Found this small spring on the floor while working on my bike
Bikes: 1994 Cadex CFR3, 2006 Scott CR1 SL, Rossin aero, Bertrand GB 2000, Spec Allez Pro
Quoted: 134 Post(s)
Liked 68 Times
Any idea where it might come from? The bike in question is a vintage cannondale, with a 7 speed 105SC groupset. I played a bit with the bearing on the rear wheel (but this seems unlikely to involve such a spring?), adjusted the rear derailleur, changed the cables etc. but again I don't see from where it could have come from. The springs of both barrel adjusters on the brakes are still in place. The spring might have fallen on the floor when I removed the bike from my stand. Anyway, any insight would be appreciated!
Quoted: 907 Post(s)
Liked 1,569 Times
Front or rear derailuer... This a joke?
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
This is the spring that goes around the intonation screw of the high E saddle on your Strat. Probably fell off when you snapped your string jamming some Hendrix in your garage the other night. Look close, the saddle and screw are on the floor somewhere, too. You will need those unless you want to continue to play a 5 string guitar.
Quoted: 134 Post(s)
Liked 68 Times
Alright this is probably a dumb question, probably should have slept on it before starting a thread. Learners have to ask dumb questions from time to time I guess
Old fart
Quoted: 3556 Post(s)
Liked 3,332 Times
Looks like a spring from a shift cable barrel adjuster.
Likes For JohnDThompson:
rebmeM roineS
Quoted: 653 Post(s)
Liked 345 Times
Spring has sprung and fallen on the floor.
Not from a hub skewer.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
brake lever return spring? barrel adjuster's probably it
Liked 2,904 Times
Likes For Troul:
Bikes: 2007 Trek 1.2 50/39/30 triple front, 12-23 or 12/26 9speed rear.
Liked 5 Times
If you have an original Volkswagen beetle engine, and take it apart and put it back together enough times, you'll be able to build another Volkswagen engine from the leftover parts, and both will run fine.
Likes For rivrgazr:
Likes For sweeks:
Klaatu..Verata..Necktie?
Quoted: 10126 Post(s)
Liked 11,469 Times
Check your brake cable barrel adjusters.
