New wheel truing stand; learning the hard way
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 582 Post(s)
Liked 697 Times
I got a Park truing stand for Christmas. Of course I would try the neediest wheels first; my old Super Sport and the two other Super Sports from the co-op. Of course the nearly 50 year old wheels are out of round and abused a bit from over the years. Learning and spending winter hours doing something bike-ish in the cold. I’m thinking when moving newer and more upscale on my meager collection it may get easier. Having fun though.
Old wheels are sometimes tricky to true.
Uneven tension, not dished properly, seized nipples, rim damage and dents, low and high spots. They are sometimes in need of just a couple minor adjustments but sometimes an entire detension and retension
Quoted: 582 Post(s)
Liked 697 Times
Yes to all the problems there. Didn’t do the total detention, but maybe need to further my education/learning with some more practical experience doing that.
Quoted: 809 Post(s)
Liked 1,022 Times
I've spayed PB Blaster on the nipples before starting on an old wheel. I squirt where the spoke enters the nipple and from the tire side of the rim. That could help.
You don't have to use PB Blaster, there are other lubricants that work well and don't smell so bad. I've got to try ATF and Acetone.
Quoted: 582 Post(s)
Liked 697 Times
No tension meter yet, but maybe in the future. Yep, some seized spoke nipples too. The old Schwinns use 16mm which I bought. I spray lube on them at start and on threads but some still needed replaced after fighting to try to loosen.
I’ve tried to base tension on pinging as mentioned here and comparing to known wheels from a shop. I also read that tighter is better when in doubt up to a point. On these old wheels the biggest challenge was roundness. Getting within 2mm is acceptable to me with 1 mm runout a goal.
It is a fun learning experience and will be interesting when moving up to the fancier wheels. I even have one my LBS did that the dish is off by 3-4mm and the dish is off maybe 5mm on my old Frejus. It is a good feeling to do this for myself since I do all my other maintenance tasks. It just felt silly spending $25-35 for this job.
Used to be Conspiratemus
Quoted: 297 Post(s)
Liked 245 Times
If the rim has taken a “set”, such that it has a flat spot or is bent out of plane, you will not be able to correct those faults by adjusting spokes. So you want to discover that state of affairs before you put a lot of effort into the wheels. Full de-tensioning will disclose the rim as needing a different approach involving brute force, or perhaps not being repairable at all.
But yes, it’s satisfying and great fun. Enjoy.
Quoted: 582 Post(s)
Liked 697 Times
Thanks for that info too
Quoted: 472 Post(s)
Liked 1,028 Times
I've rehabilitated enough old wheels that I've a) gained plenty of experience and b) learned to fully detension/fully loosen all the spokes and start over. It's the only way to ensure the nipples are free enough to fully do the job. Scary huh?
Another valuable lesson I read was: it's more art than science. Don't even try to get it right the first time. Work a bit in one section or on one side then back off and work somewhere else. Stop and breathe, check it here and there then correct something. Take your time. Warm coffee, good music, fully alone in the shop.
Approach truing wheels like an art history major, not like an engineer (says the Engineer). My goal now is < 2mm of hop, < 1mm off dish and < 1/2mm of runout. And I can get that with a good rim.
Likes For Prowler:
Space Ghost
Bikes: Bridgestone, Fuji, Iro, Jamis, Gary Fisher, GT, Scott, Specialized and more
Quoted: 292 Post(s)
Liked 412 Times
Wow, Santa really came through this time lol. That’s probably at the top of my Christmas wish list.
Passista
Quoted: 866 Post(s)
Liked 721 Times
It's OK to go for 1mm out of round, but even on many new rims it's not possible on the seam area.
Quoted: 582 Post(s)
Liked 697 Times
