Are these fork/stem races removeable? Worth the trouble?
I would like to remove the aluminum races from the frame so I can clean/polish them. I think they're are quite likely stuck, if they're even removeable at al. I don't want to risk damaging them if removal is too difficult.
Thoughts?
Thoughts?
Quoted: 1438 Post(s)
Liked 1,091 Times
I suspect that they are steel, judging by the red rust. Check with a magnet.
Made in Taiwan
Bikes: Camerotti ti roadbike, Old Sears Free Spirit Tange Hi-Ten Single Speed built from a 12 speed, 1997 Cannondale CAD3 r500 with Shimano 6400 groupset
Quoted: 35 Post(s)
Liked 11 Times
Those are headset cups, there is a specific tool used to hammer them out so that pressure is applied evenly all the way around.
If you don't have access to such a tool or don't want to make your own. You can use a large flat head screw driver and hammer to tap out the cups. However, if you remove the cups, the bigger problem is getting them seated again or pressed back into your frame.
Please, do a google search on on 1) headset cup removal and 2) headset cup installation. Better yet, watch some youtube videos.
If you don't know what you are doing, you can damage your bike/parts.
All dogs want to be lap dogs doesn't matter the size
-Animal loving friend
Likes For *Scuba:
Liked 1,091 Times
Never Fix A Running Piece. I am not sure what you could do in the way of cleaning/polishing the cups after removal that you could not do in situ.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Just google search 'headset cup removal'...you'll get thousands of results in a fraction of a second. It's easy w/ the correct tool.
Likes For cxwrench:
Old fart
Quoted: 3556 Post(s)
Liked 3,332 Times
But keep in mind you'll need another "correct tool" to reinstall them properly.
If the goal is merely to remove the surface rust for cosmetic reasons, leave them in place and rub with crumpled aluminum foil or a scotch-brite™ pad to get rid of the rust.
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
Mask off the headtube to protect it and polish the cups while they are still installed. You will not get them any cleaner by removing them from the headtube - the only part that is inaccessible is the part of the cups that are pressed against the inside of the headtube, and you don't want to polish that anyway. You also risk damage to the cups and frame if you do not have the proper removal and re-installation tools.
Likes For SalsaShark:
Mother Nature's Son
Quoted: 838 Post(s)
Liked 1,412 Times
There are homemade tools that can accomplish the removal and installation of the cups. One source is RJ the bike guy on youtube. I used his tool ideas for that, and they worked OK. You just need to take your time and make sure things are progressing properly. However, I did end up buying a removal tool and a headset press as I had other bikes to do. I bought both tools during a sale at Chain Reaction Cycles.com. IIRC, it was about $80 usd for both. The prices have gone up since I purchased. If this is a onetime deal, the cost is probably not worth it.
As stated above, I think you could accomplish what you want without removing the cups. If you are just touching up the paint on the frame, no need to remove the cups.
Likes For delbiker1:
