Headset cap and bolt disappeared while on bike rack
Hi! had a bizarre experience for my Giant TCR headset cap/bolt. Somehow the headset bolt and cap worked their way off and fell off during a trip on my car bike rack (kuat).
Has anyone had this happen?
The spacer above the stem was still on there. So strange. I did lower the stem/put a spacer that was below the stem above it maybe 500 miles ago. I think I did everything right (fingertight on the headset cap first, then tightened the stem bolts with torque wrench).
Think there's any chance I lost anything else? I forget what it looked like without the cap. I can see a bearing and the hole where the bolt goes.
I'm seeing a number of stem caps/bolts available for sale online-any recommendations?
Quoted: 20791 Post(s)
Liked 9,435 Times
Sounds like someone stole your baby bike bolt.
Likes For WhyFi:
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
Well, if your top cap was only on finger tight, it probably rattled loose from riding and fell off when the bike was turned and tilted while lifting it up at some point. I imagine your headset is probably loose also, if you did not properly add preload with the top cap after you moved the spacers around.
Quoted: 7621 Post(s)
Liked 3,432 Times
I tho0ught I might be the first with stollen baby bolts, but ....
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove
Quoted: 548 Post(s)
Liked 719 Times
Top cap bolt should be tight enough that there is no play but not so tight as to cause binding. Is there a little play in the fork now?
Once your stem is correctly torqued the top cap does nothing, apart from holding that the extra spacer.
Quoted: 6866 Post(s)
Liked 10,828 Times
Sounds like you didn't have enough load on your topcap, which means it's actually good that it fell off: if you kept riding it like that, something might have been damaged.
Get a new stem cap and bolt, and read up on proper headset adjustment.
Likes For Koyote:
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
The bike or headset will have a torque spec. If you loosen the stem to adjust the bars the cap maintains that torque spec until you tighten down the stem bolts again.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 259 Post(s)
Liked 439 Times
Um. After I tighten my stem I alway tighten the top cap bolt a bit. Was afraid it would come loose. Guess I made the correct choice. I just have to remember to redo the headset bearing preload if I loosen the stem for adjusting.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
No, the headset will not have a torque spec. The stem bolts and bar clamp bolts will. The only bike that has a torque spec for the headset is the Trek Domane w/ front Iso Speed.
Likes For cxwrench:
Liked 10,828 Times
Loosen stem bolts, adjust headset with the topcap bolt, then torque the stem bolts. That's it.
Plenty of online tutorials which explain how to adjust the topcap bolt.
Should Be More Popular
Quoted: 22473 Post(s)
Liked 8,794 Times
OP, if your bike was set up properly you can ride it as is. Get a replacement stem cap and bolt, unlikely you lost anything else if spacers are intact.
And the jokes about stollen baby bike bolts is a bit of BF history/pop culture.
Update for closure: I got a new cap and bolt for $8 from my bike shop. The mechanic showed me how tight the cap/bolt should be, and it was tighter than I thought fingertight was. Nothing was missing other than the cap and bolt.
Very happy that this lesson only cost me 8 bucks and a drive.
Quoted: 645 Post(s)
Liked 797 Times
Chris King specifies a torque for the NoThreadSet top cap - it’s pretty low - 10-12 in.lb, IIRC.
Bikes: lots
Liked 2,932 Times
4) C h e c k h e a d s e t f o r p r o p e r a d j u s t m e n t . W h e n p r o p e r l y a d j u s t e d , t h e fo r k w i l l ro t a t e smoothly without play or restriction. Some settling may occur after a few rides; readjust if necessary.
There are no torque values on bearing preload. You adjust 'properly' and that's it. They give a 6-15in lb value when initially putting everything together then finish w/ 'adjust it properly'. You might get away w/ somewhere in between 6 and 15 but you just don't know. I've been at this a looooong time and the only headset I've put a torque wrench on is the Domane Iso Speed.
Likes For cxwrench:
Advocatus Diaboli
Quoted: 4696 Post(s)
Liked 1,512 Times
It's 6-15in lbs. It's also step 2 of a 4 step process that ends w/:
