Movement in cleat-pedal contact - LOOK Keo carbon
Hey guys,
When i'm exerting a whole lot of force on my pedals (climbing) I feel on the upstroke (both sides) a click and some movement upwards in the cleat. I'm not sure if it always happens, could just be that i'm not pulling hard enough sometimes but i will keep checking.
The pedals are new Look Keo Carbon (from probikekit, but i hope they're still kosher) and my shoes are entrance level Sidi's from a year or two ago (they're the rare model with straps that go inward - the dumbest idea ever and the only such model i've seen - cutting them down was the only solution i could come up with since they hit the crank as the leather stretched and they got too long).
Anyway, I'm wondering whether anyone else has come along this phenomenon with the LOOK Keo's, otherwise I'm going to assume it's the connection between the cleats and the shoe plate that's giving. I haven't been able to make the cleats move from the shoe off the bike because it's hard to get enough force on them.
Any help would be much appreciated, thanks.
Bikes: '06 Bianchi Pista; '57 Maclean; '10 Scott CR1 Pro; 2005 Trek 2000 Tandem; '09 Comotion Macchiato Tandem; 199? Novara Road; '17 Circe Helios e-tandem:1994 Trek 2300
Quoted: 147 Post(s)
Liked 93 Times
Have you tried tightening the bolts holding the cleats to the shoes?
Presumably you have keo pedals AND cleats? I.e. they match.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
Originally Posted by DUTCHDoubleA
yeah i tightened em until the bolts were getting stripped.. thanks tho
You also need to tell us what cleats you are using and if you've upped the release tension to maximum on your pedal. A click could honestly come from anywhere on your bike.
Originally Posted by operator
Thread over
why exactly?
Never ever ever never over tighten anything. All you do is stuff it.
this said this only applies if the machine screws are stripped.
well the threads aren't stripped, and the heads only a little bit - i can the bolts out if i need. I just meant to say they're definitely not loose...
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
The cleat screws (bolts) may be too long, so they are bottoming out in the shoe before the cleat is fully tightened.
Try adding a washer and see if it still happens.
Today, I believe my jurisdiction ends here...
