disc brake rubbing from flex?
commu*ist spy
I have a 2016 giant tcx, which uses 15f/12r thru axles. I thought this would eliminate rotor rubbing, but I was wrong. when I stand up to put power down on a hill or sprint, the front rotors still rub. it's pretty annoying. curious whether this happens to others.
I have the same issue on my front brakes. In fact, I have aligned the brake multiple times on the stand, and it wont rub. However, once I go out to the road and apply some power and ride, i start getting a local rub every rotation. The rotor must be a bit out of plane but the weird thing is that it doesn't rub when I stop and spin the wheel without load or weight.
bike whisperer
Quoted: 1526 Post(s)
Liked 718 Times
Oh yeah, road discs are half baked. Had endless hassle trying to eliminate rub in the shop... I don't miss that.
The pad gap is too small. And there's nothing you can do about it on hydraulic systems, as far as I know.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Quoted: 20810 Post(s)
Liked 9,456 Times
Bikes: Shmikes
Quoted: 10153 Post(s)
Liked 5,848 Times
I've had this too. There's usually a sweet spot/angle, but it can take hours to find. I wish the caliper mounting system were better designed for precise adjustment, perhaps with some visual guides.
commu*ist spy
all my rotors are 1.5 mm width, they're as true as i can get them. I suspect caliper angle has something to do with it, but there's no way to really change that on the bike. supposedly, the caliper is the one that's at the right angle, and it's the rotor that's slightly angled
what bothers me more is that when I do hard braking down a steep long hill, the rotors rub continuously until it cools off again. this happens on my ice tech rotors as well. I've tried bleeding it and tending to the pistons. hasn't fixed anything
Quoted: 1216 Post(s)
Liked 185 Times
It just happens with some riders. I've yet to ride a road or gravel frame/fork/brake combo I couldn't induce some brake rub on - Until a few weeks ago I worked for the largest bicycle chain retailer in the Southeast so I've ridden a lot of bikes. Some riders just have positions that angle the whole system enough to get brake rub. I mean, even really stiff bikes aren't that stiff. Grab the wheel on any bike and wrench it around and you'll see the rotor/rim move around quite a bit. When you're on the bike, the entire system moves around so many riders never have rub, but many other do. Happens with rim brakes too but most people never noticed because the pad/rim material is quiet.
If it really bothers you try semi-metallic or resin pads, they'll still rub a bit but you won't hear it unless you're in a situation where you're up at 4+ w/kg but going <10 mph.
Quoted: 4717 Post(s)
Liked 1,882 Times
Liked 9,456 Times
Also, have you tried the business card trick?
Non omnino gravis
Never had caliper rub ever, on two different bikes, three different forks, two different front rotor sizes, 4 different calipers (everything from basic mechanicals to 4-piston hydraulics,) standard QR axles, and always with rotors much thicker than 1.5mm.
Setting up disc brakes is not difficult. At all. If no amount of tweaking can get it correct, then something is wrong with the fork, caliper, or rotor.
Liked 1,882 Times
https://www.parktool.com/product/dis...ing-set-dt-5-2
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
This. I thought my front rotor rub was from the rotor heating up, then it was happening the first time I hit the brakes. Checked closer and the outboard piston wasn't fully retracting. It's getting replaced under warranty.
Non omnino gravis
Well, that's pretty much my point. I assume the OP or his shop had fiddled with the setup, and still couldn't get it right. So why hasn't the shop at the very least suggested some corrective measure?
Brakes aren't supposed to rub, and if all parts are mechanically sound and the contact points are straight and clean, there should be no issues. Something on the OPs bike needs to be addressed-- it's not an outright indicator of the fallibility of disc brakes on bicycles.
Likes For DrIsotope:
commu*ist spy
however, it still doesn't really explain why there is continuous rubbing after steep down hills. I'm not a fred (165 lbs). The pistons are retracting like they should. I did a bleed job very recently so I doubt there's bubbles in the caliper. not sure what else could be going on
Quoted: 73 Post(s)
Liked 41 Times
ahh I see. but what if I have post mount adapters? there's no real way to shave those very precisely. but I guess if the fork is slightly crooked, it might help. will look into it.
Not a deal breaker, but it's noticeable
Likes For RedBullFiXX:
Liked 9,456 Times
Edit: and the word you're looking for is Clyde, not Fred.
bike whisperer
Liked 718 Times
Not all bike companies can adopt a new standard without glitches too. Had a bunch of Focus through-axle forks where the rotor rubbed on the damn fork leg!
