Tubeless valve stem length?
Taking the tubeless plunge. Wheels on order, but as I began to research tubeless valves (and setup in general), I was soon flummoxed by the endless array of valves! Based on reading forum posts, I've (sort of) settled on the Muc-Off ones, but I have no idea what length to order (as I said, I don't have the wheels in hand). I need them for 50mm deep rims and 38mm deep rims. Any guidance would be appreciated. Also, input on whether the Muc-Offs a good choice; and I'm wondering if anyone has tried the unconventional Fillmore valves? Would love some honest evaluation of those puppies (very spendy, but worth it?). Cheers!
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Neil of bikepacking.com likes the Fillmore valves. Clearly a better design for the tubeless world, but I'm not convinced it's worth the price. As far as valve length, I'm not sure. I ordered my new wheels with valves installed assuming the wheel builder would install the proper length valves. You might look up the rim manufacturer and see if they recommend valve lengths for the rims you're getting.
https://www.youtube.com/watch?v=zj31...IKEPACKING.com
edit: for traditional presta valves, I like ones that have a valve core wrench built into the cap. Muc-off valves have that. Plus I like brightly colored valves - just makes things a little easier, a little easier to spot the cap when you drop it in the grass.
Likes For tyrion:
Quoted: 874 Post(s)
Liked 726 Times
I just installed 80mm Muc-off valves on my 50/56 deep wheelset. 80 should be plenty for 60mm rims, but for the shallower rims definitely drop down to shorter valves as I wouldn't want the 80mm to stick out any further than they do on my 50mm rim.
Quoted: 222 Post(s)
Liked 304 Times
I like the Muc-Off valves. They have a larger internal width than others I’ve used, so the tube on my syringe passes completely through it.
As for length, I’m building up some 45 mm deep rims and I thought the 60 mm stems were just a bit short and all clamp-on air hoses might not work. So, I’m going with the next size up which is 80 mm. Longer than I’d like, but not stupid long.
Quoted: 6193 Post(s)
Liked 4,809 Times
I'm not certain I'd worry about brand loyalty for a valve. Just get a valve that is the correct length for your rim. If you don't have aero rims, then you probably need the short one.
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
Get one that works with your pump to avoid any unpleasant surprises.
For me, Peaty's work great. Muc off seems to be incompatible with Silca pump chucks.
Peaty's have the additional merit of matching Chris King anodization color options, and have a spoke wrench and valve core extractor caps that might be useful in an emergency.
Habitual User
Quoted: 4946 Post(s)
Liked 8,085 Times
I'm another fan of Muc-Off valves.
