Mounting Wahoo Roam on handlebars with my Cygolite Metro 800 light
Quoted: 57 Post(s)
Liked 8 Times
Hi. I recently purchased a Wahoo Roam and like other's I'm sure found it interferes with the light which in my case is a Cygolite Metro 800 when using the Wahoo handle bar mount as shown below. It makes it difficult to press the computer side buttons as well as the light creating glare on the computer screen. I only use the light in flashing daylight mode. In researching online solutions, I see there are after market adapters with a Go Pro mount to attach a light on the bottom side and the computer on the top but I'm sure my light is not Go Pro compatible. In another, a youtuber uses a small Topeak light that he mounts to the bottom of the supplied Wahoo mount using the round rubber bands. This is a small light, also only mostly suitable for daytime use. I guess this might do but would rather keep the same light i only just bought last summer if possible.
Any suggestions on how I can use both is appreciated. Right now I have the computer mounted on the stem which is not going to be a permanent solution for me. I want the light placed for less neck/eye movement between the computer and the road in front of me. I wonder how people manage this with big night time lights?
Quoted: 20810 Post(s)
Liked 9,456 Times
With a light from a big brand like Cygolite, you should be able to find a commercial GoPro adapter so that you can mount it under your Wahoo. With smaller brands, you might need to resort to a Shapeways model/print, but I don't think you'll have that issue.
Quoted: 6963 Post(s)
Liked 10,962 Times
The solution is easy and free: swap their locations.
Quoted: 765 Post(s)
Liked 1,733 Times
Flip the light to hang under your bars. I do that on one of my bikes, works like a champ. I planned to get a camera mount so I could hang my light for it, but decided this worked find and it saved me some money.
Sunshine
Quoted: 10956 Post(s)
Liked 7,485 Times
- Move the GPS unit to the left a bit so it isn't in the exact middle of the stem. Now you have more room.
or
- Mount the Light on the underside of the bars. There is no law it needs to sit atop the bars. You use it to be seen in the day so it doesnt need to be at the perfect downward angle...just mount it upside down and be done.
I run my cygolite upside down because i dont like lights perched atop the bars.
or
Liked 10,962 Times
I'm not really sure what you are describing. The light sits dead center on it's mount. Are you trying to say that the computer would intrude into your hand position when holding onto the bar tops, if mounted to the right of the stem?
Liked 10,962 Times
or
or
There's this, too, if the fork has an appropriate mount.
Quoted: 765 Post(s)
Liked 1,733 Times
I don't know about this light, but sometimes that exposes the charging socket to rain. If not true in this case, it's a good option.
Likes For jaxgtr:
Liked 9,456 Times
GoPro adapter is 10 bucks -
https://shop.cygolite.com/product.sc...&categoryId=31
I don't recall if the stock Wahoo mount includes a quarter turn GoPro mount, but they should be available if you want to continue to use the Wahoo mount. I opted to pick up this out-front mount for 17 bucks -
https://www.amazon.com/Dymoece-Exten.../dp/B07SSXGZ1H
It'll clean up the cockpit considerably. This is my bike with that mount and a (much larger) Cycliq camera/light -
Likes For WhyFi:
Quoted: 765 Post(s)
Liked 1,733 Times
The stock wahoo mount does not include a camera mount, but for $15, I think I will pick that up.
Brian | 2023 Trek Domane SLR 7 AXS | 2023 Trek CheckPoint SL 7 AXS | 2016 Trek Emonda ALR | 2022 Trek FX Sport 5
Bikes: 2023 S-Works Tarmac SL7 Dura-Ace Di2, 2022 Cervelo Caledonia-5 SRAM Rival etap AXS, 2019 Specialized Sirrus Elite Alloy, 1977 Schwinn Super LeTour 12.2, 85 Bianchi Limited Shimano New 600EX
Quoted: 25 Post(s)
Liked 50 Times
https://smile.amazon.com/Cygolite-Li.../dp/B07NLWS8VG
I use it with my Cygolite Streak. Should work with Metro light as well.
Liked 2,968 Times
if flipping it is not something you're wanting to do, you could install a bracket extension:
https://www.amazon.com/UPANBIKE-Hand...9&sr=1-20&th=1
-Oh Hey!
-Oh Hey!
Quoted: 57 Post(s)
Liked 8 Times
Thank you all for the excellent suggestions. I flipped the light. It will do for now but cable clutter gets in the way of the light a bit and I'm not in love with the light mounting post screw sticking up. I like the idea of the Dymoece mount with Cygolite Go Pro adapter and the way it cleans up the cockpit area but from pictures below, do you think cable clutter will get in the way of the light? Also I assume with the Go Pro adapter, the light is still able to be removed from sliding it out of the adapter (not having to remove screw where adapter screws into mount)?
My you guys have nice hover bar cable layouts! I like my Specialized Roubaix but not in love with the Hoverbar (it's big for small hands) or the cable layout although not sure what else could have been done.
Liked 10,962 Times
I’m still trying to fathom why you couldn’t just switch the two devices’ locations. Your explanation of it made absolutely zero sense.
