Addiction 2021.1
#9076
Administrator
Quoted: 11966 Post(s)
Liked 6,632 Times
#9077
Quoted: 10236 Post(s)
Liked 5,183 Times
17 dollar part, shipping is 10 dollars. Expected delivery date unknown.
#9078
Administrator
Liked 6,632 Times
Likes For BillyD:
#9079
So it is
Quoted: 11400 Post(s)
Liked 4,748 Times
Likes For LAJ:
#9080
Quoted: 9653 Post(s)
Liked 6,365 Times
I can get a set of crabon bars that are otherwise the same as the current metal bars on my Domane for just a wee bit more than half price. Worthwhile upgrade? Would knock of 134 grams not to mention make my bike more crabonny.
#9081
Liked 5,183 Times
#9082
Quoted: 20810 Post(s)
Liked 9,456 Times
There are worse things that you could do with the money.
#9083
Liked 6,365 Times
#9084
Liked 5,183 Times
#9085
So it is
Liked 4,748 Times
Any deal is a good deal in todays bike market.
#9086
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,886 Times
Well this is going to sound silly, but I can’t tell if the play is the arm or pedal shaking. I noticed something felt different when riding this morning and it was only on the right side. Just checked again to be sure.
Pedals could have anywhere from 14000 to 30000 miles on them for all I know.
#9087
Liked 6,365 Times
Trigger pulled. 43% off retail. Seems like a good price.
Place is a Trek dealer in Wisconsin.
Likes For Mojo31:
#9088
Liked 9,456 Times
Which did you get? I was rather fond of their VR-CF drops. If I could have found some aero handlebars at a decent price, I would have jumped at them. As it was, I got some more conventional, but quite light, VR-CF carbon bars for $60 on CL. Couldn't pass that up.
#9089
Liked 6,365 Times
I like the bars on my bike, and the new are exactly the same geometry, so not changing the fit is attractive.
At one time, I was considering the aero bar they make: Bontrager XXX Aero Handlebar | Trek Bikes. But, talking to the guy at the shop about all that would need to be done to replace cables and hoses, labor, etc., it was coming to close to $600 for that change. That was a bit more than I wanted to spend on something like that. Maybe if and when I ever become an "elite" rider.
This change I can do myself for less than $250 when I add in the tape. According to the Trek site, I'll be going from 310 grams to 176 grams.
Likes For Mojo31:
#9090
Liked 9,456 Times
Today is my day off, but it's raining on and off and is supposed to continue to do so all day. I still might try and squeeze out for a quickie if it looks like I can find a window of an hour or so without rain.
Side note: got the oil changed in the VW today, so I guess this was a good day for it, in that regard.
#9091
Liked 9,456 Times
They are the XXX VR-C, 42cm: Bontrager XXX VR-C Road Handlebar | Trek Bikes
Yeah, internal routing is a pain in the ass, but it's not something that has to be done too often and it looks killer; I wouldn't pay a $600 for that, either, but it's worth $200, a couple beers and a couple hours of sporadic swearing.
#9092
Mostly Harmless
Bikes: Have two wheels
Quoted: 13711 Post(s)
Liked 4,525 Times
#9093
Liked 6,365 Times
Yup, should be an easy swap. They will feel just a little different, too - I like carbon bars.
I have the tools to do most basic maintenance, but don't have the equipment to do the cables and hydro lines. Beer and swearing are readily available.
#9094
Should Be More Popular
Quoted: 22593 Post(s)
Liked 8,925 Times
#9095
Liked 5,183 Times
what kind grease do you ladies and gents use on your seatpost?
#9096
Liked 9,456 Times
I like the internal routing a lot. Probably the one thing that put me off on it was that I was talking to the guy about making the switch at the time I was getting my wheel fixed and a new fork installed. When you added the aero bars and labor onto the other, it was getting over $1k. That would be hard to justify to the wife. She's usually pretty accommodating, until she's not.
The hydro really isn't too tough, either: a bleed kit (inexpensive and readily available) and something to cut the lines cleanly without crimping them too much.
After you've got the above, you only need a little common sense and the willingness to deal with some minor frustration.
#9097
Liked 9,456 Times
For the Cervelo, use carbon assembly grease/paste with grit in it.
For the Ritchey, I'll defer to the others, but I think that whatever grease you've got on hand will be fine - Phil's, Finish Line, Park, whatever.
#9098
Liked 5,183 Times
Referencing the ritchey, currently all I have is a tub of this penzoil bearing grease. Didn’t know if it would hurt to use it, I have keep the connections on the frame lubed to prevent rust. If the grease I have isn’t recommended then I’ll go get some.
#9099
Liked 6,365 Times
I like the White Lightning Crystal grease. It's clear, doesn't stain, and really holds up well.
#9100
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
