UDI2 Junction Box
Road Cycling ďIt is by riding a bicycle that you learn the contours of a country best, since you have to sweat up the hills and coast down them. Thus you remember them as they actually are, while in a motor car only a high hill impresses you, and you have no such accurate remembrance of country you have driven through as you gain by riding a bicycle.Ē -- Ernest Hemingway
UDI2 Junction Box
Old 11-01-19, 09:02 PM
72andsunny
72andsunny's Avatar
Quoted: 35 Post(s)
Liked 5 Times in 5 Posts
UDI2 Junction Box
Okay, stupid question:
I was going to change out my stem, but what I think is the junction box is mounted there. Is there some way to get this thing off without cutting the cable tie? Thanks!
72andsunny is offline
Old 11-01-19, 10:04 PM
noodle soup
noodle soup's Avatar
Quoted: 4694 Post(s)
Liked 1,860 Times in 991 Posts
you should be able to wiggle it off.
In the future, I'd use something like this to mount the junction box.
https://www.fouriers-bike.com/en/pro.php?m=l&cid=67&f=2
noodle soup is offline
Likes For noodle soup:
Old 11-01-19, 10:32 PM
FeltF2Tarmac
Woman make me faster
FeltF2Tarmac's Avatar
Bikes: 2014 Felt F2 Di2 2018 Tarmac Comp Disc
Quoted: 91 Post(s)
Liked 4 Times in 3 Posts
I use one made by Lightweight that looks just like the mounts noodle soup linked. Mine was like $20. The rubber band thing is lame.
FeltF2Tarmac is offline
Old 11-02-19, 01:07 AM
72andsunny
72andsunny's Avatar
Quoted: 35 Post(s)
Update: thereís a little tab hiding on the mounting bracket. Push it up and gently slide off the junction box. Itís a pretty flimsy system, so I think Iíll take the above advice and replace it.
Likes For 72andsunny:
Old 11-04-19, 01:03 PM
faulker479
Bikes: Synapse, Slate
Quoted: 55 Post(s)
Liked 11 Times in 7 Posts
If that is a picture of your stem and junction A box, that is not a zip tie. You should be able to pry the strap off with your hand or a small screwdriver.
faulker479 is offline
Old 11-04-19, 01:09 PM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
Liked 524 Times in 347 Posts
Use the tab as described above to remove the junction box from the mount, this will give you a little more room to work. Remove the retaining strap off the tab (you can see the tab in your picture) by using your thumb to push down on the strap (toward the tab) and you will be able to unhook it. Reassemble by reversing the procedure.
jadocs is offline
Old 11-04-19, 05:32 PM
noodle soup
The OP solved the problem before you posted this, and he was informed about a little piece that eliminates the stupid Shimano "mount".
