Show us your half-step gearing!
#126
Bikes: Jamis Dakar XC bike 26", GMC walmart 10speed with touring stem and Power Grips, various low-buck treking and fishing bikes
low-normal rear derailleur?
Thank you for the information, Ruffinit!
I understand the concept now, and I like it. My first couple of road bicycles had very high 2x cranksets (53/42 example) with road racing clusters. I liked the close ratios, but they were terrible for anything but racing, since there was no way to just chug up hills or carry packages.
Duplicate gears don't really annoy me too much. I usually drive my bicycles in whatever chainring they are in, plus the cog I want, though I do shift strategically for hills or mountain bike obstacles.
Re DOWN TUBE SHIFTERS. Those things are awesome for townie bikes and ultralight set ups, but I tired of them long ago when I started mountain biking. I have since customized mountain bike "pods" for the drops on my road bike, like this. I like the XT style ones better though, they have a thumb trigger and a index finger trigger, instead of 2 thumb buttons.
Have you guys ever tried Low-Normal rear derailleurs? If you can find a Shimano XT Low-Normal 8 or 9 speed rear derailleur, it should work with 5,6,7,8,9 speeds using compatible shifter and cogs! It will go toward the "granniest" cassette/freewheel gear when you shift. They take a while to get used to, but are very nice, as they shift automatically, as soon as the optimal ramped surface meets the chain.
Half step is basically like having a high/low for each of your cogs on your freewheel. The number of teeth between each of the freewheel cogs is determined by your chainrings and given the total package you would have (on a 6 speed freewheel) 12 distinct non-duplicated gears which are evenly spaced. This gives you not just efficiency in your geartrain but a very smooth transition between gears. The "+Granny" or "+Alpine" equates to your third chainring which is small enought to give you a whole separate set of gears below the normal 12 (in this case). When completed you have 18 distinct gears.
#127
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
I found this forum looking for stuff related to "corncob cassettes" to go along with a discussion about the new Sram group (definitely not a cob.)
It has 2 front rings and a big-gap but even 11-32 10x cluster.
I like the classic stuff on here a lot. It was a real treat to see the Sturmey/Shimano custom bike. My first road bike had 52/42 and 12-25 6x. I hated it till I put a 39t on the front.
After that I've been a fan of closely geared triple cranks and 11-26 rear.
So is the aim of the half-step style group to avoid duplicate ratios, or to facilitate small changes to a driving ratio for slight grades? (a shift down and up with the front once on a light grade, instead of clicking a bunch of rear gears)
I have a 46 & 38 130 bcd Sram Cyclocross crank. If I was to install a 43 as the small chainring, I could have very good half-step gearing across a broad range. I think TA makes a 43 chainring that accepts a 10 speed chain.
It would be helpfull in windy conditions to stay on cadence. 15% jumps in cadence with a 11-32 Ten speed cassette can be annoying, the half step provides a 7% change in cadence, much better.
Michael
#128
"Chooch"
Bikes: Late 1990s Ciocc Titan
Frank Berto's great articles in Bicycling magazine became my gearing "bible". I frequently referred to his "Build Your Own Super Tourer" and "All About Twelve Speeds" articles, the later becoming the basis for my current "crossover" (no double-shift) gearing on my Ciocc.
#129
I have a 1984 Univega Gran Turismo which I thought had half step gearing, but after reading this thread and putting the numbers through Sheldon Brown Gear Calculator, I discovered that really isn't the case at all:
I had tried using it as a half step but it didn't feel like the steps were anywhere near equal, and now I see that's because they aren't! Does anyone have any recommendations on the best course to make this gearing more usable, either half step or not. I tend to stay on the middle chain ring, occasionally use the smaller chain ring, and pretty much never use the larger one, so I've even considered replacing the outer one with a chain guard :-P I'd rather not do that though.
-Eric
-Eric
#130
Quoted: 910 Post(s)
Liked 288 Times
-Eric
-Eric
#131
Location: Rhode Island (an obscure suburb of Connecticut)
Bikes: one of each
Quoted: 8 Post(s)
Liked 12 Times
28/24=1.17
24/21=1.14
21/18=1.17
18/16=1.13
16/14=1.14
That's fairly consistent with an average difference of 1.15. The rings should be half that difference, 1.075. Keeping the 46 you'd want a 49.45 (46x1.075). Rounding to the nearest integer gives you a 49, though a 50 is pretty close.
24/21=1.14
21/18=1.17
18/16=1.13
16/14=1.14
#132
Senior Moment
Quoted: 7 Post(s)
It seems to me that your riding preference is to ride on a middle chainring as much as possible, and shift down when you get on a steeper grade, and maybe shift up on a big downhill. Half step plus granny gearing isn't suited for that gearing/riding preference. With half step plus granny gearing you would be shifting up and down on the middle and large chainrings in combo with the freewheel, in order to use the right gear for your regular riding (plus shift down to the small chainring for steeper hills). Your riding preference can be effected with double chainrings of 28-48. Maybe you don't "need" a triple and would prefer to save some weight and simplify? If you change your triple to half step plus granny gear, you "should" be front shifting a lot to utilize your gears, but if your preference is to leave it on one front chainring as much as possible, then maybe you don't want a triple?
#133
likes to ride an old bike
I've been planning out a half-step plus granny for the Atala (I know, I know, that's so wrong for an Italian bike). Shimano makes a 11-30 8-speed cassette with nearly perfect 15% spacing.
With something like a 24/42/45 triple, that goes down to 22 gear inches with perfect 7% spacing from 38 to 110 gear inches. With brifters I don't think the extra shifting will be a problem at all. Can't wait to get it built up.
#134
-Eric
#135
Bicycle Repair Man !!!
I just swapped the wheels on my touring bike to a more original set of Sansin high flange hubs and Araya rims and am using a 7 speed mega range with a 28/36/48 up front.
I had a half step ready to go but when I ran the numbers I saw that I have a 19/21 speed bike with one gear overlapping 3 times and in two places it is a gearing I would never select, and the mega ranges offers a tighter 6 speed with 2 step changes from 14-24 and that 34 tooth bailout.
Will play with this for a while as it looks ideal... will probably spend most of my time cruising with the 48 and the 14/16/18, can climb most things with the 36 and have full range across the block whileI will reserve the 28 for extreme climbs and could make that smaller without creating any more serious overlap.
If I find I am spinning out my 85 gear inches I will swap in a 50 tooth ring and still won't have any grievous overlap.
#136
-Eric
-Eric
It is an easy upgrade to move from 6 to 7 and I am a big fan of these m-range freewheels and cassettes.
#137
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
'58 Lenton Grand Prix with Cyclo Benelux derailleurs.
46-49 chain rings shifted with the lever operated derailleur.
original 14-16-18-20 freewheel has been replaced with a 14-28 freewheel for various reasons. The Benelux derailleur won't shift to the smallest cog, which is no surprise and, really, no great loss.
#138
Bikes: one of each
Quoted: 8 Post(s)
Liked 12 Times
Well, here's my shot at this game. It's a Williams/Raleigh 46/49 crank with a 36 32 28 24 21 18 16 14 12 cassette. The ratios aren't as close as I'd like but they're not bad. I've also got a 34 30 26 23 20 17 15 13 11 cassette and I think I can do a little better if I mix and match cogs but I need to think that over some more.
I did a little more wright up on this thing here;https://www.bikeforums.net/showthread...n-a-531-Falcon!
#139
Bikes: -1973 Motobecane Mirage -197? Velosolex L'Etoile -'71 Raleigh Super Course
that crank is Beeeeeeyooooootiful! Why doesn't Shimano make next year's Ultegra look like that? Why? WHYYYY?!?!?!
<<Here's what I got: 46/50 with 30/24/21/19/17/15/13 for 14 unduplicated gears. Strongly considering ditching the Mighty Tour crankset for something I can set up with a bailout ring, no matter how pretty the Sugino is.
And it will never be as pretty as the Williams, no; not if it were ever so.
#140
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
I am sure this has been explained in the previous pages but I have a few questions. I am seriously considering building a bike with a realish 1/2 step gearing. on most of normal road bikes I run a 42/52-3 and a cassette/FW something like 12-21/23ish. I normally use the 42 most of the time.
would a 42/48 ctrank and 12-25 be acceptable or should I use something like a 48/52 and a 13-30 cassette? i doubt I will really get to use this bike as an actual long distance/Randonneurer bike but I want to atleast try and build a true half step.
and one of the great things about bikes is I can easily change back to a normal 42/52 bike
Sugar "Kane" Kowalczyk
#141
Bikes: one of each
Quoted: 8 Post(s)
Liked 12 Times
Try the online gear calculator. Punch in both gear combo options and then punch in your current set up and see how the new sets compare to the gears you use most on your current set.
https://sheldonbrown.com/gears/
How many cogs are on your freewheel? 42/48 seems like a big jump but if the numbers are good then they are good.
#142
Bianchi Goddess
Liked 2,923 Times
I am going to use a a 7spd. 42/48 is only 6teeth is a half step much closer? 45/48 maybe?
I'll try the calculator. the bike is currently a blank slate, so this is still in the hypothetical arena
#143
I should send you a Shimano 14-34 5 speed so that you can fully appreciate what half step gearing is supposed to accomplish
Half step gearing works best with wide range 4-6 speed freewheels and is almost redundant with wide range 8-9 speed cassettes and impractical with a close range 8-9 speed as the gearing steps in the rear are already so very close.
#144
Bikes: one of each
Quoted: 8 Post(s)
Liked 12 Times
Your chain is far too short...
Yeah. I've got the extra links. It's just that these 9 speed pins aren't reusable and this chain is really supposed to be on this other bike I've got.
I've got one of those on my Trek now. The thing came stock with a 45/50 and this 6 speed freewheel that had nothing to do with half stepping. I don't know why Trek bothered with that thing. The rest of the bike seems so well thought out. I haven't had a chance to try it out since the weather cleared but this afternoon I'll be on it for a while.
Turns out the steps on this cassette are about the same as for a 14-24 5 speed which is what the crankset was designed for. So I can stay in the middle gears and it's the same but I can keep downshifting when I get to a hill.
#148
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
#149
Bikes: one of each
Quoted: 8 Post(s)
Liked 12 Times
Oh, like this.
While the steps seem close on the 9 speed, they average a 14.75% difference so they're actually a little wide for the 46/49 with a 6.5% difference.
It does seem a little finicky for the rolling hills around here. I'm always fiddling with the shifters. But I'd be doing the same with the old freewheel, I'd just run out of gears sooner.
#150
Bikes: one of each
Quoted: 8 Post(s)
Liked 12 Times
So, I finally got around to getting My Trek out today. It's an '82 612 (or 614, I forget). This is the freewheel the brochure says it came with from the factory but it doesn't make any sense to me.
I replaced it with this Suntour Perfect that's just about perfect for it;
The 45/50 seems a lot less fussy than the 46/49. I'm still monkeying with it a lot but that might just be cause I'm new to this half step thing. Then again, maybe the terrain around here is just not right for half stepping.
Hey, Sixty Fiver, what are the other gears on that 14-34?
