Attempting my first headset bearings maintenance
Hi All
I took my road bike (aethos pro) out while the roads were still wet and now the steering feels sandy and I hear a whooshing noise when I turn the handlebars.
I am going to attempt to service the headset and re apply some grease. Is it as simple as this
makes it sound. Also and tips on how to perform this without a repair stand?
Quoted: 6178 Post(s)
Liked 4,795 Times
Is this your first rodeo?
Quoted: 5223 Post(s)
Liked 3,579 Times
when I swapped the fork on my MTB I was in there, of course. it wasn't too bad. take your time
it was a bit of a juggling act, w/ all the spacers & the bars & the cables, etc. be sure the floor is clean in case you drop anything. might be nice to have a table nearby in case you want to put something down
Just Pedaling
Bikes: YEP!
Quoted: 328 Post(s)
Liked 516 Times
Hi All
I am going to attempt to service the headset and re apply some grease. Is it as simple as this this video makes it sound. Also and tips on how to perform this without a repair stand?
Quoted: 1943 Post(s)
Liked 2,164 Times
I have some old toe clip straps, but any strap will work, and use them to support the handlebars and fork and not the brake cable, of worse yet a hydraulic brake hose.
John
John
Likes For 70sSanO:
Quoted: 836 Post(s)
Liked 1,059 Times
Also take a photo of your brake and shift cable routings around the front of the head tube before taking everything apart if you think you may forget how they go. Same with stem spacers, bearing orientation etc.
Likes For Crankycrank:
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Yes. As others have stated, get all the surfaces the bearing cartridges will touch very clean before installing the new bearing cartridges. And if you haven’t taken a treadless stem off before, when reinstalling make sure to tighten down the cap before tighten the pinch bolts for the stem that hold it to the steerer. It can be a bit awkward, but it is not hard to do. Good luck.
