New e Townie?
Likes For FREEBIRD1:
Quoted: 680 Post(s)
Liked 948 Times
they look good they have one with a bosch motor so not so wimpy. got to have a torque sensor for me. I debated on a crank forward bike as a recumbent is not the most practical bike for commuting and errands.
Far better bike and better value is the REI CTY 2.1 that sells for $1800 with 27.5 x 1.95 tires and a sturdy rear rack. With the detachable battery pack the bike is 5 lbs lighter for carrying it up stairs or placing it on a bike rack.
Likes For Calsun:
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,993 Times
They once made one with the lowest end Bosch Motor why step down from that? The color is nice though.
Quoted: 680 Post(s)
Liked 948 Times
https://electra.trekbikes.com/us/en_...olorCode=black
Quoted: 883 Post(s)
Liked 822 Times
IMO, hub motors are a fine option for cruisers unless used in hilly environments. My daughter loves the one I built for her and rides it all around Las Vegas (and soon at Burning Man). Why add complexity and expense where it's perfunctory?
Clark W. Griswold
Liked 3,993 Times
they actually have their high end one with a performance line motor.
I like the looks of frame-integrated batteries but I MUCH prefer the convenience of external packs. I have 3 e-bikes in my family, one with internal battery and the others with bottle-shaped external packs. When we are out riding together we worry about the charge on the integrated battery because we won't be able to just stop at a pub and have a drink/meal while the battery recharges.
Clark W. Griswold
Liked 3,993 Times
I have two internal batteries and the charge isn't effected by that at all in fact they happen to be larger due to they are both 625wh but that is not really relevant here.
The main difference for me is the size of the "rechargeable unit", i.e. full bike vs battery. With my bike with the integrated battery needs to be brought inside and parked near an outlet, whereas he other two bikes have compact batteries that easily come off the frame (they sit in a bottle cage with electronic terminals) so I can charge the batteries in more places where the full bike would not be welcome. For instance, I can park my bike indoor at my workplace, but there are no outlets nearby. When I take the integrated-battery bike to work I need to make sure it's topped off before I leave the house, with the other, I just need to check I have enough to get me to work and then I can charge the battery right on my desk. Even for shorter stops I can usually get to 50% in an hour or so.
Clearly everyone's ebike use is a little different so I can see how what works for me would not work for bikers use their bike for other types of biking.
Likes For Froyd Stellar:
Clark W. Griswold
Liked 3,993 Times
Maybe a good time to upgrade to something that does suit your needs more if you are commuting something with Bosch might be quite handy as Bosch is super easy to get support for and get replacement batteries and very low on needing warranties and usually when they do it is usually an odd problem or occasionally a manufacturer specific problem like the Intuvia displays on old Gazelle bikes but that was their handlebar choice and Bosch has always sent out the replacement display holders without much fuss as did Gazelle for a while and then they fixed the problem.
Cruiser GO
Picked up the single speed cruiser version, so far I really like it. Bike has plenty of pep, hill climbing ability, and stops well. I like the old school frame design over the high Townie, and the ride is really plush. The balloon tires, and 27.5's soak up the bumps nicely. I was surprised how lively the 250W motor is, the thing is very minimalistic and quiet. I'll do some range testing the next few days and see what she will do.
I put about 15 miles on it this afternoon, it is a very pleasant way travel. I suspect with a mix of assist levels when you need it I'll probably get about 30-35 mile range.
Quoted: 874 Post(s)
Liked 2,287 Times
My wife has a Townie Go with the mid drive Bosch set up and she loves it. It has an internal geared hub instead of a derailleur so if she forgets to down shift a a light , she can select the low gear and resume. She keeps it on "eco" mode most of the time and can get a few rides (10-15 miles) before a charge is required. Solid bike and very comfy according to her.
