Which crank bolt tool do I have?
Bikes: 1968 Raleigh Super Course, 1972 Raleigh Professional, 1975 Raleigh International, 1978 Raleigh Professional, 1985 Raleigh Prestige, 1972 Schwinn Paramount, 1980 Schwinn Voyageur 11.8, 1960 Carlton Franco Suisse Peugeot PX10, 1972 Motobecane Le Champ
Quoted: 322 Post(s)
Liked 690 Times
I recently traded a $20 bill for a small box of vintage bicycle related fiddly bits. Inside it were several useful pieces: some Simplex SLJ jockey wheels, a few seat post binder bolts including Campy, Sugino, and others; some Suntour hardware, clamp on Shimano and Zeus cable guides, some chainring bolts and lots of other stuff. One item I’m curious about is this crank bolt socket. It has very thin walls. Out of curiosity I removed the dust cap on a Campagnolo crankset just to compare the fit. The tool fit in the hole perfectly but there is a little wiggle room around the bolt head. I’m guessing this tool is probably 16mm? Definitely larger than 15mm. Zeus perhaps? I really don’t know.
I’m thinking there are likely some people here who have seen this one before. Your input is appreciated.
mycocyclist
Quoted: 910 Post(s)
Liked 812 Times
Stronglight Old School Crank Tool
Prongs remove dust cap.
(I was fortunate to find one with the crossbar.)
Quoted: 322 Post(s)
Liked 690 Times
Thanks machinist42
Likes For Pcampeau:
Quoted: 3807 Post(s)
Liked 3,331 Times
Viva Verot!
Pcampeau -
the socket also fits Zeus crank fixing bolts
Viva Verot!
Pcampeau -
Likes For juvela:
Old fart
Quoted: 3587 Post(s)
Liked 3,398 Times
Yes, Stronglight, for 16mm crank bolts. It would have come with a tommy-bar and proprietary 23.35mm extractor tool. Bonus if you can find those!
Likes For JohnDThompson:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
I found it interesting that the Stronglight document says to use Vaseline on the threads. I always use a small amount of whatever grease is in arm's reach and then have to get in between the crank arm and bottom bracket to clean what squeezes out. The excess Vaseline would still need cleaning to not attract dirt, but it would probably be easier to do.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
He did, anyway. Personally, I'd take the remote possibility of premature crank taper wear over having a crank fall off during a race or other important ride every time.
Quoted: 1106 Post(s)
Liked 1,326 Times
"Falling off" can be forestalled with a dustcap, and a loose crank is obvious before it does; while a crack may first be noticed when the crank separates from the rest of the bicycle.
Liked 2,568 Times
And we should be checking our cranks for cracks regardless.
