no love for a little cog
Old 09-07-10, 05:26 PM
hbsyncro
Quoted: 9 Post(s)
Liked 16 Times in 8 Posts
not sure whether to post this in mechanics or here, but i figure mtb'ers would probably know the answer. the set up i am running is shimano xtr m 966 dual control brake (hydraulic) / shift levers and xtr m 960 rear d. i have a fairly new xtr/dura ace chain and gore ride on cables. the cassette is older, but looks good. the bike shifts all gears great except for the problem i am about to describe. the chain will not stay on the second to smallest cog when i am up OR down shifting. going to a harder gear, the chain will shift to the cog and then go back to the 3rd smallest cog when i let go of the shifter. going from the smallest cog the chain shifts and the automatically shifts again to the third smallest cog. the chain will stay on the second cog during a shift if i hold the lever down. as soon as i let go of the lever the chain will go to the 3rd cog. everything else in the drive train works fine and is quiet as can be. i actually want to use this cog as it is the perfect gear for going fast on the road when riding to the trails. and last, but not least i would prefer to not buy a new cassette. help.
hbsyncro is offline
Old 09-07-10, 07:20 PM
frankenmike
mechanically sound
frankenmike's Avatar
Bikes: Indy Fab steel deluxe, Aventon cordoba, S-works stumpy fsr, Masi vincere, Dahon mu uno, Outcast 29 commuter
Quoted: 100 Post(s)
Liked 84 Times in 53 Posts
Possibilities: bent hanger, derailer out of adjustment(including limit screws), cassette improperly installed, shifter/cables/housing need servicing, drivetrain too worn.
frankenmike is offline
Old 09-07-10, 09:07 PM
Shadow7874
I would see if you can adjust your derailer some. I adjusted mine on my old mtb yesterday and it helped reach the one gear i was having trouble with
Shadow7874 is offline
JJ121591
Bicycle Mechanics
20
11-05-20 11:38 PM
Bishbike
Bicycle Mechanics
3
04-24-12 12:50 AM
swapmeet
Bicycle Mechanics
2
05-05-11 11:58 AM
TurbineBlade
Bicycle Mechanics
8
10-25-10 06:53 AM
hbsyncro
Bicycle Mechanics
1
09-08-10 11:15 PM
