Polishing Vintage Shimano Crank Arms... Replace Logos or Not?
Bikes: Trek Domane SL7 Disc, Cannondale F29
Quoted: 389 Post(s)
Liked 325 Times
I recently purchased a "probably nostalgic only to me" 1987 Schwinn Tempo with a Shimano 105 6-speed group set. The crank arms are quite tarnished and warn looking so I am going to polish them which will obviously remove the "Shimano 105" logo (of which the logo is already coming off due to rubbing toe clip straps.)
For those of you who restore Shimano group sets, do you replace the logos or just live with the thought that "shiny, mirror finish with no logo" is better than "OEM finish with logo"?
I'm in the USA and VeloCals is the only place I've been able to find replacement decals for Shimano parts. The decals look a little pixelated and are obviously not the same as how Shimano originally put the logos on the cranks, but as close as I've been able to find. Have any of you used these decals? Did you clear coat over them? From the research I've done, clear coats over polished aluminum is apparently not a great idea.
Quoted: 887 Post(s)
Liked 335 Times
If you want to polish the cranks - go ahead and do it. It's your bike.
Quoted: 3511 Post(s)
Liked 2,926 Times
I've seen some good decals, but doubt they'll last very long. But on the flip side, you can replace them as often as you need! I think just polished will look great.
Quoted: 1607 Post(s)
Liked 2,216 Times
The crank is not like a rarity, Do with it what you want.
I agree that pixilated decals are somewhat disconcerting. Got some for my Pinarello, slightly disappointed.
Likes For SJX426:
Quoted: 809 Post(s)
Liked 1,022 Times
These were ordinally silkscreen or pad printed on. Although these process are usually durable for most products, on the crank they were rubbed and didn't last. So most examples will have the logo worn off to some degree. I have a pair that is 175mm. I cleaned them up and my plan was to get a vinyl transfer for it and sell it since 175 is longer than I would like. But the vinyl transfer won't last either.
My personal opinion is that I prefer not to have the labels so big on components, so if it were on my bike, I'd polish it or get a nice lightly brushed finish and leave the decal off.
Likes For Velo Mule:
Liked 2,926 Times
I suspect it was a little tougher than that. I once tried to remove the lettering from some Ultegra hubs. Nothing I used--from paint thinner to acetone and every other solvent I could think of--even smudged the lettering. Maybe the 105 lettering is applied with inks...
Likes For smd4:
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
pad print (Tampo)inks are quite durable, much more so that thin vinyl decals or waterslides, but as noted on crank arms the constant shoe contact wears off even the most durable ink or paint.
It also wears off the even more durable anodizing, which is what you need completely off if you intend to polish the resulting "raw" aluminum alloy, it ain't gonna polish otherwise.
And with that you are in for a multi-step process and my advice: leave them blank!
Hint: paint remover (like 3M Safest or Citra Strip) applied with a brush or Q-tip will take off most Tampos (with a bit of rubbing and sometimes repeat 2X or more).
Likes For unworthy1:
Most shimano cranks are clear anodized... So you'll have to strip off that if you actually want to polish anything. Otherwise it's just a lot of polishing clear coat, which I've tried a few times with less than amazing results.
Polishing uncoated aluminum is very easy & rewarding. Trying to polish Shimano cranks is not.
You can always try a reverse dacal and use a Birchwood Casy Alumnium Black Touch Up Pen to try and recreate the logo. That might be better than a sticker or clear coat long term.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
If you're not restoring the whole bike, why bother with the polishing? A total bike cleaning and light polish gets you on the road in style...shabby chic is how I describe most of my bikes.
Quoted: 389 Post(s)
Liked 325 Times
I do intend to restore the whole bike and then hang it on the wall and just stare at it every once in a while (literally) The paint on the frame is pretty bad so I intend to do a repaint. Other than the cranks and frame, the rest of the bike and components are in really good shape.
Likes For eshew:
Bikes: 2023 S-Works Tarmac SL7 Dura-Ace Di2, 2022 Cervelo Caledonia-5 SRAM Rival etap AXS, 2019 Specialized Sirrus Elite Alloy, 1977 Schwinn Super LeTour 12.2, 85 Bianchi Limited Shimano New 600EX
Quoted: 25 Post(s)
Liked 50 Times
I can't say with certainty that your cranks are not anodized, but they sure look like it to me. I have a pair of anodized 600 cranks on a 1985 Bianchi that had the same (flat/yellowing/plastic) appearance. I used Easy-Off and a Scotch-Brite pad to remove the coating and polished using a cheap Harbor Freight polishing wheel set up on my grinder. They turned out real nice. Had I taken the time to sand before polishing, I probably could have removed some of the larger scratches, but it wasn't worth the time to me. I did polish the wheels, seat post, stem, chainring, RD, and shifters. None of the other parts were anodized. I spent about 3 hours polishing the cranks.
To be sure, try using and aluminum polish on them and check results. You should know pretty quick if they're anodized. Best of luck!
Before:
Bare aluminum:
After:
Before:
Bare aluminum:
After:
Likes For Bici Veloce:
Phyllo-buster
Liked 2,054 Times
[QUOTE=PoorInRichfield;22504432]
Been there done that, more power to you!
Bikes: 2017 Sage Skyline, 2015 Co-Motion Periscope Tandem, 2012 Soma Smoothie, 2006 Kona Jake, 1986 Miyata Nine Twelve, 1977 Peugeot UO18c, 1977 Peugeot PRN10, 1974 Allegro Schweitzermeister Model 76, 1972 Hugo Rickert Spezial
Quoted: 114 Post(s)
Liked 592 Times
These look pretty good
[QUOTE=clubman;22504456]
For 14 dollars, this might not be a bad way to go. https://www.ebay.com/itm/15434438248...8AAOSw55NgNsCI
Make sure you thoroughly clean the cranks after polishing so that the polishing compound doesn’t impact adhesion.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
I have a black Shimano crankset with a foot rub spot on the drive-side arm. When it bugs me enough, I fill it in with Sharpie and it looks perfect, but after a single ride the rub mark is back. Now I just use the Sharpie when I want to take a picture of the bike.
My Bikes
My Bikes
Quoted: 389 Post(s)
Liked 325 Times
Rubbing the crank arms with some Mothers Mag & Aluminum Polish and fine steel wool made an amazing difference with hardly any work. The end result isn't museum quality, but probably as nice or nicer than the original finish on a 105 crank arm.
Likes For PoorInRichfield:
Edumacator
Quoted: 2439 Post(s)
Liked 3,125 Times
Did you remove the anodizing?
Bikes: Yes
Liked 3,868 Times
If Mothers made that kind of difference, I'd say there was no anodizing.
My Bikes
My Bikes
Likes For Andy_K:
