recreating my rides
recreating my rides
Hi all, I'm looking for some help.
I acquired a new wahoo kickr that I'm excited to use this winter. I'm not really interested in zwift of others. I just want to rerun my rides that I have saved on Strava. If anyone is doing that, can you please let me know how to do it? I really appreciate it.
Thanks,
Chuck
Thanks,
Chuck
Quoted: 578 Post(s)
Liked 1,116 Times
As far as I know, you can record your indoor rides TO Strava ( How to Record an Indoor Cycling Ride with Strava (indoorcyclingtips.com) ) but there is no way to transmit your rides FROM Strava to a smart trainer.
I've done this on Rouvy. Upload the gps file but unless you upload video of the route you will only see your progress on the map.
Old enough, hmmm?
In retrospect (20-20); an action cam would have been very handy to record all those rides, or at least a few of the epic ones. Depending on location and weather you could still do that.
Old enough, hmmm?
And then there are these
https://www.youtube.com/channel/UCVb...SCqGDs6-_awaDg
I really like all that Euro stuff without suffering the jet lag and the expense. There are even some that I cycled way back in the 50s and 60s.
Bikes: yes, i have one
Quoted: 886 Post(s)
Liked 937 Times
here is a free solution. quite boring but does the trick...
https://www.bikeforums.net/indoor-st...plication.html
Quoted: 2560 Post(s)
Liked 2,750 Times
BKool allows you to upload gps routes which you can then re-ride on your trainer. I haven't used it in the last year, but it was a bit hit and miss when I tried it. The gradient transitions are sometimes pretty dubious.
In RGT you can upload GPS files as 'Magic Roads'. (premium version). It will then create a virtual road for you to ride and track the route/gradient of the GPS file.
One thing you need is good GPS data, as I've experienced cycling on 0% gradient then in an instant it's 25% and the trainer locks up!
To avoid this you need to smooth the GPS file to take out any bad data This can be done with gpx smoother and gpx magic.
Klaatu..Verata..Necktie?
Quoted: 7789 Post(s)
Liked 8,432 Times
downtube shifter
I use the Garmin Tacx software app with my smart trainer, and I have imported saved GPS files (.gpx or .tcx). I have manually created routes in Strava, downloaded the .gpx file, and imported the file into the Tacx software. I then ride the route in GPS mode.
Thanks,
Chuck
Thanks,
Chuck
But wouldn't be masked marketing to post the names of the applications here?...
