Hydraulic tires
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
Used to fill farm implement tires with a calcium chloride slurry back when I worked in a tire shop. This added weight for traction and prevented the fluid from freezing in the cold, as pure water would.
Not sure why anybody would want to weigh down bicycle wheels, though?
Quoted: 18302 Post(s)
Liked 4,470 Times
Yep, I've got tractor tires with Calcium in them. More modern ones may use Beet Juice which is far less corrosive.
Of course, tire sealant is popular with some cyclists, but I don't think I would go with full bike tires.
If the water in a tire was 100% full, with even slight pressure, your tires might well feel like rocks.
Quoted: 520 Post(s)
Liked 227 Times
I thought this might be a ;little late in the year for an April Fool's joke. Air is easily compressed and water is not so if you really filled your tires with water the bike would ride as hard as if it had solid rubber tires. This one is a nightmare for weight weenies. Water is 8 pounds per gallon but air weighs nearly nothing. Sure would add weight to the bike, Here is one brand you might look at - Slime
I thought this might be a ;little late in the year for an April Fool's joke. Air is easily compressed and water is not so if you really filled your tires with water the bike would ride as hard as if it had solid rubber tires. This one is a nightmare for weight weenies. Water is 8 pounds per gallon but air weighs nearly nothing. Sure would add weight to the bike, Here is one brand you might look at - Slime https://www.youtube.com/watch?v=82pMuI2bk0k
Live not by lies.
Bikes: BigBox bikes.
Quoted: 859 Post(s)
Liked 782 Times
Kind of.
Only with zero intention of healing the tire.
Water is harder to push through a hole than air. So when the tires pick up screws, rivets, other kinds of trash it gives me a lot more time until I have to plug or change them.
This is on a 3500 diesel truck.
I would not want to do the same thing to a bike.
Kind of.
Rhapsodic Laviathan
Quoted: 796 Post(s)
Liked 986 Times
You know, if you have a cycling buddy that faster than you and then doesn't let you forget about it. Fill his or her tubes about halfway with water and go for a ride with them.
Maybe I can pick up a Schwinn XR-1 to XR-6 exercise bike and replace the solid rubber tire with a regular tire and tube, but fill the tube about halfway up with water. Maybe add some propylene glycol, so it doesn't freeze and some glycerin to thicken it up. I seem to talking myself into yet another Schwinn project. By adjusting the amount of liquid and the thickness of the liquid I could adjust the resistance. At slow speeds, the resistance would be low. As the tire rotates faster, I would expect the resistance to increase due to churning of the liquid, then at some critical speed the liquid will be "plastered" against the perimeter of the inner tube and resistance will level off or even go down. Will it go down again? Does resistance ever go down as the rpm's go up? I would think that in this case, it would.
Any physicists or fluid dynamic experts want to weigh in on this? Calling gugie .
