Inner tube question for foldie tyres.
Old 01-08-22, 02:43 AM
Ev0lutionz
Quoted: 66 Post(s)
Liked 8 Times in 5 Posts
I'm using Schwalbe Marathons, sizing 16 x 1.35, and it says 35-349 also on the tyre wall. Question,
I've seen some inner tubes on Aliexpress saying 16 x 1 -3/8 ? What does this mean?
Also will these inner tubes fit my tyres too? 16x1.25/1.5 with a Schrader valve.
Ev0lutionz is offline
Old 01-08-22, 07:11 AM
djb
Quoted: 2317 Post(s)
Liked 675 Times in 570 Posts
35-349 means the tire is 35mm wide, 349 is the #in mms of the wheel / rim diameter.
for tubes, convert the imperial numbers you mention, 1 inch and 3/8 inches to mm to see how close this is to 35mm
imperial is inches, miles
metric is mm, kms
djb is offline
Likes For djb:
Old 01-08-22, 07:52 AM
andrewclaus
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 530 Post(s)
Liked 341 Times in 236 Posts
For tubes, that's close enough. For replacing the tire, though, beware. There are other nominal 16" tires that won't work. For instance, if the tire is listed with a decimal inch size, like 16 x 1.75, it will not fit your rim. See Sheldon Brown's site for a tire size chart. Don't get your hopes up though, it will only become more confusing.
andrewclaus is offline
Likes For andrewclaus:
Old 01-08-22, 08:34 AM
Ev0lutionz
Quoted: 66 Post(s)
Agree, with all the tyre standards, im getting lost haha. Thankfully my main commuter bike that I use only has 700c tyres which are easy enough for me to get replacement tubes..
Old 01-08-22, 09:21 AM
tcs
Palmer
tcs's Avatar
Bikes: 1980 Mike Melton, 1982 Stumpjumper, 1982 Santana, 1984 Alex Moulton AM, 2008 BikeFriday tikit T-♾, 2010 Dawes Briercliffe, 2017 Dahon Curl i8, 2019 Surly ˝DT14, 2021 Motobecane Turino 1x12
Quoted: 1042 Post(s)
Liked 643 Times in 394 Posts
It means the tube is either for an ISO35x349mm tire or an ISO35x305mm tire. If it's for a 305, it's going to be tight around your 349 rim.
tcs is offline
Old 01-08-22, 11:10 AM
KerryIrons
Quoted: 86 Post(s)
Liked 117 Times in 65 Posts
Agree, with all the tyre standards, im getting lost haha..
Nothing to be lost about. The numbers on the tire sidewall need to match. So any tire with a 349 on the sidewall will work. Any other number will not work. Simple as that. Tubes are MUCH more flexible in application. You want a tube smaller than the tire width - tubes easily expand when pumped. But per other comments, you don't want one that's too tight on the rim, or loose and floppy on the rim because they will result in a fold in the tube inside the tire and that will eventually rub a hole in the tube.
KerryIrons is offline
