Looking for a frame that:
Quoted: 556 Post(s)
Liked 640 Times
I am looking for a frame (or complete bike) that:
Must haves:
Has through axles front fork and rear
Supports 26x4.8
Supports 203mm disks
13-15" frame size (14-15 preferred)
Nice to have:
Steel preferred but Aluminum ok
Black preferred (but i'll paint it if necessary)
Every time I search, the only ones available are chinese made carbon fiber.... and, I'm not up for that.
Must haves:
Supports 26x4.8
Nice to have:
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
By this, do you mean "can run 203mm brake rotors", or "manufacturer says specifically I'm free and clear to run 203mm brake rotors"? I think most fat bikes will support that size, even if the manufacturer doesn't offer it as a factory option or state specifically that they'll fit. I've had 203mm rotors on my 2014 Pugsley before. The Surly Ice Cream truck in SM size might fit your needs, depending on how "official" you want that 203mm brake rotor support to be.
Quoted: 581 Post(s)
Liked 921 Times
If you insist on steel, then Surly might be the best option. They were a very early player in the fat bike market and their bikes are high quality.
The only button that isn't clicked from your list is they only have a model with F Thru-axle (Ice Cream Truck), and all are traditional QR on the rear.
Liked 762 Times
The current page for the Ice Cream Truck states that it has thru-axles front and rear:
Fat Bike Frame | Largest Tire Clearance for Bike | Ice Cream Truck | Surly Bikes
It may be worth a call to their tech department to ask if that page is accurate.
Quoted: 556 Post(s)
Liked 640 Times
and... oh god the color. Remember when Surly had dark and earthy colors instead of 'Baby Vomit Green' ?
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 463 Post(s)
Liked 546 Times
Considered a custom? Here is one builder who may be able to help you.
Fat | Capitol Bicycles
I found this guy when I was looking and considering a custom steel bike and wound up with an ICAN carbon frame (yes, Chinese ) that weighed less and cost less, but doesn't have the panache of a steel custom.
There are lots of custom builders who can make you exactly what you want. Another one who comes to mind is
https://curtlo.com/our-bikes/fat-bikes/
a fellow on the group road ride yesterday had a Curtlo, so it is at the tip of my memory...
Quoted: 2975 Post(s)
Liked 1,181 Times
Must haves:
Supports 26x4.8
Nice to have:
Must haves:
Supports 26x4.8
Nice to have:
Depends on whether you need a maintenance insurance policy (good warranty) or not. I bought a Bikes Direct Titanium Fatbike that ticks all you boxes except its titanium. The Titanium bikes had a better geometry. Mine is converted to electric and I am running the 203mm rotors. I have 14,000 miles on mine. Not sure on availability right now. that's likely to be an issue but the used market is there.
I have ridden a few of their steel frame fat bikes and they did not handle the same.
Surly is about the only manufacturer out there with a steel frame that would tick your boxes.
