Polish BB Spindle
Polish BB Spindle
Found a spindle in size I needed, but you can see its forged but not polished. Old one adjacent for comparison.
Can I just chuck this my friends lathe and polish with 800-1500 grit paper? You can feel the difference in smoothness between the polished and non polished
It will wear in. After some use the smoothness will be similar to the polished one. Roughness that can be felt by hand is usually not noticable while actually in use anyway.
Quoted: 4201 Post(s)
Liked 3,857 Times
Back in the day the few anal of us would take apart their "cheap 10-speed" hubs and repack them with grinding compound (think grease w/ grit). Then we would spin the axle w/ a hand drill while we watched 1970s TV. After a bit the hubs would get cleaned and properly greased, with fresh balls now running on a polished track. Made your Normandy Sports roll as nice as Campy NR. Andy
AndrewRStewart
AndrewRStewart
Quoted: 1944 Post(s)
Liked 2,164 Times
I’d be inclined to get a dowel to match the radius of the spindle. I’m not sure you can pinpoint the exact location where the balls will be running on the cone surface. You’ll also want to apply even pressure.
I’m not sure if wet-n-dry or crocus cloth is better. Wrapping the dowel with whatever you use might give a more even result.
John
John
Quoted: 2026 Post(s)
Liked 1,096 Times
Get a bearing retainer filled with the correct size balls and, using valve grinding or similar mild abrasives, hold it against the bearing track while rotating the spindle in the lathe. That way the bearings will polish the correct track locations.
Likes For HillRider:
SE Wis
Quoted: 2746 Post(s)
Liked 3,391 Times
And I'll assume throw those bearings away and use new ones to install?
Quoted: 6193 Post(s)
Liked 4,808 Times
The bearings only contact a tiny part of that race on the spindle. Putting it in the lathe and using sandpaper no matter how fine might just make the low parts lower faster than it does the high parts. So then you'll be slightly ovalized.
If you want to do something, do as Andrew R Stewart said. I knew a guy that did that to the gears with valve lapping compound in a large deep sea fishing reel and it was the smoothest running fishing reel I ever felt.
Though personally, I wouldn't worry about it for the BB spindle. I think it'll take care of itself in a very short time.
Quoted: 506 Post(s)
Liked 638 Times
Really Old Senior Member
What you mean to say is the new one has an oxide coating or is "unpolished".
IF it's a cheap one, it's probably relatively soft and will wear quickly.
Home polishing will likely just remove the surface hardening, if any.
Forging & polishing are not mutually exclusive.
Liked 1,096 Times
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
I’m also in the camp of using a polishing compound on the lathe if you insist on doing something to it. You could just put it in a bike frame and do it there too, spinning the spindle with a hand drill. That way you know it’s square.
Your buddy with the lathe should know this, but keep the polishing compound that will likely migrate off of the bed ways.
Yes, replace the bearings after, and make sure to get all of the compound cleaned off.
You could also just ride it, adjust the bearings as needed, and go on.
I would not try using sandpaper or re-cutting the bearing track in the lathe with a tool.
It should be noted that bearing races should be a slightly larger radius than the balls that ride on them, so it’s never going to be perfect with the correct ball size and abrasive compound. Don’t try to polish until the entire area is shiny or you’ll have changed the raceway curvature.
Quoted: 241 Post(s)
Liked 232 Times
https://www.interlocracing.com/shop/...bottom+bracket
Regrease that one regularly and for gods sake use loose balls and not a retainer ring. That way you will have a rock solid component for a very long time.
Likes For ign1te:
Just go ahead a buy a real bottom bracket instead. There are very few that still make cup and cone, but TANGE is one of them.
Why Polish? Is there a boycott on Ukranian bottom brackets?
Likes For Numerozero:
Quoted: 537 Post(s)
Liked 415 Times
The finish is nothing other than paint or gun metal, depending on how it was manufactured.
Bearings are much harder than the axle which in comparison is a softer metal.
When you service bottom brackets, you will always see a track grooved by the bearings.
That is expected as your bearings break-in and seat from normal use.
Another question, I found an old Shimano 5-Dll 70/119 spindle in my pile of junk. Can you put a 70mm spec spindle in 68mm cups? The races look to be a few mm more outboard than the 68mm spec spindles
Quoted: 1819 Post(s)
Liked 1,693 Times
I had a similar reaction when I saw the title of this thread. My didn't realize at first that the OP wasn't asking about a bottom bracket made in Poland. Sorry if I digress from the original purpose of the discussion.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Yes, but the chainline may not be ideal. You'll have more thread exposed on the adjustable cup, and may need a spacer on the fixed cup to tweak the chainline.
I would just install it and run it and let it wear in that is easy and you won't mess up a good spindle. you could spend a fair amount of time polishing to make it look better and not realize any gain. Of course, maybe buying a better spindle is the way to go depending on what you are building.
Quoted: 1856 Post(s)
Liked 664 Times
If possible, one of the safest things to do is to search for a NOS spindle and cup set which matches the original. Has that been ruled out or have you not even looked down that rabbit hole? Sometimes that is not as hard as one might think. Then it is not better than original, but it is what the OEM thought was sound. Assuming the original designers had their heads on straight, that should be a very good set of parts, long-lasting if serviced properly. An example of this kind of quality is the early 1950's Raleighs. No shop was perfect, but what I see in my 1952 Rudge frame, built at Nottingham is very good - not many flaws.
Sometimes you get a bike to work on which did not originally come from a smart designer who had a smart and competent factory. I'm just climbing out of what I hope is my last such rabbit hole!
