XC Cycling Shoes vs Road
I recently got an Shimano XC502 shoe and a PD-M9100 pedal. I think a SPD Cleats + Pedal will also mount on a road shoe because it has those 2 holes in the middle. My questions is, why does the XC shoe have 4 holes?
With a mighty wind
Quoted: 1086 Post(s)
Liked 859 Times
There are two stand pedal designs. SPD style, to include many different brands, not just Shimano. They use a cleat on the middle of the shoe. Sometimes the shoe mounts have 4 holes to give you some adjustability in cleat placement. You’ll only use two of them.
The other style is Look type pedals. The cleat mounts to the three other holes you see in the lower picture. Or, in the case of Speedplay, an adapter to the three holes then a cleat to the adapter.
Sometimes you’ll see all of it like the bottom picture to give you total freedom in choosing your pedals.
SPD style tend to be double sided and less prone to mud and dirt clogging. Shoes for these are usually more walkable.
Look styles are sometimes totally smooth and not walkable. They’re very comfortable on long rides. Tend to be stiffer for power transfer. The larger body feels more secure. Aren’t good for anything but pedaling.
I have both, depending on the bike and how I use it.
That actually makes no sense and having used nothing but mtn bike shoes I've never once thought about why they all have 4 holes. 2 holes or 4 holes makes no difference to how far forward or backwards you can move the cleat. It is all in the slot. Maybe the metal plate would have to be longer to be strong enough to cover for the full movement of the plate if it only had 2 holes.
The 2-hole is used for mounting standard SPD cleats and road shoes usually have this as well as additional holes for mounting SPD-SL cleats. I bought some SPD-SL pedals and cleats but having to use cleat covers for walking around seems like a big step backwards for non-racing purposes. I get plenty of support with the right shoes and the SPD cleats work perfectly for staying attached to the pedals.
With the XC type of shoe as they are now known (used to be "touring" shoes), I can walk without falling on my ass or getting nasty looks from cafe and shop owners when I enter their businesses. When I was wearing my old bike shoes with the metal cleats for my pedals with toe clips and straps it was a very different matter when I would sound like I had tap shoes on.
never seen a pair of mountain bike shoes with only 2 so I made an assumption, even using google I can't find any. Maybe the combo roadie shoes like OP posted come with 2 hole SPD setups on the norm.
Really? Pretty much every spd type shoe I remember seeing has had two sets of holes. I think some of my first spd shoes may not have (I was a very early adopter of spd), but since then two sets seems to be the norm. Just for fun I scrolled through most of the MTB shoes shown on REI, and all that I saw had two sets.
Anyway, your comment made me curious what shoes might have only one set of holes since I had not seen any. So I was curious enough to dig a little and with a bit more digging I managed to find a few, but they tended to be for indoor cycling and were generally brands I never heard of.(Gavin, CyclingDeal, Roknemo, Honosuker, etc.). Also they were likely to be for shoes that were trying to accomodate both two bolt cleats and three bolt cleats.
Of the ones I found the Gavin models were the only ones that had models that were available in what looked like MTB, road, and generally the range of models rather than tailored to indoor cycling. I had vever heard of them, but they did look like they got reasonably good reviews. The rest looked like cheap no name junk.
All that said the standard good quality brands, Sidi, Pearl Izumi, Bontrager, Shimano, Specialized, Lake, and so on tend to come with two sets of holes.
FWIW, shoes are an area where I tend to splurge. I'll ride a lower end bike before I'll wear cheap shoes. So you won't see CyclingDeal, Roknemo, Honosuker, on my feet. I'll stick with Sidis. That may be why I hadn't see SPD shoes with one set of holes in the last 2-3 decades. Some things are worth opening the wallet on to get quality. Shoes and sleeping bags are a couple places where I don't bat an eye at a steeper price tag. The payoff in comfort is worth it.
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 904 Post(s)
Liked 1,887 Times
if you mount the spd cleats in the forward holes you will not be able to slide the cleats all the way to the back and vise versa. I recently was trying to slide my cleats back and they would not go and I could tell I had more room to slide them back further so pulled the cleat to see what was stopping it from sliding back all the way and it was of course the rear holes. Not a lot of difference but if fine tuning might make a difference.
With a mighty wind
Liked 859 Times
Ive also never used junk shoes. My racing preferences were Diadora or the Trek OCLV Nikes. That pretty much tells you exactly how old I am. They were all 3 holes and I removed the spd insert to “save weight”. Ha.
Currently I use pseudo-retro looking Bontragers on the road, and another pair of Speedplay specific Audi’s that get exactly as much use as my Speedplays (I’ll make you a great deal on them). On drop bars I mostly ride gravel, I find that Shimano agrees with my foot injuries more, so I use them. Once I wear those out and only Boa is available for better quality, I’m not sure what I’ll do.
When I got back into mountain bikes, I switched to flats and have been a lot more satisfied than I ever would have expected. I think the broader market would agree with me.
Seems nowadays, SPD style is almost gravel specific or spin class. And my single pair of Shimano shoes is no sample size.
That 4 hole plate sure is a lot more robust than the 2. That alone is probably why it gets used.
I wouldn't dream of choosing to ride unclipped even (or maybe especially) on technical stuff, but got my start riding MTB SPD with the very earliest availible spd pedals and shoes and old habits die hard I guess. So I tend to thing of MTB shoes as clipless. I have to remind myself that lots of folks do not share my preference.
With a mighty wind
Liked 859 Times
My first clipless pedals were Onza H.O. Ti. I used the black elastomers. I was 13 or 14 and I bought them with my paper route money. 1993 or so. Between road, mountain, and even my pedicab I used clipless.
I literally haven’t been unclipped until my Canfield last spring. It took a couple rides to get used to it but it’s great.
I do put my XTR pedals on for longer rides. I no longer believe that I get anything from the upstroke, but I find the more uniform pedaling circle of clipless to be less fatigue once the ride is longer than about 4-5 hours.
I seem to pass everyone on technical descents, MTB or gravel, no matter what is on my feet. As long as big air isn’t part of it (I’m a chicken).
Paper route money in 1993? You are making me feel old, That was 20 some years after my paper route days I was in my 40s by then.
Bikes: 1999 Giant ATX MTB, 2002 Lemond Zurich, 2018 Fuji Transonic 2.3, 2019 Specialized Tarmac Disc Expert
Quoted: 170 Post(s)
Liked 391 Times
I rode for many years with my MTB shoes and MTB pedals on my road bike. I was used to riding with clipless pedals on my MTB so when I got a road bike I just added some MTB pedals to the road bike and off I went. It was much later that I actually switched and got regular road shoes and pedals for my road bike.
Unless one is referring to Five Ten type shoes and flat pedals with pins, the cleatless pedals work the same. The SPD-SL pedals and shoes in theory provide more support but if a shoe is made properly the sole will provide enough support with a SPD or even a clip and strap arrangement. Last year I ordered a dozen pairs of shoes to find my new pair and there was a great deal of difference in the stiffness of the soles. I want as rigid a sole as possible along with a good fit for my "normal" width feet. I found quite a difference in sizing and stiffness even within the Shimano bike shoe line.
Different companies have different ideas as to what is a normal width and normal foot pocket. People with very narrow or very fat feet need to spend more time searching for a brand that has lasts that work for them. When I find a shoe that does fit well I always buy a second pair as a future replacement.
Quoted: 4391 Post(s)
Liked 4,833 Times
It varies with the shoe. Yes some (most?) shoes you can just take out the insole and swap plates. I had a pair that the plates didn't come out without cutting the sole. It probably could have been cut from the top inside the shoe, but I didn't think that was a great idea and would have only done it as a last resort. Since I could get the same cleat position with the other set of holes it was not a problem to just use the other holes.
Likes For staehpj1:
Quoted: 1109 Post(s)
Liked 1,200 Times
The fun part was on the trail: of the two bolts, one stripped and IIRC, fell out, so the cleat would rotate around the other one. I couldn't unclip from the pedal, so had to take the shoe off to get off the bike. Of course I fell down the first time. Since then, I've made sure to grease the bolts and check them every now and then.
