Aerobic Cruiser hybrid recumbent ebike
Bikes: Schwinn Jaguar(Cruiser), Bianchi Sport+Comp (700c), Aerobic Cruiser, Giant LaFree, Tidal Force S-750 (Pedal Only)
This is probably the first recumbent designed to be an ebike and with the manufacturer looking to clear some inventory is currently a good deal on a new ebike.
I had been looking at recumbents for a few years and more recently electric bikes. Have even ridden a couple of home built ebikes done by Christofer Parham. Be warned... riding one of his modded ebikes can be a grin inducing addiction.
My main reason for considering the Aerobic Cruiser (AC for short) was the desire to be able to ebike my 43 mile commute and not need a shower or massage therapy afterwards. I have been riding my regular bikes the few miles to catch the commuter bus for about five years and grew up riding around the rural roads of the Carolina's. However, going over 20 miles in business casual clothes on a pedal only bike was more than I dared tackle at forty something especially in Atlanta summer heat. Although this past summer it was more like Seattle weather than Hot'lanta.
Anyway, I wanted an ebike and had long been curious about recumbents. So I took the $$$ plunge after visiting the AC facility in Cordova, TN and taking a test ride. Plus I saved on shipping by renting a van and hauling it home myself. Bike was purchased on Saturday 10 August 2013.
Will update with my experiences.
UPDATE –I have put 136 miles total on the AC and charged the pack twice. It was fully charged when I picked it up at the Aerobic Cruiser facility in Cordova, TN. The single biggest chunk of those miles were put on Sunday when I did a test ride from home to the office and back. Was a 43 mile round trip that started with a full charge and a reset on the Cycle Analyst.
DATA for that trip shows:
40.1 volts -starting voltage approximately 12 hours after the charge completed
42.99 miles
17.952 Ah
690.16 Watt Hours
16.0 Watt Hours per Mile
32.15 Amps Max
37.6 Volts minimum
38.9 mph Max Speed (gravity is my friend and my enemy depending on which side of the hill I’m on)
17.9 mph Avg Speed
2 hours 24 minutes 00 seconds (2:24:00)
39.2 volts -Ending voltage when I stopped in my driveway. The voltage bounced up a bit after resting but I failed to write it down before I charged the pack back up.
THE BIKE
Tires where at 54psi front and 56psi rear. I did not weigh the bike before the ride but it was loaded and I was dressed for the trip much like I would be when going to the office. So I had my laptop bag bungeed on top of the tail bag and the tail bag was loaded with the charger, some tools, logbook and other miscellaneous items. Of course I also had a water bottle, keys, phone and wallet. What I DID NOT have was the locks I bought and still have to figure out the mounting for on the bike. A previous weighing on my old bathroom scale showed 42lbs front and 58lbs rear with charger in the tailbag.
THE ROUTE
For the curious who like to look at maps you can see the route here (minus the first and last mile or so) https://veloroutes.org/bikemaps/?route=105504
The elevation image is more dramatic on the trail portion than I would have thought but seems about right for the road portion. On the ride to the office the first half of it is on the Silver Comet trail from around mile 11 to the trail head near Vinnings / Smyrna, GA. From there the ride turns down Atlanta Rd (going southeast) from where it meets Cumberland Pkwy/East West Connector down to the Chattahoochee river and ends near the MARTA headquarters at the Lindbergh station just off Piedmont Rd in Atlanta. I took the same route both ways.
TME
I started at 11:48AM Eastern time and was back at the house by 3:30PM. Had a snack at the midpoint and stopped by both LBS that are along the way.
Plugs for the LBS’s (is that okay?) The Silver Comet Depot (silvercometdepot.com ) is right on the trail around mile 5 or 6 at Floyd Rd and Smyrna Bicycles is in a small strip of stores on Camp Highland Rd near the trailhead. Smyrna Bicycles does have an ebike by GIANT for rent but almost no takers.
Have not been over to my LBS in Powder Springs since they moved to their new location near the Florence Rd / Silver Comet intersection around mile 13 but, Hamlet is a good guy so I want to give them a plug as well.
NOTE: I HAVE NO FINANCIAL INTERST AND RECEIVE NO COMPENSATION FROM ANY OF THE LOCAL BIKE SHOPS MENTIONED
MY EFFORT
The ride was done with moderate to moderately hard pedaling under beautiful weather. I found I was adding from 1 to 3 mph to whatever the motor only speed was when on the Silver Comet Trail. On the road section the hills that would boost my max speed over 38mph on the return trip I was able to climb on the way to the office at 11mph at the top with full throttle and 1st gear pedaling. My max speed on the way in was a little over 34 mph on the same route. I did feel like I was able to add some pedaling assistance to gravity even at 35 mph plus. The motor assist is speed limited in the controller to 20mph but makes it a lot easier to maintain that plus a bit more with pedaling. Of course the motor also makes the uphill parts much easier. Got to love the gearing on those downhill sections from the 67 tooth front sprocket to Nexus 3 speed IGH as a mid-mounted transmission with 21 teeth in and 21 teeth out to a 20 tooth sprocket on the hub motor for the rear chain. If someone wants to calculate out the chain inches for all that feel free to post it.
THE WEATHER (PERFECT)
Temp in the low 70 degree Fahrenheit range with about 50% humidity a 7 MPH breeze and sunny skies until the last few miles when it clouded up.
THE RIDE AND OTHER THOUGHTS
The trail was busy as you might expect on such a beautiful day which means paying extra attention, especially around kids and unsteady riders of any age. Several of the under 6 crowd pointed at the AC and commented with great enthusiasm. Also had a few other positive comments and conversations from riders and walkers. The bike definitely gets noticed as recumbents are still a minority of the bikes out there and this one is a bit different than the others on top of that. There were also a lot of walkers/joggers on the trail who I always try to give plenty of room; especially when they have earbuds blocking out the sounds around them. Traffic on the roads was light but the twin mirrors the bike comes with makes it easier to keep on eye on approaching vehicles. Of course the other big hazard is vehicles turning directly across your travel path. So I also had the Cat-eye reflector lights going front and rear. While I have additional lighting on my bag for the rear, a better headlight for the front is on order. The only glitches I had with the bike was one self-induced but scary moment when the cranks felt like they had locked up. The motor was still able to power the bike along. Luckily the issue was caused by my having moved the twist-shift part way between 2nd and 3rd gear and that had caused the Nexus 3 speed IGH used as a transmission to bind up.until I moved the shifter into a proper selection. I did that one other time shortly after I got the bike.
The other glitch was when the rear chain jumped off on the return trip home. It happened near the start of the Silver Comet trail just after the downhill section from Smyrna Bicycles but before you get to the Mavell Road parking area. I was able to slip it back on, wipe my hands on a rag I had brought along and pedaled / motored along without problem the remaining 11 miles home. It did re-enforce that I need to put a better chain guide / tensioner on the rear chain. Even though my redneck retrofit tensioner made out of a section of 4 inch pvc pipe has been working ok for the last 90 miles or so; at least until this happened. I already have an idea to use an old derailleur cut down to act as a guide/tensioner based on some of the DIY examples I have seen on single speed setups. I have thought about using a half link and shortening it up and even adjusting the position of the motor/axle. I may still do the half link but want to keep the motor firmly buried at the full depth of the rear fork dropouts to minimize any chances of axle spinout. I did check and tighten up both axle nuts just a bit before this ride. Probably over torqued them just a bit but better that than a little under torqued. As a side note the drop outs measure 0.375 inches wide using my dial-caliper. Except for those two instances the bike performed wonderfully. My legs where tired the next day and would not have wanted to tackle the ride again but, I finished up my afternoon at the house climbing up and down a ladder to clean gutters and removing dead tree limbs that were hanging over the deck. I had previously noticed that riding this recumbent style bike does work some different muscles than a regular diamond frame (DF) bike and that was re-enforced the next day. There was some mild soreness in the hamstrings and glutes but just enough to let me know I had done a bit more than usual. If I had tried this on a non-ebike I probably would have had to come home and flop on the couch for the rest of the day and then not been able to walk the next day. At fortysomething I don’t bounce back like I used to. One of the reasons I selected this bike was the desire to have a big enough battery pack to do my commute without needing to charge at work because I do not have a place I can charge on the bike without risking the charger going missing. If you go by the information given on the Aerobic Cruiser web site. the 690 Watt Hours used would be 69% of the 1,000 Watt hours claimed for the battery pack. So this means I can do my commute with a little less effort and still stay below the 80% Depth of Discharge (DoD) that is supposed to help the LiFePo4 pack live longer. I believe the pack has even more capacity than that and at some point I will do a full discharge test with assistance from Chris. Chris is my dealicaler of EV grins when a stock factory ebike or kit wiring is just not good enough. Yes, that is a shameless plug but, he has let me ride 2 of his high performance builds and I may need another EV grin fix soon. Plus I have plans to modify mine and am already familiar with the quality of his work so I feel comfortable plugging his site.
Once I sort out mounting the locks on the bike I plan on doing the commute during the week and enjoying the excitement of bicycling with Atlanta traffic.
Enough for now; more later.
I HAVE NO FINANCIAL ASSOCIATION WITH AEROBIC CRUISER BEYOND HAVING PURCHASED A BIKE AND HOPING THEY SELL ALL THEY HAVE. The financial backing of the company is provided by Charles McVean and my only association or knowledge of him is from what I have seen on the web.
42.99 miles
17.952 Ah
690.16 Watt Hours
32.15 Amps Max
37.6 Volts minimum
17.9 mph Avg Speed
THE BIKE
THE ROUTE
TME
MY EFFORT
Bikes: Specialized Allez, Specialized Sirrus
Quoted: 17 Post(s)
Moved from Recumbent to E-Bikes.
I think those are very sweet looking bikes in my opinion. I hate to ask the price tag though, especially when a homebuilt bike can be 90% as good - I have a used Sun EZ Sport 26/20 faired long wheel-base recumbent with dual LiFPO4 packs, and a front Nine Continent kit with CycleAnalyst - total price about 2000 bucks. I imagine that the price is at double that for the Aerobic Cruiser? I've had my bike up to 90 miles on a charge, with the dual packs running in parallel. LWB recumbents make great ebikes with their low midracks carrying lots of batteries so that they do not interfere with cargo on the back rack. With a fairing you are into some serious efficiency. I typically average 13 watt hours per mile in a mix of flat and moderately hilly terrain. Thanks for the report
Cool, seems like a reasonable deal. It seems to have enough battery on board, although I'm packing 30amp hours at 48v, I gather that bike is 20amp hours of lithium iron, which is still quite a big battery.
Quoted: 659 Post(s)
Liked 7 Times
The price I was quoted for the AC was $1500, but that's largely because the model is discontinued. It appears to include a number of parts that are either proprietary or at least hard to find from other suppliers. That makes it a bit of a risk if some critical part breaks and can't be replaced.
Aerobic Cruiser Battery
Considering I used almost 18Amp hours on my ride described above and the ending voltage was 39.2 volts immediately at the end of my ride I would say a which works out to 3.27 volts per cell. With LiFePo having an "empty" voltage of 2.8 per cell and a working voltage of 3.0 to 3.3 volts per cell I would say it may have even more capacity than advertised.
If someone is will to work at it a bit most issues can be resolved with an equivalent solution.
A motor / controller don't care what kind of batteries or what chemistry is suppling the voltage and there is certainly plenty of room for your chemistry of choice.
The controller? AC used the BAC1000 made by ASI in Canada. And while they may or may not survive for decades like some of the forklift and golf cart controller makers they seem to stand a better than average chance. One of the major ebike kit providers (Justin Le of Grin Tech) has a posting on another forum earlier this year that Grin Tech has contracted with ASI to make the boards for a new line of controllers they are begining to produce.
The motor? A MAC 7T geared hub motor that can be ordered from multiple suppliers or replaced with a variety of other geared or direct drive hub motors. I will give you that the cover configuration on the one in the AC is a bit different.
The connectors? Molex connectors used on the bike are in widespread use by the auto industry and should be available for over a decade.
The battery? There are reputable providers of LiFePo packs in custom configurations especially a 36 volt type pack.
The only truly "custom" parts on the bike are the frame, battery enclosure, the huge front chain ring and the clamp for the handlebar on the Ritchey stem. Everything else is available from suppliers that have been around for many years.
Looks like Aerobic Cruiser is in clearing out the inventory mode. I see on eBay they are selling bare frames with the swingarm, rear shock and the speed sensor switch installed.
