Addiction 2021.4
#5126
Quoted: 10234 Post(s)
Liked 5,178 Times
Thanks I was concerned. I didn’t go as far as you but I re torqued the front end. It go better but still does it when I go hard.
#5127
Bikes: Shmikes
Quoted: 10148 Post(s)
Liked 5,841 Times
thank you this is what I have been looking for. I kept trying to do zone 2 rides and ended up climbing. I was looking at distance and elevation. And all of the longer routes have elevation, so I was trying to pick the one with the most distance and least elevation.
As soon as I would start on elevation my heart rate would spike.
#5128
Liked 5,178 Times
Depending on your tolerance for boredom, you can create a Z2 ride in Zwift using the custom workout builder and do it wherever you want. You just go uphill very slowly. I have one which varies the power every few minutes but stays within Z2. It's so awful, I generally just watch a movie instead of the game.
So you have it in erg mode then? I will take a look, thanks for the tip.
Likes For mvnsnd:
#5131
Bikes: Factor O2, Caad10, Caad2
Quoted: 365 Post(s)
Liked 122 Times
#5132
Bikes: Shmikes
Liked 5,841 Times
#5133
Liked 5,178 Times
I was a little all over the place on the beginning. It would say hold 220 and I would go past that and then below that. I didn’t do a good job til near the end.
I can always do another one with zwift in full control and erg mode on. That might be more accurate.
#5134
Liked 5,178 Times
#5135
Administrator
Quoted: 11952 Post(s)
Liked 6,604 Times
If I have to choose between Cholesterol or Sugar as to which one to work to eliminate from my diet, I will eliminate sugar every time. Big Sugar has done a great job pointing the finger at fat as the source of American obesity, but fat is an essential component of a healthy diet and does WAY more good than harm.
The human body actually manufactures cholesterol for its needs. Among many other things, it is essential for hormone production. All hormones. As well, the brain is composed of 70% fat, the essential coating of the neural pathways. We'd be dysfunctional idiots without it.
Needless to say, moderation of fat intake is the key. But by comparison, processed, added sugars are almost always harmful. #thedebil
#5136
So it is
Quoted: 11393 Post(s)
Liked 4,731 Times
#5137
Quoted: 20808 Post(s)
Liked 9,450 Times
ERG is obviously a value to many but, at the same time (and as someone that's new to power), I think that it would be of value to you to at least mix in some non-ERG workouts to get a better feel for pacing yourself and riding smoothly. ERG, unfortunately, doesn't step in for you on the roads.
#5138
Quoted: 9648 Post(s)
Liked 6,363 Times
Likes For Mojo31:
#5139
Liked 5,178 Times
I'm not sure about the ramp test, but the standard tests are with ERG disabled, at least for the FTP proxy effort.
Makes sense. I just did a zone 2 ride no erg and no climbing. All the numbers looks like how it would be on the road. Glad that finally worked.
#5140
Administrator
Liked 6,604 Times
You had some good cholesterol numbers from what I could see. My total cholesterol is always on the borderline of the acceptable range, but my HDL is good. It’s my glucose levels I keep an eye on, I want no part of that big D.
#5141
VFL For Life
Bikes: Velo Volmobile
Quoted: 28577 Post(s)
Liked 1,849 Times
#5142
Administrator
Liked 6,604 Times
Gimme chocolate, dark chocolate. And of course cheesecake.
#5143
Administrator
Liked 6,604 Times
wut. The woman? I’m pretty sure Mrs BD will not approve.
Likes For BillyD:
#5144
Liked 6,363 Times
#5145
VFL For Life
Liked 1,849 Times
#5146
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,856 Times
so I did do the ramp test, the first day. I had it connected to both my garmin head unit and zwift. What I didn’t know is that the garmin head unit took charge of the wahoo and zwift was in standby.
So what I mean by that, my rider moved in zwift but the resistance stayed the same on hills and flat ground.
The garmin unit had it set to 1 percent resistance.
Anyways at the end of the ramp test it bumped my ftp to 230.
SO, if you did the Ramp Test without Erg Mode, you'd just have to keep shifting gears to increase resistance, just like with a dumb trainer, but your trainer would be providing Zwift with your power output.
The other thing is that you can also change how closely the trainer tries to match the terrain. It's under "Settings" on Zwift. You have to be In Game, in a world. Click Menu, then Settings. Default for Trainer Difficulty = 50%, so it will mimic a 3% gradient when you're climbing a 6% gradient in the game. I generally run it at 100%, since I'm trying to mimic riding in the real world, but if I were to try Alpe du Zwift, I'd probably cut it to 50% the first time.
Two things about Trainer Difficulty - First, even set to 0%, so everything seems flat, your speed In Game is STILL determined by power output, gradient, weight, and aero profile, so if at 0% Trainer Difficulty on a 15% gradient, you might be spinning easy, putting out 150W, and feeling like you're on the flat, but you'll probably be going 2 mph.
Second, on descents, Zwift only mimics HALF of the descending gradient. So a 6% descent is really only 3%, at 100% Trainer Difficulty, and at 50% it would only be 1.5%.
#5147
Should Be More Popular
Quoted: 22573 Post(s)
Liked 8,918 Times
Likes For datlas:
#5148
Liked 11,856 Times
My view is that sugar, starch - carbs generally - are fuel. Just fuel. If you're burning energy, you need fuel. If not, you don't. Fat is also fuel, but slower burning - though more energetic per gram. Important to remember that your brain only runs on glucose - part of why one feels so stupid when bonking.
#5149
Liked 11,856 Times
#5150
Mostly Harmless
Bikes: Have two wheels
Quoted: 13694 Post(s)
Liked 4,520 Times
Likes For rjones28:
