23 vs 25 tires on 15c rim
Old 12-09-16, 11:10 AM
spectastic
commu*ist spy
spectastic's Avatar
Bikes: a few
Quoted: 649 Post(s)
Liked 3 Times in 3 Posts
provided optimal pressure on both tires, i'm pretty sure that 25 mm will provide slightly lower rolling resistance, better comfort, better pinch flat resistance, and wider contact patch for traction, while the 23 mm tire will have slightly better aerodynamics.
however, which combination will provide better handling and why?
spectastic is offline
Old 12-09-16, 11:17 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,322 Times in 832 Posts
15cm? That's like 6"..
fietsbob is offline
Old 12-09-16, 11:19 AM
Leebo
Bikes: Kona Dawg, Surly 1x1, Karate Monkey, Rockhopper, Crosscheck , Burley Runabout,
Quoted: 854 Post(s)
Liked 109 Times in 64 Posts
2 mm is the thickness of a dime, no measurable difference.
Leebo is offline
Old 12-09-16, 11:21 AM
fietsbob
Bikes: 8
More a question of how expensive a tire you are willing to buy..
fietsbob is offline
Old 12-09-16, 11:25 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 3011 Post(s)
Liked 1,336 Times in 934 Posts
Any differences will be rather minor with only 2mm separating the tire widths. Having said that the human body is pretty good at picking up on slight differences. And the human mind is great at taking that perception and making a big deal over it. Andy.
Andrew R Stewart is offline
Old 12-09-16, 11:36 AM
spectastic
commu*ist spy
spectastic's Avatar
Bikes: a few
Quoted: 649 Post(s)
2 extra mm on a 23 wide tire means 18% more air volume. that's not trivial.
15c as in 15mm inner rim width.
Likes For spectastic:
Old 12-09-16, 11:37 AM
bradtx
Bikes: Cannondale, Trek, Raleigh, Santana
Quoted: 306 Post(s)
spectastic, I think I can give a fairly close apples to apples comparison. Real world difference is nil.
-Bike is a CAAD3 Cannondale
-Rims with Continental 23 mm tires are CXP22
-Rims with Continental 25 mm tires are CXP23
Brad
bradtx is offline
Old 12-09-16, 11:44 AM
bradtx
Quoted: 306 Post(s)
True, which means that the 25 mm tire can run with slightly less air pressure, but whether I ran the same air pressure in my example, or 5 PSI less in the 25 mm tires I just couldn't detect a real difference in handling.
Brad
bradtx is offline
Old 12-09-16, 12:12 PM
TimothyH
- Soli Deo Gloria -
Quoted: 6837 Post(s)
Liked 702 Times in 447 Posts
Please define "better handling". G-force during cornering near the limit of adhesion? Threshold braking distance in the wet? "Better handling" is a broad concept and ambiguous in and of itself. You need to be more specific. It has to be measurable.
All things being equal, a tire with a larger contact patch will provide more mechanical grip. You summarized this well when you said...
-Tim-
TimothyH is offline
Old 12-09-16, 12:14 PM
fietsbob
Bikes: 8
Winter is the time for Recreational Speculation..
fietsbob is offline
Old 12-09-16, 01:09 PM
bulldog1935
Bikes: '74 Raleigh International utility; '98 Moser Forma road; '92 Viner Pro CX upright
Quoted: 939 Post(s)
Liked 4 Times in 4 Posts
more rubber on the pavement provides better handling.
Nobody is brave enough to chase me around turns on my 38mm Barlows.
bulldog1935 is offline
Old 12-09-16, 02:32 PM
Leebo
Quoted: 854 Post(s)
My 60 mm geax tattoos provide scary side grip through turns, Almost to super sport cornering. ( in my mind)
Leebo is offline
Old 12-09-16, 02:38 PM
Bike Gremlin
Mostly harmless ™
Bike Gremlin's Avatar
Bikes: Custom made on Scott Speedster frame, Custom made on a 1996. steel MTB frame (all but frame changed at least once in the past 20 years).
Quoted: 994 Post(s)
Liked 46 Times in 31 Posts
Big difference in air volume = comfort.
Bike Gremlin is offline
Old 12-09-16, 02:39 PM
noglider
noglider's Avatar
Quoted: 6909 Post(s)
Liked 1,566 Times in 991 Posts
'c' is not a unit of measurement. The 'c' in 700c refers to a series, where 700a, 700b, 700c, and 700d are different diameters (not widths) of wheels that are close in size.
It's unfortunate that people refer to tires with terms like 700x28c. It's really 700c by 28mm.
noglider is offline
Old 12-09-16, 02:43 PM
Bezalel
Bikes: Raleigh Companion, Nashbar Touring, Novara DiVano, Trek FX 7.1, Giant Upland
Quoted: 19 Post(s)
Contact patch size is a function or weight and pressure. At equal pressure a 23mm and 25mm tire will have the same size contact patch.
If your bike frame uses thicker tubes than 25mm, you're not getting much more aerodynamic with 23mm tires.
Lower rolling resistance and comfort are both based of tire deflection. You can't get better on both counts just by changing tire size.
Pinch flats shouldn't be a concern with properly inflated high pressure tires.
Bezalel is offline
Old 12-09-16, 02:45 PM
Leebo
Quoted: 854 Post(s)
Ugg, just go pedal. Sure there is a difference. Measure the difference in rolling resistance and the increase in contact patch. As well as the aero difference and get back to me. Make a chart, what ev.
Leebo is offline
Old 12-09-16, 02:52 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2690 Post(s)
Liked 1,401 Times in 871 Posts
I agree, but it's a losing battle when even the tire companies mark their tires as 700 x 28C, etc.
JohnDThompson is offline
Old 12-09-16, 03:05 PM
bulldog1935
Quoted: 939 Post(s)
it's one of those pet peeves that's never worth arguing...(and yes, shared by me, as well)
the consolation is when it's your turn, you can do it your way
Old 12-09-16, 03:32 PM
noglider
noglider's Avatar
Well put. I wasn't looking to argue, though. I was looking to tell someone who I'm sure didn't know and also was not looking for an argument.
noglider is offline
Old 12-09-16, 04:09 PM
spectastic
commu*ist spy
spectastic's Avatar
Bikes: a few
Quoted: 649 Post(s)
fwiw, tire width is not so critical in aerodynamics so much as the junction between the tire and the rim. a bigger delta between the rim width and the tire width, the less the cross section resembles a tear drop, the greater the turbulence, leading to greater drag. it has absolutely nothing to do with down tube width, but rather about the streamline
Old 12-09-16, 05:47 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 3931 Post(s)
Liked 971 Times in 651 Posts
I've always tried to figure out my Vittoria 37-622 tires that also labelled 700x35
Sy Reene is offline
Old 12-09-16, 06:19 PM
Andrew R Stewart
While I recognize air volume is a factor I'm just not sure how much it is compared to the % that is above the rim's outer edge.
I come from riding slightly wider sew ups (23/24mm usually) the common for close to 30 years. During this period the clinchers I rode were 30mm+ wide. I noticed that the sew ups had better pinch flat resistance even with their narrower spec. But the amount of air above the rim's edge is greater with the narrower sew up then with the wider clinchers. (The thinner casing and tube helped the smoothness too)
So, back to this thread's topic, I view this discussion through the amount of added air that's above the rim, not the total volume. Call me two dimensional (and making bad puns) but I think the height of the tire has a large factor to real life, everything else being the same. IIRC the 2mm of width is usually about 1mm in height, difference wise. So I see 4% of difference between a 23 and a 25mm tire on the same rim. Not too much.
Having said that I would choose the 25mm tire every time, over the 23mm one. Andy.
Old 12-09-16, 06:23 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
+1.. That 4-10% spatial distance difference has meant a lot less flatting and a more comfortable ride. I have no idea whether my speed/watt impact was positively or negatively impacted, but if it was, it it was miniscule.
Sy Reene is offline
Old 12-09-16, 06:38 PM
SquidPuppet
Calamari Marionette Ph.D
SquidPuppet's Avatar
Bikes: 3 Chinese Gas Pipe Nerdcycles and 2 Chicago Electroforged Boat Anchors
Quoted: 2356 Post(s)
Liked 21 Times in 18 Posts
I would pass you on 35mm Kojaks.
The supple carcass of the Compass tire sucks up bumps like there's no tomorrow, but that tread pattern significantly reduces cornering and braking grip. I have both types of tires and there's no comparison.
SquidPuppet is offline
Old 12-09-16, 06:43 PM
bulldog1935
Quoted: 939 Post(s)
this isn't exactly true.
Drag is coefficient of friction times frontal area (that's why it's the coefficient of friction).
You do lower the coefficient by having a smooth teardrop-shaped transition, but the frontal area is simply the width times the height.
