Schwalbe Pro One TLE tire - User Experience
Bikes: SL8 Pro, TCR beater
Quoted: 983 Post(s)
Liked 583 Times
Today I cleaned my tires and realized they were a lot more used than I thought. The back one is definitively shot - it's squared off and I can see what looks like metal wires at 2-3 small spots. Front one is still OK, but it's starting to square off and thread wear indicators are close to gone. I guess I could get another 500-1000kms out of it if I'm lucky.
Schwalbe claims they have a 4000-5000kms lifespan so I got what's expected, but I was wondering if some of you had had more luck than me. I read that some of us can get a lot more than that.
I'm a medium heavy rider (175lbs) and I'm guessing weight is my worst enemy when it comes to tire wear given that I ride 99% of the time on paved roads in very good condition with almost no debris on the shoulder. The compound is the Addix-Race. Tires are 28mm wide and mounted tubeless on 19.4mm internal width rims. They are inflated at 70PSI back & front before each ride.
Overall, I loved them. I will definitively buy them again for next season as soon as they come back in stock at my LBS.
Likes For eduskator:
I'm 200lbs and I ride the 28c at 68/70psi front to back and the 30c at 58/60.
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
This is good to know. I have the previous generation of this tire, not the TLE. (TLR? It's tubeless) I like them a lot. Mine have been on the bike for two years and around 3500 km. The rear is just beginning to square off, probably has at least 1000 km left in it. The front still looks almost like new. I too ride almost exclusively on smooth pavement and try to avoid debris as much as possible. I've had a few punctures, but nothing big, just thorns. The Orange Seal closed them right up each time, so I've never had to repair one. I think I'll stick with these.
Quoted: 20810 Post(s)
Liked 9,456 Times
I've gone through a set of these (one front, two rear), I'm around the same size and got right around the same mileage (~2500-3000 miles) out of each of the two rear tires.
Likes For WhyFi:
Quoted: 6185 Post(s)
Liked 4,803 Times
Metal wires? As in the ends of wires sticking out? Maybe pieces of old radial automotive tires that would flat us mere mortals with tubed tires.
Or is it just the threads of the casing you are seeing where the treads worn thin?
Bikes: Canyon Endurace, Merckx liege 75, Cinelli Vigorelli
Quoted: 167 Post(s)
Liked 114 Times
I second those figures. I like the tire and the durability.
If you have a steady supply of something, you can afford it and it's not interfering with your life, there's nothing wrong with being addicted. - Roland Griffiths
Flyin' under the radar
I have the tires on one of my bikes and have liked them. I will say, however, that I went with Conti GP5000 Tubeless on my other bike and prefer the Conti to the Pro Ones. I think the Contis roll better, and are a smidge more comfy. Once the Pro Ones wear out, I'll replace them with the GP5000TL.
Quoted: 983 Post(s)
Liked 583 Times
On a similar note, I still haven't found a place that had them in stock... With my hookless rims, I am very limited to what I can safely use. I saw that the new GP 5000 S TR had been approved so I might go with them instead if I can find a set of 28mm*s.
Liked 9,456 Times
Which wheels are you using? Other ETRTO hookless tires include the Michelin Power Road TL and Pirelli P-Zero Race TLR, both of which I've used on my Zipp 303S. Both are good tires. The Pirelli are super grippy but ride a little hard compared to the Schwalbe; I've only got a few hundred miles on them, so I don't know about longevity. The Power Road are a little more supple than the Pirelli, but not as supple as the Schwalbe.
Quoted: 983 Post(s)
Liked 583 Times
Giant SLR-1 wheels. The Power Road is listed as an approved tire, but the Pirelli isn't. They should be safe if they're labelled hookless compatible, though. I had the Power Road (tubed version) in one of my previous bike and liked it, but I really fell in love with the Pro Ones. It looks like the GP5000S TR is also a good candidate, but I am wondering if it lasts as much as the Pro One.
Liked 9,456 Times
Thanks for the info.
Quoted: 983 Post(s)
Liked 583 Times
Yup. The Pro One is a fantastic tire. Unfortunately, they don't stay bead-locked on my wheels when deflated, which makes sealant maintenance more fussy, so I haven't gone back to them. I figure I'll finish making the rounds of higher performance hookless tires, including the Conti when available at a decent price. If I don't find something else that I'm really happy with, I'll revisit the Pro Ones and try another layer of rim tape, or something, to see if I can get 'em to stay put.
I can understand why hookless rims would make a tire harder to stay seated, but didn't think they could unseat just like that when deflated. Never had that problem. Out of curiosity, did you try different sealants to see if it would help the tires stay seated?
Liked 9,456 Times
Nope. If they're going to stay seated, they'll stay seated without sealant. It's not a common issue, but it's not that unusual, either.
Likes For WhyFi:
Quoted: 983 Post(s)
Liked 583 Times
Good point. 5kS TR & Pro One are both 110$ a piece here in Canada, and a little less at CRC & Merlin Cycle. Very expensive.
Quoted: 983 Post(s)
Liked 583 Times
Thread revive & update on the Pro Ones...
I bought another set this year and I got 3000kms out of the rear one this time. The front one is still OK. Nothing has changed except that I am lighter than last year (should have lasted longer, right? ). Same pressure. Front one is good, but rear one is squared off. No visible sign of damage or deterioration other than being square, however.
Good thing I kept my front tire from last year; I will put on the back, hoping that I'll be good for the remainder of the season.
Will definitively try the GP5K S TR next year to see if I get better lifespan or even downgrade to Michelin Power Road TLR.
Thread Killer
Quoted: 3132 Post(s)
Liked 1,700 Times
I love the Pro One, and have Power Road TLR in service, about which I agree with WhyFi that they’re not quite as supple as Pro One, but I wouldn’t call them a downgrade; my Power Roads aren’t getting tread cuts on every ride like One, at least. The new Power Cup looks to be pushing out some improvements which may make it the tire to beat in my mind, so I’ll definitely be giving those a go before long.
Likes For chaadster:
Quoted: 983 Post(s)
Liked 583 Times
The Power Road has been discontinued, superseded by the Power Cup TLR.
Were the Power Road TLR discontinued this year? Because I see them everywhere in stock online. With my hookless rims, I am restricted into what rubber I can safely use. The Power Road is tested & approved. The Power Cup isn't. I bet they are just as safe, but I'd rather not take the risk or eating tarmac at 70km/h because of a blow-out.
Liked 9,456 Times
Thread Killer
Liked 1,700 Times
I also love the Pro Ones, but I find it a little intense for a tire to become squared-off after only 3000kms (1800 miles!). I mean, I am not a heavy rider at all and they're always inflated to the proper pressure before each ride.
The hookless scene…that’s a hot mess, so I agree you’re wise to seek an expressed “ok” from the rim maker. Due to my weight and width limitations on my roadies, I can’t run a tire width where that general 72psi max limit for hookless would work, so I’ve just not been paying attention to hookless at all.
Quoted: 983 Post(s)
Liked 583 Times
Yeah, I think the Power Cup launch was this past Spring, hitting the press in March (e.g. https://road.cc/content/tech-news/mi...ad-tyre-290961), so I’m not surprised there’s still inventory around. A quick glimpse at a Google search results shows really low— like single digit quantities— on the tires, esp. 25mm, so you might want to move to buy sooner rather than later.
Chances are that my rim manufacturer will update its compatibility chart later this year and that the Power Cup will be included. I should (hopefully) be good for the remainder of the season with my current tires so there is no rush. If not, I will try the GP5K S TR next year.
Quoted: 528 Post(s)
Liked 230 Times
I suppose road surface makes a difference. Mine are now 2'308km old and they don't look worn and still feel perfectly fine. I also have hookless rims as the wheelset I wanted was HL so I said ok whatever. They recommend the Schwalbe or the GP5k S TR and since the latter is always sold out, I pounced when I saw the Schwalbe Pro One TLE in 28mm. And actually, they also came stock with my bike where they have 3'407km and they also still seem fine.
Likes For ZHVelo:
Quoted: 983 Post(s)
Liked 583 Times
At 3500kms, your rear one hasn't squared off? If you rub your finger from a sidewall to another, you feel it perfectly round?
I still have a lot of rubber left, they're not shot, but the rear one isn't round anymore.
Quoted: 528 Post(s)
Liked 230 Times
I was actually hoping for someone to say that! I ride on tarmac that's close-to-perfect 90% of the time. I am not a heavy rider, the pressure is good, etc. In short, very good conditions to get the best lifespan out of them.
