Another "I wish they'd make" concept
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 967 Post(s)
Liked 615 Times
Recently I was following a thread and there was a picture of a side-pull caliper, perhaps Grand Compe, I cannot remember; but the finger-grip O-ring on the adjusting barrel was brown, not like black on Campy, etc. Hmm, I wonder if there would be a market for these in colors to accent the bike and perhaps match handlebar tape, cable housing, etc. Gum? Red, yellow, blue? Whatever? Celeste? Sounds like a frivolous thing, but I wonder if production costs might be low enough that there would be profit even at $5/pair.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 3191 Post(s)
Liked 2,460 Times
Not for me. That's getting too matchy matchy for my tastes.
Suntour tried that with their X-1 Chroma group.
https://velobase.com/ViewGroup.aspx?...e-d3092e921084
Likes For seypat:
Quoted: 559 Post(s)
Liked 1,032 Times
There is someone - I can’t remember the sellers name - that is offering exactly these o-rings in a variety of colors. As I recall, they’re $5-8/pair. I’ll dig for a link….
Likes For RustyJames:
Quoted: 3430 Post(s)
Liked 2,824 Times
BF member jamesdak turned me on to these from bikecyclery, as linked above. They come two to a pack. Very high quality. I got white ones for my Dura Ace brakes.
And for the record, I have no problem with matchy-matchy: White tape, saddle, cable housing, toe straps and bottle cages.
Stop reading my posts!
Quoted: 1421 Post(s)
Liked 1,038 Times
if you can find the post where someone shared the number for "pretty damn close" matching o-rings sold in plumbing supply shops for about 79 cents, IIRC you can usually find such plumbing parts in either "buna-N black" or brick red...the colors plumbers like best.
Liked 2,824 Times
Likes For smd4:
Quoted: 967 Post(s)
Liked 615 Times
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4311 Post(s)
Liked 2,954 Times
OK, now that that's settled - here's something I used to want to invent: a fixed gear hub with a device to switch to freewheel. Something like an internal gear that could lock or unlock with the pull of a lever or similar. So people could experience fixed gear riding, and still have the option to turn it off - like maybe when you're in tight spaces or a lot of traffic or something. Also you wouldn't have to take a flip-flop wheel out and get dirty and everything, which is fine for once in a while, but not in the middle of a ride.
Originally I thought this would be a good idea because I hadn't ridden FG enough to be comfortable with the idea, now I think it'd be a good idea for other people, but I don't need it. Anyway, seems like it would be an easy option to offer on SS bikes.
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
So maybe a clutch that forces the drivetrain to come up to speed more gradually (at the expense of never being 100% locked in), or perhaps the control could only pull the linkage out of engagement at speed, so you could select coasting if a downhill is coming, but only put it back into fixed mode at a stop...
RUSA #7498
Quoted: 967 Post(s)
Liked 615 Times
I wonder if all older pedals that could accept toe clips had the same c-to-c distance on the holes where the toe clips attach. Someone could make a casting that attached there, and incorporated a SPD-style clamp; I have quite a few pairs of Campy Superleggera pedals, road & track, that I wouldn't mind into making into SPD pedals. Same for old MKS, DuraAce, whatever.
Likes For tiger1964:
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 385 Post(s)
Liked 689 Times
Hmm, perhaps a clearinghouse of ideas and someone might decide worthwhile to make...
An attachment that does what you suggest would require a very strong connection to the pedal in order to withstand the twisting force when releasing SPD restraints.
On the hole alignment idea, I wonder if it can be solved using a short length of aluminium bar stock with a few holes drilled at compatible positions...
SE Wis
Quoted: 2731 Post(s)
Liked 3,361 Times
Likes For dedhed:
Liked 1,038 Times
I don't have a Campy adjuster handy, but one I'm looking for is a brown ring for a SunTour Superbe adjuster.
That "bead" place in MD has a "dark chocolate brown" model in 15mmOD/10mm ID that's not the right brown, but might be close enough.
and 10mm may be a little loose but a little glue might solve that
Also they have a thinner 14mmOD that MIGHT work with Modolo adjusters, not sure, also has 10mm ID and comes in black only (fine for Modolos).
blahblahblah chrome moly
Quoted: 1162 Post(s)
Liked 2,542 Times
whoa! Colors (and sizes) I never imagined! Thanks for posting th links!
See how the "flying saucer" shape of the adjuster nut fits inside the U-section? Very different from Campy et al. Seems like a dumb design feature, but whatcha gonna do?
I'm no expert on finding generic industrial parts, but it seems unlikely to me you'll find anything to fit, other than a real Superb bumper.
If you need Modolo Professional, Wayne Bingham at Velo Classique in Virginia has them. Not just the rubber bumper, I mean the whole adjuster screw and nut with bumper, sold in pairs only, not cheap.
Mark B
Likes For bulgie:
Liked 2,560 Times
The "Pro Star" brakes on my '88 Bianchi have those rubber pieces on them. They look like a grommet that's inverted from normal, but I haven't found the magic words for Google either.
I suspect that this rubber piece gives a lot more grip to the brake adjuster than just an O-ring riding in a channel.
Quoted: 967 Post(s)
Liked 615 Times
I visualize a Dremel -- and a lot of anguish -- in the future dealing with that.
Liked 2,542 Times
Prolly easier to just buy new ones. Here's a pair on ebay, used and slightly scuffed but plenty OK in my book, $48 with shipping. Just the first ones I found — a longer search might yield a better deal.
The NOS Modolos I bought from Velo Classique recently were less $$ than that, quite reasonable actually, for unobtainium.
Mark B
Quoted: 967 Post(s)
Liked 615 Times
Hmm, making that inside channel in soft plastic/rubber? Maybe it you're a lot better then me with a Dremel. Also you can't make the Superb shape really by removing material from an O-ring. Like you can't make a U by cutting the top off an O, if you see what I mean. Although the DIY part might be 100% functional, it'll look a bit different (if you care) Prolly easier to just buy new ones. Here's a pair on ebay, used and slightly scuffed but plenty OK in my book, $48 with shipping. Just the first ones I found — a longer search might yield a better deal. The NOS Modolos I bought from Velo Classique recently were less $$ than that, quite reasonable actually, for unobtainium.
And of course it occurred to me last night that while I have one bike with Campy brakes, the other with side pulls is indeed Suntour Superbe... yup, it looks like I have the same problem as pictured.
Quoted: 359 Post(s)
Liked 581 Times
