Threaded headset: Adjustable race with an integrated keyed washer?
Hi there, folks. I can't figure out how to remove/adjust a threaded race, as it seems to be stuck. Here are some images I've uploaded - please open the URLs manually.
Complete headset before disassembly. The round metal piece below the locknut covers the keyed washer.
cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/1680x2000/headset_complete_9a197ec778a6a44d461b253ecbcc463ee16c615b.jpg
A groove and a hole on the thread
cimg6.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1709/headset_groove_5bc6522266ee8b60a2a789619cfa27d4553f8ff3.jpg
You can see the tab on the keyed washer.
cimg7.ibsrv.net/gimg/bikeforums.net-vbulletin/1660x2000/headset_keyed_washer_73e5e237050b0b8691e3eb8d2b22184332fb4a81.jpg
The adjustable race seems to be integrated with the keyed washer.
cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/1443x1419/headset_without_locknut_and_washer_c6ad1129ae712137ad32bb0d7870a6e3bde26f56.jpg
Likes For PTbiker:
Quoted: 4201 Post(s)
Liked 3,857 Times
To my eyes it looks like the tabbed lock washer has become rotated on the steerer and it's tab is not jammed on the steerer's threads (and no longer residing in the steerer's groove). The usual fix is to grab the outer edge of the washer with a large pair of slip lock pliers and rotate the washer back so its tab reengages the groove. This tab out of groove rotation is fairly common and easily worked around. I know of no threaded race that has a tabbed aspect as that would preclude the threaded feature from being used Andy
AndrewRStewart
AndrewRStewart
Liked 3,857 Times
Hi, thanks for the reply. By saying I should grab the outer edge of the washer, are you implying that it's a separated piece from the race? It looks like one single piece (race and washer), but the black paint could be confusing me. Another doubt: isn't the threaded race supposed to be turned by hand?
Generally any thread damage on the steerer is a non issue as the spot will be small and with a little effort the race can be screwed back over the spot on reassembly. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 5775 Post(s)
Liked 2,573 Times
Sometimes it pays to pour yourself a cup of coffee and think things through a bit.
In this case, ask yourself how could a threaded race could end up there if it were (note the use of subjunctive mood) keyed in to the fork so it couldn't turn.
The answer is that it couldn't. So either the race isn't threaded and simply slides on, or the keyed part is separate from the threaded part.
Now, you can go back and read Andy's post for the solution.
The race is indeed threaded; it became loose after tightening the locknut. The keyed washer is still stuck, though. And now I know that one of the front brake arms is making a noise when testing for headset play. The reason for disassembling the headset was a creaking sound whenever I pressed on either side of the handlebar. At first I thought the steel handlebar was about to break, but then isolated the creak. After a partial disassembly, cleaning and lubrication (couldn't reach the bearings), the noise is gone. Let's hope it doesn't come back.
Liked 2,573 Times
At some point you're going to want to, or need to, deal with this because the headset will not stay adjusted on its own. As Andy said, the object is to grab the key washer with a pair of Channellocks and turn it until the key lines up with the slot then lift it off. Then you can decide whether to replace the key washer with a new one if it's marred too badly for your taste, or just put it back and use continue to use it.
If you're still having trouble seeing the key washer as separate from the lower race, try turning the lower race in a way as to tighten the headset. That will move it away from the from the washer and make it easier for you to go forward.
FB
Chain-L site
FB
Chain-L site
I don't have that type of pliers, and there isn't much space to hold the washer. What about hitting the tab with a screwdriver until it reaches the groove?
Quoted: 1034 Post(s)
Liked 1,290 Times
Go to store, buy the pliers necessary, slip lock, sometimes called channel lock pliers, then use them for the job. Why waste time, and potential damage? Do you wish to spend even more time and money replacing the fork when you damage the threads after the screwdriver slips? I'm all for word arounds, but only when there is really not a better way, and when it won't make matters worse.
Quoted: 3505 Post(s)
Liked 2,924 Times
This problem could have been easily rectified days ago and you could have been riding the bike this last weekend. But you seem determined to make this 30-second job far more difficult than it ever needed to be, because...I have no idea.
Really?? How many times to people have to explain the easiest way of fixing this to you? Now you want to hit your headset with a hammer?? Just buy a set of channel locks and do this the right way. They are less than $20 at Lowes and you will have them when you need to do this job again (and, BTW, they're useful for any number of other jobs around the house).
Liked 2,924 Times
You're right. I thought it was worth a try, but I give up.
Liked 2,573 Times
If you can get a decent purchase of the tab in a way that you won't be beating up the threads (any more than the tab already has), and you think you have decent hand skills, feel free to give it a shot before springing the dough for another tool.
FB
Chain-L site
FB
Chain-L site
A couple weeks ago, I may have solved my issue (fingers crossed), as I got no headset play this time after riding many kilometers.
After removing the stuck washer and filing off its tab, I cleaned and greased everything, including the race and the caged bearings. The only tricky part was to get the bearing preload right while tightening everything nicely.
A big thanks to all those who bothered to reply.
Likes For PTbiker:
