For the love of English 3 speeds...
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1294 Post(s)
Liked 935 Times
Here are some picture of my new bike, a Rudge Sports from 1962. I have wanted an English 3-speed for a long time, ever since 1985 when I got to briefly ride a 1960 Raleigh Sports. I thought, at that time, that it was the best ride I had ever had on a bike.
This one is about halfway to being reasonably clean and lubricated. It looks like everything's there, anyway. I was very pleased to find this nearby. I'll take
it for a ride and get you all some better photos maybe tomorrow.
Likes For 1989Pre:
Johno59: Thanks. Regarding the rear basket removal, I was not expecting it to be that easy. I just hope I turned the adjusting nut on the indicator
into the right position once I re-attached it.
Regarding the sprocket being loose, I don't follow you. You are saying I need to buy some spacers?
Standard Member
Liked 935 Times
Hopefully someone else will chime in, but I am pretty certain you can get LED bulbs online.
There are people on the thread that can tell you more about trouble shooting the Dynohubs system and parts, than I can.
Quoted: 331 Post(s)
Liked 332 Times
In the schematic they are listed as X-49 ,two of. Here they are in front of the sprocket. I usually have them behind the sprocket.
Quoted: 331 Post(s)
Liked 332 Times
LED Bulbs
Niclite LED bulbs have a website on EBay. You need the Bulb and the capacitor. They've worked fine for me.
Quoted: 331 Post(s)
Liked 332 Times
Spin the wheel and place a screw driver across the two terminals on the dynohub. A spark indicates you have power.
Likes For Johno59:
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
We are clearing out some of the dead or beater bikes from the shared bike shed in our apartment complex and a neighbour called an 80's Gazelle Impala with AB hub a "total loss". (to be fair, it was a dumpster find)
With the exception of some superficial rust the only thing really wrong here was a front wheel that rubbed the frame, which was easily fixed by undoing both nuts, putting the wheel in straight, and then tightening them again. We are now discussing future ownership or €30 in replacement parts to get everything running smoothly again.
But honestly, some new cables and a new shifter and it will run as new again for a decade more.
Likes For JaccoW:
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 265 Times
There are two methods of making sure the aduster of the toggle chain (also known as the indicator) is set up correctly. The method I like to use is to put the shifter in low, and set the shift cable tension as low as I can while simultaneously seeing to it that the toggle chain is pulled out of the hub as far as it will go. This insures that the shifter will have the least amount of tension on it when in first and all the higher gears will be in the right place (avoiding that notorious 'neutral' between 2nd and 3rd). Note that the cable stop on the top tube of the bike as well as the pulley for the cable are both secured properly!
Standard Member
Liked 935 Times
Standard Member
Liked 935 Times
Jacco, it'd look even better with a white saddle, possibly Reydel! Good job saving it.
Standard Member
Liked 935 Times
Johno, I spun the front wheel and turned on the dyno. It works when I throw the switch to the right, but when I throw it to the left, nothing.
The way the sprocket was set up was one spacer behind the sprocket and one in front, so that's how I left it.
Standard Member
Liked 935 Times
Bluestreak: Yes, I have Nicelite LED bulb in the Ever Ready can on my Grubb. The bulb in the lamp on the Rudge appears to be okay, so I'll see what kind of illumination I get.
Try staking it, which is cheap and easy. Get a cold chisel and on the backside of the arm go around the swaged part and make nice little radial grooves by whacking the chisel with a BFH. It'll probably hold. I've done it.
Not exactly the right pic but you get the idea; you want to deform the metal to pinch the other piece in order to immobilize it.
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 439 Times
Likes For gster:
Standard Member
Liked 935 Times
Thanks, Gster.
I was going to clean it up and put it back on the road, but then decided to go a bit further. I just bought a cotter pin press (the cotters are original) and a Raleigh fixed cup tool, so will give the heart of the bicycle a look later next week and get it re-lubed with new bearings. I think everything is original on it, including the brake pads and Regency tires. Even the Dyno Hub works!
The saddle is dated 1961, and seems to be just fine! I think I got lucky for $75.00. The seller even delivered it for me. The Dyno-Hub is dated 1961 and the rear Sturmey February of 1962. I hope to have some nice, outdoor pics of it in a couple of weeks.
Liked 439 Times
Thanks, Gster.
I usually leave the fixed cup alone.
The older the bike, the easier it often is to get the cotters out.
Some can be very stubborn.
Good price.
Standard Member
Liked 935 Times
How can the fixed cup be inspected, cleaned and repacked while still on the bike?
Liked 439 Times
The steel is very strong and I have never removed/replaced one.
These bikes were built to last
and they really do.
Likes For gster:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
His 'n' hers. Looks like a matched pair of 23 inchers for a decent price.
https://www.facebook.com/marketplace...85559745796671
Likes For thumpism:
My wife has had back surgery and needs a more upright riding position. I added a Sunlite Cromo quill extender to her '73 Raleigh Sports that goes about 4" down inside the steering tube, and tightened it down using a 6mm allen wrench with a crowbar inserted so I could use both hands to tighten the wedge bolt. I inserted the handlebar and hand-tightened the top wedge bolt. But now while the handlebar is tight inside the the extender, it is the extender itself that is moving. When I straddle the wheel and apply gentle pressure to either side of the handlebar, the extender is clamped hard enough to the inside of the steering tube the headset itself is turning, you can see on the photo below the headlamp bracket out of alignment. Unfortunately the movement is loose enough to make the bike unrideable.
Does anyone have advice if it's possible to stop the movement of the headset, or if I replaced the stem extender and handlebar with a longer replacement quill stem like one of these, or if I need to raise the extender higher up the steering tube, if any of these solutions would work to stop the headset movement?
Quoted: 3804 Post(s)
Liked 6,643 Times
Had the 1950 Lenton Tourist out yesterday to participate in the 3-speed October 2020 Challenge. Intended to commute on it to work this morning, but after packing the saddlebag, I looked down to see that the rear tire was flat. Urp. Didn't have time to repair, but I'll do that this evening (took a different, non-3-speed bike).
Likes For nlerner:
Quoted: 912 Post(s)
Liked 515 Times
