Front fork
Front fork
Hi all you knowledgable people!
Has anyone experienced the front shearing off their Raleigh Eclipse folding bike?
After adjusting the height of the handlebars, I went to get back on and they completely sheared off from the frame and front forks.
It’s irreparable 😭 and I wondered if this was something that happens???
The bike is otherwise in as new condition.
Advice too would be most welcome
thank you
thank you
Quoted: 6193 Post(s)
Liked 4,809 Times
Why would you think that this is something that just happens? Especially to bikes in otherwise new condition?
If the advice you wish is for getting this fixed, then this isn't the forum for that. You should be in the Bicycle Mechanics subforum.
Oh, welcome to BF, some of us give tough love.... <grin>
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,991 Times
What sheared off? A bike shouldn't fall apart like that unless it is of really really low quality and that very well may describe your bike looking at a picture. However it is a Raleigh and while they have lost the quality over the years of being bought out by different companies I would doubt highly they would just completely fall apart on a new bike. Certainly if you overtightened or under tightened something or if you put something past the minimum insertion line (which is common on quill stems and of course seatposts) they can have some serious issues.
I would join the forums, post in some different threads to be active around here and then after a short period you will be able to post pictures and we can see what happened. Without pictures it is hard to tell what happened and if anything can be done. You can introduce yourself in the welcome forums or take a look around at the various sub forums here. There is one dedicated to folding bikes so you could take a look around there not to repost your current thread but to get involved with various discussions on going so you can get to 10 posts.
Helpful
Thank you both
Clark. You’ve just told me what must have happened. I adjusted the height of the handlebars up. As you say, and I now realise, there must be a minimum you have to leave inserted. I have obviously exceeded this and it has failed. The handlebars have not just popped out, the end has sheared off.
Looking like I need new front forks. But I will post on the advised repair forum.
At 67, I’m still able to source and solve issues thanks to kindly souls who take the time to help. Thank you very much
Clark W. Griswold
Liked 3,991 Times
Thank you both
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
yikes! that sounds terrifying and should not happen to any bicycle. nothing is perfect, but it sounds like Raleigh owes you a replacement.
on a related note, it's just a "fork." you only have one of them on a conventional bicycle (sure, there are mutant bikes with more than one fork), and we can assume that it is on the front of your bike. a normal bicycle does not have a "rear fork," so the word "front" is redundant.
Quoted: 523 Post(s)
Liked 229 Times
Are you sure you are using the correct terminology for what broke? It may be the stem, not the fork that you broke. Here are pictures of the fork and the stem. Raising the stem too far may cause the stem to fail but if the fork itself broke, that would not be the cause. It would probably be a defective fork. Not uncommon as there have been many recalls on bicycle forks. You need to file a report with the CPSC so that if this is a more than a "one of" the CPSC can build a case for a recall which means it gets fixed for free for all owners. https://www.saferproducts.gov/IncidentReporting
Bicycle Fork picture
Bicycle stem picture
If the stem is too short you can buy a stem raiser that does just what you did but does not risk damaging the stem and having a stem failure. Available online for prices from around $8 to around 30. The on pictured is a Delta Cycle Alloy stem raiser. I've used one on my Balance 450 MTB for years.
Stem Extender picture
Likes For VegasTriker:
To Vegas triker
This is helpful. Yes it is the stem that has broken./sheared off. Question. Will a stem extender solve the problem instead of buying a whole fork (and stem)?
Quoted: 1819 Post(s)
Liked 1,693 Times
If it is the stem that is broken, it is the stem, not the fork that needs to be replaced. Folding bikes often have proprietary stems that are not compatible with the types of stem risers used on more conventional bikes. Your solution might be to buy a handlebar with more rise so that you don't extend the stem too far
Let your bike be the tool
Bikes: '66 Raleigh Carlton, '70 Ron Cooper, '95 Bianchi CD'I, Zonal Frame with Xenon gruppo, Carbon Frame with Record Gruppo, Columbia Twosome, Terry Classic, Bianchi SX, Gravity SS/FG
Quoted: 338 Post(s)
Liked 314 Times
From the pictures I've found on the internet, your stem is like a gooseneck and inserted into the fork's "steerer" tube. The handlebar height appears to be adjustable up and down by opening a quick release cam at the base of the stem. Is this incorrect?
Never try to teach a pig to sing...
Likes For cranky old road:
Quoted: 523 Post(s)
Liked 229 Times
Yes, it is possible to use a different type of handlebar raiser (see picture below) but you still need to find a handlebar stem to replace the broken one. From the picture shown in this sale advert for the Eclipse it is much longer on folding bikes https://www.shpock.com/en-gb/i/WvHLm...e-folding-bike. You also need to be able to remove the broken piece lodged in the steerer tube. It may also be that the handlebar/stem from another brand of folding bike would work on the Eclipse. This particular bike doesn't sell for a lot of money so may not be worth putting $$ into the repair.
Liked 1,693 Times
If the stem can be raised and lowered, it cannot be a permanent part of the fork. The fork is inserted into the frame from the bottom, the stem is inserted into the fork steer tube from the top
Likes For alcjphil:
Yes crankyoldroad
That sounds about right. I’m obviously unfamiliar with the correct terms. Thank you
the handlebars came right out along with the lever for adjusting them.
Quoted: 338 Post(s)
Liked 314 Times
So is it the steerer tube of the fork that has broken rather than the stem? And the fork now looks like a Y with a shorter tail than originally, with the tip of the Y that had some sort of provision for adjustable diameter clamping on the stem has sheared off? Most of the steerer tube is still inside the greater frame? (FYI That part of the frame is called the head tube and the bearing set that allows fork and handlebars to rotate in the head tube are the headset.) I'd really like to see a photo. In my imagination, from the information in this thread, it sounds like the top of your steerer tube has sheared off "along with the lever for adjusting them." Non-folding bikes would not have a fork steerer tube that will clamp down on the gooseneck stem. I think that has made your problem hard to comprehend for those of us less familiar with folding bikes. How old is this bike? Unless the instructions that came with the bike specify not to raise the handlebars past a minimum insertion mark, I'd try to get some compensation from Raleigh (probably unsuccessfully, I'm afraid."
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 463 Post(s)
Liked 546 Times
A quick check of the CPSC data base will tell you if there has been a recall of any item
https://www.saferproducts.gov/PublicSearch
Use the advanced search option and enter bicycle as the key word. In the "Type" field you can select "reports" (there are a lot) or "recalls/repairs" to get the ones that have been recalled.
Likes For DangerousDanR:
Quoted: 1109 Post(s)
Liked 1,200 Times
FWIW, this sort of topic really belongs in the mechanics forum and you'd get excellent advice there. Here is a picture I got off the web of what I think your bike is like. It might help you to communicate the problem, but again, a photo is always best and most efficient.
Likes For Camilo:
To cranky
THANK YOU. Your patience and politeness is much valued.
The pictures that were posted were really helpful.
No idea on age of bike though, I bought it as new.
It is the steering tube that has snapped off! (There was NO indication how far I need to put the handlebars in! )
So, if you’re not tired of all this, what do I need to replace please?
ps. I’ll try to post photos
Clark W. Griswold
Liked 3,991 Times
That is solved if you are interested in bikes. If you enjoy bikes post around the forum check out subforms and join in on other currently running discussions pretty soon you have enough posts and you can then post pictures and be a more active member of the forum. No need to just post in one thread and certainly no need to create a bunch of new threads but join in with your other cycling folks here and talk bikes and related topics. It is fun as all get up sometimes and you can learn a lot and maybe teach something on certain topics.
Quoted: 338 Post(s)
Liked 314 Times
Photos at last!
This is the whole part I need which branches off into the forks. You can just see where it has sheared off. I’ve ordered a new one.
This is the clamp with, I'm assuming is a bit of the sheared off stem inside.
Thank you once again for all your patience and support.
You might, or might not be pleased to hear, that I will attempt to fix it myself. 🤭
Quoted: 338 Post(s)
Liked 314 Times
One issue you might have in installing a new fork yourself is the headset bearing race that is pressed onto the fork at the base of the steerer, either removing the old and installing it on the new fork or procuring a replacement compatible with the headset and installing it. Probably easiest to have a bike shop do that.
Liked 1,693 Times
The piece that sheared off is the top of the fork steer tube, not the stem. The stem must be inserted well past the threaded portion of the steer tube to prevent this happening again. If your handlebars are not high enough, you will either need a longer stem, or handlebars with more rise
Likes For alcjphil:
