cheshire. He is building a web site for Viking bikes.
Contact him for any further pointers or help.
https://classicvikingcycles.com/
1959 Hilton Wrigley Connoisseur (my favorite!)
1963 Hetchins Mountain King
1971 Gitane Tour de France (original owner)
* 1971 Gitane Super Corsa (crashed)
* rebuilt as upright cruiser
1971 Gitane Super Corsa #2 (sweet replacement)
1980 Ritchey Road Touring (The Grail Bike)
1982 Tom Ritchey Everest
(replacing stolen 1981 TR Everest custom)
1982 Tom Ritchey McKinley (touring pickup truck)
1985 ALAN Record (Glued & Screwed. A gift.)
LeicaLad is offline
Wspsux
Singlespeed & Fixed Gear
8
05-20-14 08:51 PM
turbodrabbit
Classic & Vintage
9
06-12-13 09:37 AM
Jaymz
Bicycle Mechanics
10
09-16-11 06:51 PM
Vincent100
Classic & Vintage
9
12-26-10 07:50 AM
