Ultegra Disc Brake Pads Install Problem
Old 08-21-22, 01:12 PM
Koyote
Quoted: 5608 Post(s)
Liked 8,540 Times in 3,681 Posts
Im installing a new set of disc brake pads in these Ultegra brakes: exactly the same as the old pads. L03A. Ive done this before with no problem. But this time, when I slide the pads in, they are pretty much up against each other - with no room for the rotor in between them. And no, I did not grab the brake handle while the wheel was off And I have checked to ensure that the backing plates are completely separated, pushed as far outward as possible. Any ideas?
Koyote is online now
Old 08-21-22, 01:31 PM
Barry2
LRP=HR
Bikes: Holdsworth 1979 Special, C-dale 1993 MT3000 Tandem & 1996 F700CAD3, Cervelo 2022 R5 & 2018 R3, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 621 Post(s)
Liked 795 Times in 461 Posts
Push the piston back into the caliper.
IIRC, my pistons go almost flush with the caliper face.
Barry
Barry2 is offline
Old 08-21-22, 01:35 PM
Koyote
Barry
Did that already. Still too little room between the pads to even get the wheel back on rotor will not slide between them. Rode the bike 40 miles this morning with the old pads, working perfectly. Now with new pads, cant even get the wheel on.
Old 08-21-22, 02:07 PM
Barry2
LRP=HR
Quoted: 621 Post(s)
OK then, I measured a new pair of L03A pads and they measure 4.03mm thick.
That's the pad and the backing plate together.
What cha got on yours?
Barry
Barry2 is offline
Old 08-21-22, 02:14 PM
Crankycrank
Quoted: 675 Post(s)
Liked 678 Times in 512 Posts
You might have to bleed a little fluid out to allow the pistons to retract all the way.
Crankycrank is offline
Likes For Crankycrank:
Old 08-21-22, 02:17 PM
Barry2
LRP=HR
Quoted: 621 Post(s)
Or with the bike upright and the reservoir cap open, push the pistons back until the oil stops dripping on the carpet!
Barry
Barry2 is offline
Likes For Barry2:
Old 08-21-22, 02:22 PM
Polaris OBark
ignominious poltroon
Polaris OBark's Avatar
Quoted: 1127 Post(s)
Liked 1,653 Times in 917 Posts
If you or someone bled the brakes with worn down pads and/or rotors in place, or decided to slightly pressurize them at the end of the bleed to get them nice and firm (NTTAWWT), this can happen with new pads or new rotors, and in my case nearly always does when replacing both simultaneously.
Polaris OBark is offline
Likes For Polaris OBark:
Old 08-21-22, 02:25 PM
Polaris OBark
There is also a newer, less expensive version of this, that looks like a piece of rotor.
Old 08-21-22, 02:28 PM
Barry2
LRP=HR
Quoted: 621 Post(s)
I'll see your fancy park tool, and raise you a multipurpose tool.
Barry2 is offline
Likes For Barry2:
Old 08-21-22, 02:33 PM
Koyote
Barry
Barry, I spoke too soon I pulled the pads back out, got in there with a plastic tire lever, and pushed like hell. Did manage to move the pistons back a bit more. Theyre all good now. So, you were right! Thanks for the assist.
Thats a little embarrassing. I have done this, many times, and never had that experience.
Likes For Koyote:
Old 08-21-22, 02:37 PM
Barry2
LRP=HR
Quoted: 621 Post(s)
We expect this kinda behavior from noobs!
Welcome to Bike Forums!
Barry
cxwrench , WHERE ARE YOU????
Come kick him while he's down!
Barry2 is offline
Likes For Barry2:
Old 08-21-22, 03:25 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1927 Post(s)
Liked 2,839 Times in 1,452 Posts
You should always clean/lube the pistons before pushing them back into the bores. Mineral oil for Shimano.
cxwrench is offline
Likes For cxwrench:
Old 08-21-22, 05:02 PM
Koyote
Noted. Thanks.
Old 08-21-22, 05:07 PM
Barry2
LRP=HR
Quoted: 621 Post(s)
Koyote ,
Glad you got your pads squared away. (and your leg pulled a little)
I had to fight mine last time. Hence the new brake tool. Can't wait to actually use in in anger.
All the best
Barry
Barry2 is offline
Likes For Barry2:
Old 08-21-22, 08:12 PM
Koyote
Even though a plastic tire lever works just fine for me, I'm always looking for am excuse to buy a new tool. You guys are not helping.
Old 08-21-22, 08:35 PM
Polaris OBark
You will be happy to know I just reproduced your problem.
Old 08-22-22, 03:07 PM
Koyote
Polaris, found this on the product page for that tool:
NOTE: Wedge-style piston tools, such as the PP-1.2, are not intended for use with brake systems that utilize ceramic pistons, such as Shimano road disc brake calipers."
Guess it's not a good idea for my Ultegra calipers...?
Old 08-22-22, 03:23 PM
Polaris OBark
Huh.
I never saw that before. I have ultegra and XT pistons, which I think are ceramic. (Not sure about that, either.)
The way I use them is to leave the pads in and I jam it in between the pads.
I used to do it with a broad screwdriver, but that was more likely to scratch the pad surface.
I wouldn't apply the tool directly to the pistons. Even with a plastic tire lever, you have to be really careful. I keep old pads so I can indirectly press on the pistons through them.
Old 08-22-22, 03:26 PM
Polaris OBark
Maybe the new one is safer? https://www.parktool.com/en-us/produ...-spreader-ps-1
Old 08-22-22, 03:35 PM
Barry2
LRP=HR
Quoted: 621 Post(s)
Edit: below is my procedure, a mechanic here in BF claims you should not press directly on the ceramic.
That’s not a bad rule, a sharp edge on the retraction tool would cause an excessive pressure point on the ceramic.
It's not pressing on the ceramic directly that's the issue.
It's trying to retract the pistons from one side/edge.
You can force the piston to become crooked in the bore and chip the ceramic.
Barry
Barry2 is offline
Old 08-22-22, 03:39 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Huh.
I replace pads in Shimano calipers w/ ceramic pistons daily. If putting the 'pad spreader' between the old pads doesn't work I remove the pads, clean/lube the exposed pistons and then push them back carefully w/ an 8 or 9mm combination wrench. At this point I have not ever broken a piston. Of course the important words here are 'clean, lube, and carefully'.
cxwrench is offline
Old 08-22-22, 04:20 PM
Polaris OBark
For the record, CXWrench is the one who got me to quit using a large flat-blade screwdriver between the pads while I was ahead. The pad spreader definitely works better. (I've never had the joy of a pad that was stuck.)
Old 08-22-22, 08:06 PM
Koyote
I guess I've been lucky: I typically remove the pads, then use a flat-blade screwdriver to push back each piston, or sometimes a plastic tire lever directly on the pistons -- I kind of use one piston as a fulcrum to press against the other. I haven't broken anything, but will definitely do it differently next time.
Old 08-22-22, 09:13 PM
Polaris OBark
My kid cracked one of his pistons using a screwdriver. I think it was a ploy to loot all of my tools before he went back to college.
Old 08-23-22, 10:08 PM
NoWhammies
NoWhammies's Avatar
Quoted: 754 Post(s)
Liked 464 Times in 273 Posts
I thought the pad spreader was not to be used on road bikes with ceramic pistons. Am I incorrect in this?
NoWhammies is offline
