Does this crank take a special tool to remove?
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 676 Post(s)
Liked 447 Times
1986 Panasonic DX 5000.All my other bikes use the same Park crank tool.
Not sure how this one comes off. The hole in the center is round and doesn't
use an allen key
use an allen key
Quoted: 18320 Post(s)
Liked 4,489 Times
Shimano... something?
It should just take a standard crank puller.
Quoted: 676 Post(s)
Liked 447 Times
Liked 4,489 Times
I think there are a few exceptions. TA?
Screw the crank puller so the large part is even with the end of the puller. The large part of the puller should screw into the crank BY HAND.
Once secure, turn the handle so the small part pushes against the bottom bracket. It doesn't screw in.
I DON'T SEE ONE IN YOUR PHOTO, BUT MAKE SURE YOUR CRANK DOESN'T USE WASHERS.
Likes For CliffordK:
Liked 4,489 Times
Perhaps upload a photo of your crank puller that you're using.
Quoted: 676 Post(s)
Liked 447 Times
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
Lucky, that means you probably have the old version of the tool with TA threads on the other side (I'm sure someone will be along to correct me if it was Stronglight...) I lost mine somewhere, as a casualty of working on bikes in the backyard
Bikes: yes
Quoted: 510 Post(s)
Liked 401 Times
Quoted: 826 Post(s)
Liked 2,048 Times
You've got it right. The older double-sided tool works on standard threading plus TA cranks. Stronglight cranks need a different puller
Quoted: 1073 Post(s)
Liked 1,882 Times
Once I ruined a decent set of cranks because I forgot to remove the little protective cap from the crank extractor bolt and just pulled the thread straight out. "Geez, why are these cranks on so tight?"
