Dura-Ace Chain 11spd CN-H6901-11 Question
Old 05-15-22, 06:06 AM
buddiiee
Bikes: 70's Nuovo Record Jeunet Franche Compte, '88 105 Trek 1200, '85 Victory Bianchi Vittoria, '89 Exage Bianchi Strada LX, '11 Shimano Masi Partenza
Quoted: 109 Post(s)
Liked 19 Times in 15 Posts
I'm noticing that the newer Dura-Ace chain's side plates aren't bulged out like the older ones were; am I seeing this incorrectly, or did they stop doing that? If they did, are there any advantages?
70's Nuovo Record Jeunet Franche Compte, '88 105 Trek 1200, '85 Victory Bianchi Vittoria, '89 Exage Bianchi Strada LX, & '11 Shimano Masi Partenza
buddiiee is offline
Old 05-15-22, 06:47 AM
easyupbug
Quoted: 566 Post(s)
Liked 559 Times in 403 Posts
I seem to remember the 9 speed and maybe 8 had a bulge between pins, a extra step to form in manufacturing which when you make as many chains as they do the cost adds up fast and questionable value.
easyupbug is offline
Old 05-15-22, 09:48 AM
Troul
Troul's Avatar
Liked 2,936 Times in 1,900 Posts
My theories are that the change to the design might have been to reduce chain rub for an intended group set. The more tolerance within a cassette &/or multi geared crank could cause a shift to suffer from the moment of command to execution & chances of such, increases when the designed spacing is already wider & that group set has worn in over time. If the later group set is new, the redesigned chain might not want to release as freely from the gear teeth, resulting in a misfire shift or a heavier demand if using friction shifters.
Just my theories. YMMV.
-Oh Hey!
Troul is offline
Old 05-15-22, 12:31 PM
buddiiee
Quoted: 109 Post(s)
I see... good theory. Also. Anyone know then when they stopped the bulging side plates then? I have some 6 and 7 speed bikes that I'd like to put a new shimano chain on and was wanting the best shifting chain I could get. I'm asking because I have a good deal on an 11 speed dura ace chain but it looks like the side plates are flat, and I didn't know if that was a dura ace chain or not.
buddiiee is offline
Old 05-15-22, 07:17 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
You're considering putting 11 speed chains on 6 &7 speed bikes?
cxwrench is offline
Likes For cxwrench:
Old 05-16-22, 01:19 AM
buddiiee
Quoted: 109 Post(s)
Only because I heard they were the best, and the longest lasting. But I'm not sure any more, as I think the bulged sideplates has more benefit for my needs.
buddiiee is offline
Old 05-16-22, 08:59 AM
Iride01
Iride01's Avatar
Quoted: 6163 Post(s)
Liked 4,782 Times in 3,300 Posts
DuraAce isn't necessarily longer lasting. It's just the top of the line for Shimano. And it is optimized to work with the other DuraAce components the best of all. Shifting ability and weight will be the performance things Shimano is looking at. Longevity is probably about the same as their lower tiers, maybe even a little less since it's all about crossing the finish line first.
Chains are made to work with specific speed rears. So use a 12 speed chain for 12 speed rears. 11 speed chain for 11 speed rears and so forth. But when you get down below 9 speed rears, then 5,6,7 and 8 pretty much are just the same chain. 9 will probably work on them too reasonably.
Iride01 is offline
Old 05-16-22, 09:22 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Maybe the 'best' for 11 speed drivetrains...it's apparent to me that you need to do some research about multi-speed chains and what should work with what. It makes zero sense to use a D/A 11 speed chain on a 6 or 7 speed drivetrain.
cxwrench is offline
Old 05-16-22, 10:41 AM
buddiiee
Quoted: 109 Post(s)
I was watching Silca's videos on drivetrain friction and longevity and not that any of that actually means anything to me in real life, (because i'm just a rider now, not a paid pro competitor) I'm an experimenter, so when I hear or see things I often times put them to the test just for experiments's sakes. This way I can physically see how stuff works, and have the actual experience now instead of just repeating what other's say ya know?
buddiiee is offline
Old 05-16-22, 11:54 AM
cxwrench
cxwrench's Avatar
Bikes: lots
So you're ignoring facts about different speed drivetrains and parts that were designed and engineered to work together by very intelligent people and trying it yourself just to 'see how it works'?
cxwrench is offline
Old 05-16-22, 12:38 PM
Rdmonster69
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times in 216 Posts
Use a chain that is designed for the number of speeds in your cassette. My DA 11 speed chain is VERY narrow w/no bulged side plates. I can see you having difficulties getting it dialed in just because its made for an 11 speed cassette.
Rdmonster69 is offline
Old 05-16-22, 12:42 PM
alcjphil
alcjphil's Avatar
Quoted: 1813 Post(s)
Liked 1,692 Times in 973 Posts
Using an 11 speed chain on 6 or 7 speed drivetrains invites the very real possibility of your chain jamming between chainrings during front shifts and baulky shifts at the rear
alcjphil is offline
Old 05-16-22, 12:53 PM
Iride01
Iride01's Avatar
Sometimes if you tell a child not to push a button, they'll go way out of their way and through any amount of trouble to push the button. <grin>
From time to time, I've been afflicted with that mentality too!
Iride01 is offline
Old 05-17-22, 05:47 AM
buddiiee
Quoted: 109 Post(s)
Who said I ignored it? Not I. My original post was asking about the bulged sideplates; because I was considering one, not buying one. When posters here started chiming in about width specifications, I read them, and took them into consideration.
Iride01, did anyone push any buttons? I'm still looking but I just can't find any.
Thank you for your help guys.
buddiiee is offline
Old 05-17-22, 09:02 AM
easyupbug
Quoted: 566 Post(s)
Could not agree more, I have seen the aftermath of what was said to be a lazy shift drop a 10 speed chain between rings and the resulting fall damage was ugly.
