help with replaceing wheel bearings in bontrager race-x lite hub
I have a race-x lite hub on a set of old zipp 500 wheels. I'm assuming the hubs are much newer than the rims. I have removed the freewheel but I can't figure out how to remove the wheel bearings themselves out of either the freewheel or axle. I just don't feel like randomly hitting with my large hammer just yet and I can't seem to find any manuels or links online that match this model.
Freewheel on
Freewheel off
Here is the non-drive side
Here's the freewheel
Freewheel on
Freewheel off
Senior member
Quoted: 883 Post(s)
Liked 503 Times
I've never serviced that particular hub, but I have dealt with a few similar. It's most likely the axle will have shoulders inside the bearing that will drive the bearing out with side impact. Use a hammer of softer material than the axle and hit on the drive side first. I would support the hub flange on the opposite side. ABS drain pipe couplers, available at better home building centers everywhere, work well for this.
Should not require herculean force to move it, but sometimes they stick pretty good. The bearing will be toast after removal.
ot.net slave
Bikes: Salsa mtb * 3, Intense mtb * 1, Abeni SS rd * 1, Salsa road/touring * 2, Trek Damn one * 1, Vintage/projects * many
That's a rebadged DT Swiss 240 hub (or 340, the instructions would be the same) look for bearing replacement DT 240. This forum will probably not have many hits, use Google.
- Joel
- Joel
Spaghetti Legs
Classic & Vintage
11
07-29-19 10:59 AM
MrCjolsen
Bicycle Mechanics
2
07-07-10 09:38 AM
