2018 Norco Threshold Apex 1 toe overlap
Old 09-28-17, 08:20 PM
ricohman
ricohman's Avatar
Liked 6 Times in 5 Posts
I am seriously thinking about buying one of these and had one out for a few laps in my local park.
I was surprised that my toes hit the front wheel a few times in slow maneuvers when I was making some sharp turns back uphill.
I did some tight turns and I think I weight the outside pedal so it never hit the tire enough to make me feel like I would crash. But this really doesn't replicate racing.
My 2016 JTS has no toe overlap. But it doesn't handle as sharp as the shorter Norco. But then it's a great all rounder and I will be keeping it for gravel and racing.
Is the toe overlap a real concern? This is a 55.5 cm frame.
ricohman is offline
Old 09-29-17, 07:28 AM
chas58
chas58's Avatar
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times in 335 Posts
What type of riding do you do?
Personally, toe overlap only bothers me doing track stands.
chas58 is offline
Old 09-29-17, 07:47 AM
ricohman
ricohman's Avatar
This bike will be used just for racing.
If I had to climb a hill and complete a turn sharp in a gate halfway up, there is no way I could peddle through the turn to come back down the hill. I guess I could clip out and run around the corner but if something can be ridden I would rather do that.
ricohman is offline
Old 09-29-17, 12:53 PM
chas58
chas58's Avatar
Yeah, if you have very slow speed very tight turns on the course, it could get pretty irritating. but without a very very slow tight turn, you won't notice it.
Try asking this in the cyclocross racers forum.
chas58 is offline
Old 10-02-17, 08:07 AM
ATPAH
Quoted: 63 Post(s)
I had this issue on my Renegade. I have long tended to push my cleats all the way back and I'd be getting stopped on the twisty singletrack that I sometimes ride, if I left them that way. I moved them up to the point where they rub, but they don't prevent the wheel from turning or the pedals from turning, if the foot and tire come together. It was not as hard to adapt as I had thought. Is there any room for you to move the cleat on your shoe without losing significant power/efficiency?
ATPAH is offline
Old 10-02-17, 02:24 PM
redlude97
Quoted: 1975 Post(s)
Liked 232 Times in 173 Posts
toe overlap is a real issue in cyclocross, I deal with it on my 49cm frame. You just get used to the timing to avoid overlap. Moving the cleats forward and/or running shorter cranks is also another solution
redlude97 is offline
Jim53
Fitting Your Bike
20
06-28-17 03:25 PM
lopek77
Road Cycling
39
02-27-14 12:08 PM
nelsonfung21
Singlespeed & Fixed Gear
5
12-20-13 10:24 PM
dbg
Fifty Plus (50+)
34
08-16-12 08:24 AM
dokterd1
12
07-11-10 09:24 PM
