SRAM Rival or Ultegra Di2
Last year I ordered a specialized roubaix expert 2021 withUltegra Di2. Due to the Covid disaster it’s on back order and maybe I’ll get the bike later this summer. My dealer who specializes in rode bikes suggested that maybe I get the 2022 Roubaix Comp with the new SRAM rival Etap. He said it is $200 less and a little heavier. Any opinions out there. Other than the Groupset the bikes are nearly identical. Since the bike goes for either $4800 or $5000, the pricing is not an issue . But how much more is the weight? Does anyone have any experience with the SRAM rival. I have read that SRAM works like the etap red and force with heavier parts! Thanks. My existing bike uses 105 parts and is over 10 yrs old.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
I've always been a SRAM guy so I'd go etap. They both work very well. Both companies have great CS. I think it's just a little easier to figure out potential problems w/ SRAM.
Quoted: 763 Post(s)
Liked 1,731 Times
will you get the eTap sooner? If not, I would just stick with the Ultegra di2 since you are only looking at a $200 difference. I have the Ultegra di2 and love it.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
I have eTap and have ridden Di2 also... I'd get eTap.
I also like Coke over Pepsi.
bike whisperer
Quoted: 1527 Post(s)
Liked 718 Times
Shimano is more competent than SRAM; bigger company with more engineers. Shimano gear tends to have fewer rough edges (so to speak, not necessarily literally) and more attention to detail. Dura-Ace is bonkers stuff, basically money no object without blowing dough just for the sake of it like Campy - and all the best value elements of DA trickle down to Ultegra.
All that aside, with Rival being more or less equivalent to 105, a tier higher for $200 (at $5k, no less) is a no-brainer.
Unless of course you wanna be the first kid on the block with 3rd-tier electronic...
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Clark W. Griswold
Quoted: 4347 Post(s)
Liked 3,984 Times
I prefer Di2 personally and find Shimano CS a lot easier to deal with, SRAM isn't bad but it always feels like more work for their stuff and Shimano is like yeah let's get you a label and we will get the new part sent out ASAP.
However the SRAM AXS stuff seems to be pretty solid and easy to deal with minus having 4 batteries (two in shifters and two on derailleurs) Plus the fit of their cable levers seems to gel with my hands really well. It is up to you in the end.
In terms of Cola Wars, RC baby, I don't want peasant cola I want Royalty! Though in terms of actual cola not old enough to be involved in the original cola wars, Virgils or Boylans is my favorite.
6 of one or half dozen of the other
It seems like both sides of the coin are good. I am leaning towards Di2 but I would probably get whatever one comes in first.There are those who believe there is not much difference between 105/ultegra. I would say at my level 18-20 mph it won’t make much difference anyway. This is clearly not any agreement here. Realistically they are both good and I probably won’t ride any better with one over the other, BUT I think the Di2 2450 gms is bit lighter than the sram rival 3210 gms
The Di2 bike will probably be the soon to be outdated 11 speed version, unless shimano gets on the ball and finally starts producing 12 speed. That would make rival a no brainer for me. Right now, it's not known if the road version of shimano 12 will include the microspline freehub or not. That is also a major consideration. I switched from 25 years of Campy, including Chorus 12, to force axs 12 speed last July. No regrets.
I got a new bike in March and went Mechanical Ultegra - why? because I am waiting to get the 12 speed Shimano DuraAce or will go RED AXS.
I am very happy with the Ultegra and will wait; just wish Shimano would hurry up - heard dates of June 25 as the embargo date but some say this is now delayed.
Thing that is putting me off just jumping in to RED AXS is the reviews of the FD and seems to be lots of chain drops! so expensive and not as reliable as Shimano; also the liquid in the brakes is a nightmare to deal with compared to Shimano. Now some are saying RED AXS might be updated at the start of next year(RIVAL just got released).
In your case DI2 is a no brainer unless you want 12 speed.
I've setup a sram axs FD 8 times now with 6 different cranks and had zero chain drops in almost a year. The cranks have been Campy chorus 12 and shimano grx that both offer more range.
I believe that the chain drops occur due to misalignment of the FD that occurs when the clamp bolt is fully tightened without rechecking the alignment. My FDs all rotated a little upon final tightening, so I carefully measure the gap between the end of the cage and the crank arm before and after tightening.
Another cause of drops is using the sequential or compensating modes. I have mine set to manual with a 2 sprocket limit if the shift lever is held down for a multishift.
My two force bikes haven't needed any tuning since being built-up.
Likes For DaveSSS:
Canadian eh?
Bikes: 2020 Specialized Roubaix Expert
Quoted: 131 Post(s)
Liked 96 Times
I have tried both Force AXS and Ultegra Di2. In the end I prefer the latter. Easier to get set up, and stays set up.
I recently updated my bike from Shimano 105 to Ultegra Di2 and a D-Fly wireless unit added to the mix. I could not be more pleased with this setup. With that said, though, I have never rode a SRAM-equipped bike.
I'd go with SRAM eTap over Di2 but I'd go for Force.
I built a bike a few years ago with Ui2 - worked great. Then I converted a previously mech bike over to electronic shifting and the obvious choice, because of no internal wire routing, was eTap. I liked it *so* much, when eTap Red went on sale, I bought the group, sold the Ultegra Di2 group and installed eTap. My wife also got an eTap Red set up and then a 1x AXS system on her new gravel bike.
For me, there is no question this was the right answer. I live in the frozen north and I do a lot of riding when it's cold. The double paddles on the Shimano shifters are impossible to get right or feel well with real winter gloves and are a nonstarter with mittens. Etap has none of those issues. It's also a lot cleaner installation and it's much better for when we disassemble our bikes for travel. A side benefit is that an entire group installation is about an hour even if you've never done it before. It's ridiculously simple.
Given a choice on a new bike, it would be - without question - AXS eTap for me. Pick your group, but eTap. Been there, done that.
On Your Left
Liked 2,433 Times
Likes For GlennR:
I have had 11 speed eTap Red, and now I am on 12 speed Force AXS and I have loved both a lot. AXS is really great, super smooth and trouble free. I have zero desire to go to Di2.
www.mp-aviation.com
www.mp-aviation.com
Bikes: Pinarello; Canyon; Lauf
Quoted: 75 Post(s)
Liked 48 Times
I've never used eTap but I've had issues with SRAM Force derailleurs on two bikes. My Di2 bikes have been solid so I will stay with Di2 - have no desire to switch to SRAM eTap.
As for 12-speed groupsets, I see no need for them as 11-speed is enough and there is actually overlap in a 2X setup. Now, I have a 1X 13-speed Campy Ekar that I really like on my gravel bike that I'm using as an endurance bike - manual. For me, it negates the need for a 2X electronic setup.
Lastly, I prefer not drinking soda at all - it kills your teeth and adds unecessary calories to your gut...but I digress...
Anyone who can get by with 1x doesn’t have a lot of steep climbs, and/or is willing to give up top speed. If your view is narrow enough, 8 speed is dandy. I not only have 12 speed, I use the 10-36 cassette and a 48/31 or 46/30 grx crank to get 557% or 552% range.
11 speed is quickly coming to an end.
FWIW, I weigh 135, but I'm getting up in age. I still ride 5,000+ miles per year.
Quoted: 75 Post(s)
Liked 48 Times
In any case, 13-speed 1X works for me but may not work for everyone.
Cheers!
Likes For cj3209:
Trying to keep up
Bikes: Pinarello Prince, Orbea Onix, Ridley Fenix
Quoted: 79 Post(s)
Liked 136 Times
Quoted: 75 Post(s)
Liked 48 Times
I've never really wanted a Campy bike, but am very tempted by Ekar for my gravel bike. How do you like it? Do you have to do much fine tuning on it, or does it stay set up pretty well? My gravel bike has SRAM Apex which isn't bad, but... when I hop on my DI2 road bike it reminds me that it is not Di2 or even my older 10 speed Ultegra level of smooth.
On Your Left
Liked 2,433 Times
Everyone is different, so it's great there are so many different groupsets so everyone can find what works for them.
Trying to keep up
Quoted: 79 Post(s)
Liked 136 Times
During shipment of the bike, I think the bike got misaligned as I had trouble shifting into the largest rear cog so I tried to fool around with the H/L settings and promptly mucked it up. My LBS fixed it and since then, the shifting has been very good with no issues. I really like not having to worry about a front derailleur and can focus on a few gears climbing hills and descending hills; very very good. You have to get used to the thumb lever that shifts to a smaller cog and the brake lever which shifts to a larger cog but it's very intuitive and I can actually shift easily while on the lower slopes of my handlebars. With Ekar, you don't really need electronic shifting.
We are truly spoiled for choice, and personal preference really matters. I'm not about to kick my bike to the curb - I love the Apex brakes and hoods and the shifting is fine. I do ride the gravel bike quite frequently, so it is definitely scratching an itch. I mean, if someone offered me a new bike with red or force, I wouldn't say no :-).
