Golden Arrow rear derailleur; rebuildable?
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 174 Times
I'm putting an '86 Miyata 310 back together, and I was having problems getting the shifting right. I fiddled around with the GA rear derailleur, and found that there was a small (but not insignificant) amount of slop in the parallelogram pivot pins. The movement is easily observed...you can twist the derailleur's parallelogram a little bit, but it changes the angle and position of the pulleys quite a lot.
I've never noticed that kind of slop on other derailleurs, so I'm assuming that the pins and/or bushings are worn. Is this fixable, or is it normal for an old derailleur, or is it toast?
