Replace The Chain?
Replace The Chain?
Old 05-11-22, 08:39 PM
jwr0201
jwr0201's Avatar
Bikes: Trek Lattitude MTB Specialized Crossroads Elite
Quoted: 17 Post(s)
Liked 3 Times in 2 Posts
Replace The Chain?
I recently picked up a 2008 Specialized Crossroads and am. in the process of doing a refurb, as the bike was not really taken care of.
Question is whether I should replace the chain on such an 'experienced' bike. I assume that the bike was not a hanger queen, as the seller said - rather it looks to be we'll used.
Sage advice requested!
RR
jwr0201 is offline
Old 05-11-22, 08:42 PM
downtube42
downtube42's Avatar
Quoted: 896 Post(s)
Liked 2,063 Times in 1,081 Posts
Measure it, if stretched, replace.
If there are any frozen links, replace.
Otherwise clean and lube.
downtube42 is offline
Likes For downtube42:
Old 05-11-22, 09:41 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
OP if you don't know how to figure this out you shouldn't be doing a 'refurb' or anything else to this bike.
cxwrench is offline
Likes For cxwrench:
Old 05-12-22, 01:06 AM
Camilo
Quoted: 1109 Post(s)
Liked 1,200 Times in 760 Posts
Look up something like "how to measure chain stretch" and figure it out for yourself Not meaning to be harsh, but no advice you get here - other than that - will do any good at all. If you're uncertain at all or can't figure out how to measure whether it's good or not, just buy a new, modestly priced, chain. And look up how to size it properly. You can just match the size of the old chain, but would want to make sure that it was sized properly.
Camilo is offline
Old 05-12-22, 07:05 AM
silverado8405
Bikes: 2007 Trek 820, 2014 Fuji Gran Fondo 2.1
Quoted: 20 Post(s)
Liked 10 Times in 9 Posts
https://www.sheldonbrown.com/chain-wear.html
near the end, instructions on how to measure for wear. Or just replace chain and be done with it.
silverado8405 is offline
Old 05-12-22, 06:07 PM
jwr0201
jwr0201's Avatar
Quoted: 17 Post(s)
And why not? Did you not begin to learn somewhere or have you always been an opinionated expert?
If you cannot offer dignified advice to someone needing assistance, why bother to reply?
Did your response give any type of assistance, or just make you somehow feel superior?
Maybe not everyone has the funds to just go out and buy a $1,000.00 or more new bike.
jwr0201 is offline
Likes For jwr0201:
Old 05-12-22, 07:02 PM
Chuck M
Happy With My Bikes
Chuck M's Avatar
Quoted: 884 Post(s)
Liked 2,307 Times in 1,117 Posts
If the bike was not well cared for, the chain IMHO is suspect. KMC chains are not terribly expensive on Amazon and since you indicate that your bike is possibly not a high end bike Wal-Mart sells bicycle chains that will work. You will likely want a chain tool as you will probably have to remove a few links to get it to the length you need.
Chuck M is offline
Old 05-12-22, 08:04 PM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times in 1,439 Posts
Just be aware that if the chain has stretched to the point that it needs replacing, the replacement chain might not mesh well with the old cog and chainring teeth; they can get wallowed out as a chain wears. Sometimes replacing the drivetrain parts all at once is the best remedy, but it all depends on their condition. Start with a new chain; it'll usually let you know if other parts are needed by making noise and/or "skipping" over the worn teeth.
New vs old chainrings:
Rolla is offline
Old 05-12-22, 09:02 PM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,928 Times in 2,553 Posts
+1 But, that picture is of a new chainring and one that is very worn. Much more likely is that you cannot see a lot of wear on yours but that there is still enough that a new chain will not run properly. So, when you take off the old chain, do not throw it away! If the new chain does work out, hooray! But if it does not, now you have two choices. You can replace the freewheel/cassette (and you may need to replace the chainrings also) to work with your new chain or you can put the old one back on the old cogs and chainrings. The teeth wear down as the chain stretches so the combo may last along time as a (sorta) functioning unit but if it is worn enough, any new part will not mesh. If this is the case, I would plan on replacing everything but meanwhile, if you need a ride, the old system may work. (May. New to us used bikes are always a gamble.)
79pmooney is offline
Old 05-12-22, 09:30 PM
Rolla
Guest
^ Good advice. Don't throw away any old parts, at least for awhile.
Rolla is offline
