better than a park tool grease gun
Old 02-23-21, 02:38 PM
travbikeman
travbikeman's Avatar
Bikes: State 4130 Custom, Giant Trance 29
Quoted: 416 Post(s)
Liked 172 Times in 117 Posts
Ok, just received an email back from Park Tools telling me that grease seepage is normal from these grease guns.
Are there better small grease guns out there that do not leak the grease?
travbikeman is offline
Old 02-23-21, 03:21 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3556 Post(s)
Liked 3,332 Times in 1,899 Posts
My Dualco has a cap on the base that seems to prevent that kind of mess:
File Type: jpg
File Type: jpg
JohnDThompson is offline
Likes For JohnDThompson:
Old 02-23-21, 03:53 PM
2_i
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 831 Post(s)
Liked 332 Times in 247 Posts
Dualco here too and no problems either.
2_i is offline
Likes For 2_i:
Old 02-23-21, 03:56 PM
travbikeman
Quoted: 416 Post(s)
Thanks, will be shopping for those. Thinking I paid too much for a Park Tool.
2nd Park Tool I've owned that really disappointed.
Old 02-23-21, 04:09 PM
Unca_Sam
The dropped
Unca_Sam's Avatar
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times in 696 Posts
Park's grease gun IS a Dualco gun, but rebranded. Dualco doesn't seem to sell to end-users easily.
Unca_Sam is offline
Old 02-23-21, 04:16 PM
travbikeman
Quoted: 416 Post(s)
Thanks, I just read that elsewhere. Might just deal with it and create a better holster that holds the gun upside down when not in use to prevent grease from dripping out.
Old 02-23-21, 04:21 PM
Unca_Sam
The dropped
Unca_Sam's Avatar
It's only a problem when it's warm.
Unca_Sam is offline
Old 02-23-21, 04:28 PM
travbikeman
Quoted: 416 Post(s)
Heh...that might be a problem.... it's in the basement and the basement is cold and it's leaking.
OK, note to self: create a holster before summer when it will really leak warm grease....
Old 02-23-21, 05:18 PM
Unca_Sam
The dropped
Unca_Sam's Avatar
Park's grease is runnier than the Mobil 1 grease I switched to. OTOH, if you're using a tube, the top of the gun has threads to screw onto most grease tubes. Just cut the nozzle down to the threads and screw a new tube on. It's easy to prime and refill that way.
Unca_Sam is offline
Likes For Unca_Sam:
Old 02-23-21, 06:24 PM
drlogik
drlogik's Avatar
Bikes: '87-ish Pinarello Montello; '89 Nishiki Ariel; '85 Raleigh Wyoming, '16 Wabi Special, '16 Wabi Classic, '14 Kona Cinder Cone
Quoted: 698 Post(s)
Liked 405 Times in 251 Posts
+4 for Dualco. I have four of them. Different grease in each one. Mine never leak or pass unless I leave the grease gun for too long, hot weather hits and the grease starts to separate. That's only happened with some cheap wheel bearing grease I bought at the auto parts store. Hence why I don't use that any more.
On another note, the Dualco's that I bought 15 to 20 years ago seem to be made better than the two I bought 4 or 5 years ago. That may have something to do with it leaking. Mine that leaked was one I bought 4 or 5 years ago.
drlogik is offline
Likes For drlogik:
Old 02-23-21, 06:50 PM
2_i
Quoted: 831 Post(s)
The grease I am using is the synthetic Motorex 2000. Among its benefits is that does not liquefy with temperature. It also hardly ages so you use it up at slow pace which compensates for its somewhat elevated price.
2_i is offline
Likes For 2_i:
Old 02-23-21, 09:36 PM
drlogik
drlogik's Avatar
Quoted: 698 Post(s)
Motorex 2000 is one of my go-to greases as well. Finish Line Teflon is the other. Both seem to have a long shelf life in an unheated garage and a hot garage in the summer. Both survived Arizona summers.
drlogik is offline
Old 02-23-21, 10:09 PM
Russ Roth
Quoted: 1071 Post(s)
Liked 988 Times in 704 Posts
I've been fairly happy with my astro pneumatic which looks like the dualco but with a shorter needle. I did have a touch of trouble with the needle clogging but a minute with a slightly larger drill bit solved that one.
Russ Roth is offline
Likes For Russ Roth:
Old 02-23-21, 11:38 PM
SalsaShark
SalsaShark's Avatar
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times in 166 Posts
Picked up this big syringe in the animal medicine department of my local farm supply store. I reshaped and rounded the tip, and polished it smooth so i can inject grease directly onto bearing cups without fear of scratching the surface with the needle. Been using this for a few years, only cost a couple bucks - good control with the grease, and if you pull back on the plunger slightly when done using it, it will not leak anything.
SalsaShark is offline
Likes For SalsaShark:
Old 02-24-21, 06:01 AM
Juan el Boricua
Bikes: 1980's Royce Union "fixed wheel", 1995 Trek 370, 406 -wheeled " shopper/minivelo"for running errands, SS Raleigh M60
Quoted: 41 Post(s)
Liked 52 Times in 41 Posts
Maybe because of the design but, and as also John pointed out about the Dualco, both the Dualco and Astro Pneumatic have a bottom cover; just looked at Park's catalog and they're shown without the cover. Iwonder why would Park Tool skimp on this feature as it not only helps in preventing "runny grease", but also stabilize the gun and protect the barrel's lips if it hits the floor. Here are my Astro Pneumatic's.
Juan el Boricua is offline
Likes For Juan el Boricua:
