Is this tire cooked?
Or is it fairly savable. The tread of this Turbo Cotton
is still great, but the rubber part has parted in a few places. I've used some superglue here and there, but curious how much of this gluing would undermine the structural integrity of the tire?
bike whisperer
Quoted: 1526 Post(s)
Liked 718 Times
Most of the structural integrity is in the casing. You also want the tread to be pretty much adhered to it...
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
How far can you walk in road shoes?
Likes For GlennR:
Expired Member
Quoted: 3660 Post(s)
Liked 5,406 Times
You surely don't want it separating mid corner.... A friend had a pair of those that came on a new bike. I fixed a flat/ swapped a tube for her and those are some impressively supple tires. I hadn't seen anything like them since the days of tubulars. Or maybe I should say flimsy instead of supple because they were definitely flat magnets. She moved on from them quickly but I figure they rode nicely when they were holding air.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4379 Post(s)
Liked 3,014 Times
I would ride it home and then throw it in the trash.
Quoted: 1814 Post(s)
Liked 923 Times
You can glue those down with contact cement, but it may be a losing battle if more edges come loose. The tread was glued on to start with so there's no structural issue.
Clean with small wire brush & rubbing alcohol; when dry coat both surfaces with moderate coat of glue, let dry with the parts separated with toothpick; press down and hit glued area with hammer against smooth flat surface.
Mother Nature's Son
Quoted: 852 Post(s)
Liked 1,433 Times
No way I would ride that tire again.
Likes For spilot101:
